Question about Sony KP-57WV700 57" Rear Projection HDTV
Sony KP 57WV700 Rear Projection blinks 5 times when turning on. No picture when connected to Component or DVI plugs but I can get picture with composite video (yellow cable). I can get audio. I tried to adjust the 3 voltage knobs.
  • Sony Master
  • 19,396 Answers
Five blinks mean: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
In your case it looks like you have a faulty crt drive on the A board, the A board must be replaced. For that reason the set works only on composite, where signal is analog.
Before replacing the A board all input ports must be tested, the A board can be tested following indications on service manual.
The A board and service manual can be ordered from:
Encompass Parts Distribution
or
Electronics parts & more from PartStore.com
Regards.
Posted on Jun 19, 2009
Sony kp-57wv700 cannot adjust color or hue
if you have a big sub right against it it needs to be moved away as the magnets can affect the big screen picture.
Mar 30, 2012 | Sony KP-57WS500 57" Rear Projection...
I have a Sony Kp-51ws520 5 blinks
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 22, 2010 | Sony KP-51WS520 51" Rear Projection...
Picture is very blue, especially in dark scenes.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 21, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
I have a KP-57WV7000 that will not turn on. I got
try to turn the tv on using the sony remote and this sequence of buttons push display 5 volume up then power if the tv comes on change ic8002 on the power supply if it doesnt try replacing anyway this is a common issue with sony tv's
Jan 24, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
Sony projection tv 5 years old
you will need to call an electronic repair shop to get this problem resolved
Oct 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
5 blinks, Sony KP-65WS500 stays up only with one CRT gun at a time....
5 times blinks shows White Balance error in tv. You need to adjust Screen Volts (G2) and problem will resolve. Screen volts controls located at Focus Block as shown in below picture.
d90a778.jpg Need further help, please let me know.
Bye.
Sep 09, 2008 | Sony KP-65WS500 65" Rear Projection...
Sony projecting tv kp-57wv700
Based on service manual info, it cant blinks 7 times as per symptoms, please count again blinks. It can be 5 times.
If its 7 times blink, Horizontal Deflection stopped in this case. If you want to repair it at your own, please let me know to guide you further but it is necessary you should have knowledge of electronics.
Aug 18, 2008 | Sony KP-57WV600 57" Rear Projection...
SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
May 27, 2008 | Sony KP-53XBR200 53" Rear Projection...
Sony KP-57WV700 57" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
