Question about E-Machines eMachines Desktop PC
Relocatated an emachine now it says no input signal
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 57 Answers
Check both ends of your monitor cable to make sure it is plugged in firmly. Also, do you see a power light on the pc?
Posted on Apr 17, 2014
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
Protron tv says input signal out of range when connecting laptop via hdmi
The TV can't process the digital signal. It might be out of range.
Nov 26, 2012 | Protron PLTV3250 32 in. LCD Television
Can i connect my xbox 360 using Dvi D to Hdmi in the dvi slot and also my tower to the vga slot on my eMachines E19T6W
I am not an xbox person, but as far as hooking it up, it should work as long as the other device is NOT powered up. That being said you will still have to provide audio from the xbox another way as dvi only carries a video signal, unlike the hdmi which carries both audio and video.
Dec 12, 2011 | eMachines E19T6W 19" Monitor
It will start starting up, then it'll say "no input signal" and turn off again.
that means your keyboard might be faulty or the cable has been remove or faulty.
Aug 02, 2010 | E-Machines eMachines Desktop PC
When I turn on computer, the blue light comes on and the computer makes sounds as if it is starting and the monitor light is yellow. If I turn the monitor off and then back on, the screen says something...
No input usually indicates the machine is having trouble getting a video signal from the monitor. Check and make sure the monitor cable is connected properly. If you have another monitor also test the machine with another monitor.
Feb 26, 2010 | E-Machines eMachines Desktop PC
Emachine 17" lcd monitor from Best Buy
1: Check the cable connections for the VGA or DVI cable at both ends for a secure connection.
2: There may be a button on the bezel of the monitor for input source to switch between VGA, DVI, or HDMI. While the monitor is on, press that one or more times waiting 2 or 3 seconds between presses to see of it finds the signal.
Apr 10, 2017 | E-Machines e15t 15" Flat Panel LCD Monitor
No input signal form a laptop to a projector
Hi jkoceng,
What type of interface cable are you using to connect to the projector? 15-pin VGA? S-video?
Generally on laptops if you look at the keyboard on the function keys (F1, F2, etc.) you'll see little icons such as adjustment of volume, brightness, etc. Look for one that looks like a monitor or screen. Usually this is on the F5 or F6 key. If the icon is blue, look for the corresponding key on the keyboard (Fn key, CTRL, Alt, etc.) and then hold that when connected to the projector while you press the appropriate function key. This should alleviate your problem.
Of course, you'll also want to be certain that you're using the correct input function on the projector.
Ben
Mar 13, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
20 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
