Question about Maytag MSD2436GR Side by Side Refrigerator
Maytag plus msd2456geb stoped cooling or freezing last night...does it need free on and if so where is the valve located
3 Suggested Answers
hiltonjug
  • 612 Answers
SOURCE: Maytag MSD2456GEB fridge section warm
Please remember I am attempting to diagnose your appliance without being there and with very little information.
Sorry but if your freezer is 10 degrees, it is running warm. Freezer is designed to run between -10 and 0 degrees. Reset controls, place them in the middle of the scales. The controls can be confusing. The control that turns the unit on and off is your freezer thermostat and the other is the damper that controls the air flow from the freezer into the fresh food section. What I would think is wrong with your unit is one of two things.
  1. You have a defrost problem.
  2. Your inside fan is not running.
1. Look at the inside back panel of your freezer. If you have ice or frost built up on the panel, you most likely have a bad defrost heater.
2. Check to be sure you have air flow inside your fresh food section coming from your freezer. If not and your control is setting around mid-ways, you have a bad fan or your defrost heater is bad and ice is blocking the air flow.
Please rate solution
Posted on Sep 14, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhkgjd
Posted on Sep 29, 2010
Power surge brand new maytag fridge not cooling
That power surge probably burnt out the guse on the circuit board. I suspect you may need a new board unless you know an electricity geek who can replace the fuse. New I would check your warranty. That circuit board might cost $200. plus..
Dec 21, 2014 | Maytag MSD2756G Side by Side Refrigerator
The freeze of my Maytag plus refrigerator is not working
You need to check the Condenser coils, these are copper coils of tubing usually located on the back of the unit near the ground. They need to be free of all dust and grease to work at maximum efficiencyand it is recommended to clean them every 6 to 10 months.
If that doesn't solve the problem then there may be a refrigerant leak. In order to legally put reclaim, recharge, or test refrigerants you need a special certification2_bing.gif from the EPA. If you need to do so I recommend you call in a certified technician.
Mar 30, 2010 | Refrigerators
Maytag FrenchDoor- fridge not cool
My friend you need a new circulation fan motor.
As you can see the diagram.
Your freezer do not need fan to be cold, but your refrigerator need a fan to deliver cool air into it.
Should you need more details please feel free to contact me at nguyen@ite.net
Jun 09, 2009 | Maytag MFD2560HES Bottom Freezer French...
The fridge is not defrosting and the fan inside is stoping
One of 3 things cause a ref not to defrost. Defrost timer may not be advancing to the defrost position on the timer...The defrost thermostat, located on the evaporator in the freezer, is measures open bad)...or you have a bad defrost heater. If you have an electronic defrost control,which is used on most Maytag, Jenair, or Amana units, this could be your problem. If you turn the unit off for 24 hours to let it defrost manually then it will last for about 2 weeks before freeze up again.
Apr 02, 2009 | Fisher Refrigerators
Left the door open on my Freezer last night and now it doesnt wor
After looking at some advice from others I turned the internal dial to the OFF position, then turned it back to 6 or 7, and left it for 20 minutes, and it is now freezing again.
Jan 04, 2009 | Freezers
Left door open on freezer last night and now it wont work
turn it off for a day or two let it defrost and then turn it on. it just has frozen up the coil, or the compressor has heated up cause it was working to hard turn it of for a cople of hours to let the compressor cool
Jan 04, 2009 | Frigidaire FRT21P5A Top Freezer...
Maytag ice dispenser wiring diagram model MSD2456GEB
apc...appliance parts center has a good web site that might get you a wiring diagram. or your local appliance supply store might.
Jan 09, 2008 | Maytag MFI2568AE Side by Side French Door...
Refigerator leaked water slightly then stoped cooling
Yes try to turn with a screw driver if possible. If it start working replace timer. If not it can be low on freon you would see frosting but no cooling.
Jan 07, 2008 | Magic Chef CTF2125 Top Freezer...
Maytag MSD2436GR Side by Side Refrigerator Logo
71 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
