I had my home inspected and it was determined that the "condensate drain line is disconnected from the nipple on the water heater flue pipe." What exactly am I looking for to attach the drain line/tube back to?
Tankless or hybrid water heater?
Tankless gas must have special fitting between water heater and vent that has a condensate line fitting. Hot toxic vent gasses traveling up vent pipe cause acidic water vapor to form inside vent pipe that drips back down vent and drips onto heat exchanger and other parts eventually burning hole through expensive metal alloy heat exchanger, rendering tankless computer water heater useless after electric circuitry gets wet and shorts out.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#vent
Hybrid or heat pump type computer water heaters must have condensate drain connected to catch pan located just above storage tank and below compressor. Condensation can form on condenser coils and drip into catch pan where there is primary and secondary drain
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#maintenance
Read product manual
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: I have a 40 gal
You will need an amp meter. I suspect that the lower heating element is out or the thermostat.
Most water heater have a upper and lower element. The bottom is the main work horse.
Take the lower access door off and you can get to the wires to use a clamp on Amp meter. You should get a reading of 10 + amp if it is working. You can check the thermostat with the volt meter also to make sure you are getting voltage to the element . You should have 220 volts across the two wire attached to the element. The elements are not to hard to change. You will need to shut the power Off and the Cold Water off. Drain the tank to get below the bottom element and you will need to get a special wrench to unscrew the old element out of the tank. Hope this Helps
Testimonial: "Thanks for the promt reply, I had the feeling it might be that but did not know how to find out. Thanks again"
SOURCE: i have a 250SX aquastar bosch tankless hot water
The 250 MUST have the condensate line connected. EC comes from gas supply problems and CO2 levels not being adjusted. LP units require 3/4" smooth gas pipe or 1" corrugated pipe minimum size. The LP regulator needs to be turned up to about 13 inches of water column and with all the gas appliances on, measure no less than 11 inches of water column. The CO2 levels must be measured by a qualified gas technician with a calibrated (with in 6 months) CO2 analyzer.
SOURCE: Water heater ground
run to breaker panel or drive a 8ft ground rod and connect to it the water line is no longer acceptable as the public utility's are using pvc for gas and water now and this is no longer a practice you could use the ground rod that is already installed on your service and use connector , but something you might do well to check is to make sure in the process of installing the plastic pipes the ground going to the panel was not also disrupted if so you will need to install 2 8ft ground rods at least 6 ft apart and daisey chain together with proper size ground wire . # 4 solid for 200 amp and # 6 solid for 100 amp service , I would make sure the panel ground is solid very important for safety ,, let me know if i can further assist
SOURCE: I have a 50 gallon
The accumulation of condensation in the vent piping is more than likly the problem. I am guessing the vent piping is either 3-inch or 2-inch. You need to splice in a "T" fitting reduced down to 3/4-inch with a 3/4-inch tubing attached and run this to a sutible drain. This will drain the condensation elimiating the accumulation in the vent assembly. Install this "T" fitting about 3-feet down stream from the vent motor.These supples and fittings can be found at a Home Depot or Lowes store.
SOURCE: I have a Bosch AquaStar
Tankless should never be installed with plastic pipe, PVC or CPVC etc.
Before calling service technician, open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
