Question about Magic Chef CER3725AA Electric Kitchen Range
Control panel not lighting up and oven not working.
How do i check to see if control panel is bad
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Have you checked your fuse box? Maybe a circuit breaker has tripped or a safety switch
Posted on May 08, 2014
Light in oven not working. I put new one in , still not working. Electric oven
Possible bad door switch or some ovens have a switch on the control panel for the interior light that could be bad.
Mar 04, 2015 | Cars & Trucks
My oven does not heat up. Control panel lights up; oven igniter does not light up. I have oven igniter checked and said it is not the problem. What else can I check? Thanks...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 03, 2011 | GE Spectra JGBP35 Gas Kitchen Range
Oven will not come on however broiler, cook top, lights, and control panel etc. all work fine.
Oven not Working or
Oven not Heating
heatman101
Jan 22, 2011 | Siemens HG2416UC Gas Kitchen Range
Both the bake and broil oven elements do not heat up / they are unresponsive. I can set the oven temp but on the control panel and it appears that everything is OK there I've replaced both elements and...
Must check the the voltage of 240 coming in to the oven sometime there is 120 volts which will light up the control panel but not enough to turn on the heat elements also check the wiring diagram some times there are cut off switches between the control panel and heat elements those can be bad too!
Appliancetek
www.astrepairs.com
Jan 14, 2011 | Ovens
Tappan oven tgfs26cba , oven does not light when turned on. control panel says it's working. glow plug glows hot. gas inot fed. was informed wife had taped oven vents to stop mice ??? could this have over...
Just because it glows that does not mean it is not bad...
heatman101
Sep 04, 2010 | Tappan Ovens
Control switch for upper grille/oven is operating intermittently.ie. indicator lights not coming on. Is this likely to be the switch or the electronic control panel?
If` it is intermittent, it could be bad connection, or the control switch is faulty, if you can gain access to the control panel, check for bad or burnt connections, unlikely to be board, but not unknown for them to go faulty.
Please rate my solution.
Thanks.
Jul 15, 2009 | Neff U1721 Double circotherm Electric Oven
Magic chef stove
If the oven is working but the control does not light up then you will have to replace the control.  If the oven doesn't work then will have to check and see if you have power to the control.  If power is there then the control is bad.
Oct 25, 2007 | Magic Chef CER3725AA Electric Kitchen...
Samsung RGSF5330DT Range dead.
try checking control panel connections they might be dirty if not then board is proberly bad
Aug 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Magic Chef CER3725AA Electric Kitchen Range Logo
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
