Question about Safe International Electronic Digital Steel Safe Gun Box Home Office
I cannot get n my safe. I cant find the key n I think the battery is low.
    Problem Solver:
I would suggest leaving it for a day so that the battery has some power (they do recharge slightly if not completely dead) and make sure you get the number right straight away. You really need the key to be found, as it makes it so much easier. You may still have problems with a new battery; this is what we have found in the past. Good luck.
Posted on Apr 17, 2014
Opening my safe when the batteries are low
Without the details of the safe this is very difficult to answer, however most safes have a hidden key slot beneath a clip off panel, If you haven't got a key you would have to resort to a locksmith to pick the override key slot.
Mar 09, 2017 | The Home Security
I have the key I know the3 combination but still i could not open because it's in low battery
if you know the battery is low then you need to open your safe using the keys and then change your batteries as the safe won't open using your 3 digit code if the batteries are low.
Jan 03, 2013 | Safe International Digital Electronic Safe...
How do you open gun safe if battery dead and cant find key
Look hard for the key!!
A locksmith is going to cost you.
Make a note to change to battery every year - kinda like a battery fire alarm.
Have a real careful look for that key - think of the money it will save you if you find it! ! !
GOOD LUCK
Feb 25, 2011 | Garden
I cannot open my Noble safe with the code I had. It seems that my code is gone and I don't find the key to open the safe. What can I do ? songa
I cannot open my Noble safe. I havent used it for 1 year, it has no battery and cant open it with my key. I cant remember the code, but i wont be able ti use it with no batteries.
What can i do
Feb 23, 2011 | Safe International Digital Electronic Safe...
I have a cs-2 digital safe batteries dead cant find key help please
Try taking a 9 v battery and hold the terminals against the metal frame of the safe. If this works you should be able to enter your code and get her open. Then you can replace the 4 AA batteries on the back of the door. Good luck
Mar 15, 2010 | Safe International Digital Electronic Safe...
How to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Nov 01, 2009 | Home Security
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Low battery
Dont know your model but on mine the battery is located behind the key pad. turn it clockwise and pull it strait out to access battery.
Mar 29, 2008 | Sentry Fireproof Safe
Safe International Electronic Digital Steel Safe Gun Box Home Office Logo
97 people viewed this question
Top Safe International Home Security Experts
Computer Repairing
Computer Repairing
Theo Nikolaidis
Theo Nikolaidis
Are you a Safe International Home Security Expert? Answer questions, earn points and help others
