Question about Home
Saniflo cubic1 not pumping
Makes noise but does not pump out waste
olddewsons
  • 38 Answers
SOURCE: pumping stopped
Well it sound likes you have 2 problems. 1st is the float switch is set to high,and pump wont come on till it raises higher then tray. 2nd. sounds like empeller came lose from shaft. I hope this help. :)
Posted on Jul 07, 2009
venexcsd
  • 1185 Answers
SOURCE: The water from the loo and shower is rising & not going down
The outlet is blocked , get an engineer in to fix it pronto
Posted on Aug 24, 2009
SOURCE: Saniflo Macerator Noise
If it's a one shot cleaning and not an ongong additive, bleach can be used to dissolve the tissue.
Charlie
Posted on Aug 31, 2009
Testimonial: "i havent tried it but its very helpful. Thanks."
citroenchris
  • 600 Answers
SOURCE: Continually pumps
Probably the waste pipe blocked, it should have a rubber join that has worm screw clips securing it, I connect a hose to the"up" pipe and flush the blockage out.
Posted on Mar 18, 2010
stevenw9
  • 7 Answers
SOURCE: I got a saniflo plus but motor runs but pump is not pumping?
The internal motor capacitor has failed - most common problem with these units
I have posted repair instructions here:
Saniplus repair instructions
It is a PDF
Posted on Jun 28, 2012
My saniflo macerator plus has stopped working-it had been making a humming noise not draining-now it's not making a noise at all-what might be wrong please?
It could be a blockage in the blade, impeller or the discharge line. Also could be a defective starting capacitor, since the capacitor spins the blade and impeller, if the capacitor goes bad it will make the unit hum and not pump out the waste until eventually it shuts off completely and would not kick on and off at all. At this point, the capacitor may have to be replaced. You should contact Saniflo to order parts.
Aug 21, 2011 | Saniflo 002/005/007 Saniplus Toilet with...
My saniflo pump turns on about every six hours or so on its own.what could be the ploblem?
Water pressure makes the unit kick on and off. Most likely somehow water is draining back into the pump. Check the flapper in the flush valve, inside the toilet tank and see if its leaking water into the bowl and from the bowl into the pump. Also, in the 90 degree discharge elbow there is a check valve with a rubber flapper that opens up to allow waste to pump out and it closes to prevent waste water from draining back into the pump. The check valve may be defective or it may be stuck open allowing waste water to drain back into the pump and is making the unit kick on and off by itself.
Apr 03, 2011 | Saniflo 002/005/007 Saniplus Toilet with...
Sanipro continuously runs,however, not pumping waste away and waste water has filled toilet bowl. Any suggestions
There can be a blockage somewhere in the discharge pipe, the blade or impeller. Also the short discharge pipe or long elbow inside the pump casing may be split open or not attached properly and waste water is just cycling inside the pump casing. Worst case scenario could be a bad capacitor, the capacitor spins the blade and impeller, it that goes bad the unit will just hum and not pump any waste out until is replaced. You can also order parts through Saniflo if needed.
Dec 23, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo permanently on,
If the blade and impeller spin freely by hand after removing the obstruction but does not pump out the waste after assembling the unit back together, then could be a bad capacitor, since the capacitor spins the blade and impeller. If the capacitor goes bad then it will just make a humming noise and not pump the waste out.
May 20, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflo sanibest continually running , noisy ...
The float switch will be the problem.
We do not replace the switch, just change the unit as labour to strip and replace switch makes it un economical.
Jan 28, 2010 | Saniflo Sanibest macerator with multiple...
Our saniflo is suddenly making a continuous grumbling noise and no water is clearing. We are pretty sure nothing has been put down it as we are all v careful. It is very cold here and has been for weeks. A...
It keeps making noise becasue the pump is still trying to get rid of the water inside.
it can't get rid of the water most likely because their is a blockage in the waste water pipe.
if possible follow where the waste pipe runs to. if it goes in to a loft or somewhere else VERY COLD there is a good chance that it has frozen somewhere along the pipe.
If you are tying to pump the toilet waste vertically (upwards) then as soon as you turn the power off to the saniflo, the waste will fall back down and in to the toilet - or over the top in your case, sorry!
You might want to accept the inevitable and get a bucket and start removing the waste water from the bowl. Make sure that you have rubber gloves and I suggest goggles and something protecting your mouth - in case you get splashed.
Easiest solution, is to remove the excess waste water, turn off the saniflo, pour some bleach in to the toilet bowl, then cover the bown securley with cling film to keep the rank smell at bay.
Other wise, start tring to follopw the waste water pipe and warm it up, either by directly or indirectly (warm air gun) or by warming the area around it.
Personall;y i am using the easy option. the cold werather won't last forever, but can you use a toilet elsewhere in the meantime.
In the meantime, Saniflo claim about 15 years as the lifespan, but i have never know a saniflo to make it past 3! they are not ideal, but may be your only option.
consider whether you could get a proper toilet waste pipe put in, as it WILL save money in the long run...
Jan 07, 2010 | Saniflo & Saniplus& Macerator Pump
Continually pumps
Dec 19, 2009 | Saniflo & Saniplus& Macerator Pump
Pump makes humming noise, but does not flush.
hi sounds to me that it is blocked these pumps are for waste only not paper etc
Nov 16, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
