Question about DCS 36-6-1 Gas Kitchen Range
I have a old DCS 36-6-1 Natural Gas stove. The oven heats about 300 to 400 degrees higher than it should. Can't find a repair place that can find parts or know whats wrong. HELP
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Don't know where you are ( which country) if Australia I may be able to help . Let me know.
Posted on May 08, 2014
  • 161 Answers
SOURCE: oven in DCS gas range doew not turn on
Well some of the older ones have a unit that is sorta like a pilot light which keeps you safe by not letting out gas before it ignites so as to not blow up. This macanism is probably bad. I use to replace them on Tappan ovens. They would last a couple of years and then would go out and to replace them then was about $80.00. Easy to do. They are usualy located inside the oven somewhere and look like a glass eye on one end with a small 1/4 inch gas line connecting to the other end.
Posted on Aug 07, 2007
  • 409 Answers
SOURCE: gas stove DCS
sounds like the thermal fuse may have gone on it.
is it just the stove or does the cooktop work funny too?
a technician shouldn't cost you more than $80.00 to diagnose. part is farily inexpensive too + labour to install.
Posted on Sep 13, 2008
SOURCE: DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Posted on Aug 10, 2009
SOURCE: I'm looking for jet holder main(natural gas) p/n
Thanks for the offer, all I need is the parts to fix the stove, I know the problem and searching the replacement parts online.
Posted on Jan 07, 2010
heatman101
  • 43501 Answers
SOURCE: Oven slow to heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 14, 2010
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
Oven needs to be calibrated....it heats approximately 100 degrees below where it should
Not familiar with the brand of course but if your model has an Eaton oven control like this one for Viking Page 23 their is an adjustment screw for calibrating the oven temps. Other controls use an adjustment inside the shaft of the oven control itself.
Go to partstown.com and look up the service manual and calibration steps for your stove.
Apr 19, 2011 | DCS 36-6-1 Gas Kitchen Range
I have a natural gas hookup and my grill takes a long time to heaat up (15 minutes) and max degrees is 350 - 375. I found dust in the connection hose blew ut out. Also took grill apart and cleaned...
Unfortunately, that's the way it does on Natural Gas, in an outdoor environment. The reason being, Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Of course, on the plus side, you don't have to get tanks refilled. With that said, the thermometer on the grill may be faulty.
To test this theory, buy an inexpensive oven thermometer (the kind that can be placed on an oven rack) and place inside the grill, when you're preheating it with the lid closed. Once you grill thermometer reaches 350 degrees, open the grill hood and compare it the two temperature readings. If the oven thermometer is reading significantly higher, then you no the grill thermometer is faulty.
Hope this helps you get back up to temperature.
Mar 02, 2011 | Weber SPIRIT E-210 (NG)
Oven will not work
With a gas range, I wouldn't fool with it. Get a service man out there now! Gas stoves are great untill they malfuntion and need a qualified service person to check it out. It's cheep insurance if there is a gas leek causing the problem. The alternitive-------!
May 21, 2009 | Kitchen Ranges
Hi, we have a dcs 366 gas range. the pilot light for the oven went out and we can't seem to locate the pilot to re-light. the manual doesn't really go into detail for the oven...only the stove top. is this...
You don't give the model number of your DCS range, but it probably doesn't have a pilot light.
More likely it uses and electronic igniter. Internet search on "gas oven ignitor". I think this
might help you with your problem.
Mar 15, 2009 | DCS Kitchen Ranges
DCS 36-6-1 Gas Kitchen Range Logo
171 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
paulcarew
Sal DeAngelo
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
