Question about Harman Kardon AVR 130 Receiver
Can AVR135 biamp - Harman Kardon AVR 130 Receiver
    Champion:
    New Friend:
  • 231 Answers
Why on Earth would you want to? Spend the money on some LPs or CDs.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000073294.pdf
Posted on Apr 20, 2014
Manual for biamp series 24 mixing console
https://www.manualslib.com/manual/940051/Biamp-24-Series.html
May 14, 2017 | Music
BiAmp 24 series mixer - trying to put together a connector cable from PS24/28 power supply to 24 channel mixer. I have pinout info on power supply end but not mixer end. Anyone have schematic info?
The mixer end is a mirror of the power supply end. Example. If the + pin is at 11 o'clock on the power supply end, the mixer end will have the + at the 2 o'clock position. The same goes for the other pin locations
May 13, 2017 | Power Computers & Internet
I setup my Harman kardon AVR135 after 4 years not using it and it worked the first time. But then it doesn't respond to the remote nor does the buttons on the console work properly. Any solutions?
First thing I would do is change the batteries in the remote for fresh ones. If you haven't used it for 4 years the batteries must be a lot older. Not sure why the buttons wouldn't work. After the unit has been plugged in for say 24 hours, I would pull the wall plug and try again. There may be internal memory batteries that need to be recharged and reset.
Oct 27, 2015 | Harman Kardon Audio Players & Recorders
Part 2 My subs are the ones that are making the noise it only does this wen I hook up the y adaptor to the sonic cabinet wen I plug it in to hi biamp my subs work fine but the cabinet still does nothing...
Make another video showing your connections on your amplifier I've hooked this set up before so I can understand partly what your saying, are your filters correct?
Mar 27, 2013 | Audio Players & Recorders
How do i biamp these speakers they have a biamp plug in the rear do i need a special cable to do this
The two input jacks are parallel connected, to allow you to chain extra speakers together. There is no facility on this model to bypass the crossover and bi-amplify horn and driver separately. Nor should you need to. Just make sure you use a power amp rated for at least 400 watts per channel at 8 ohms.
Sep 23, 2011 | Peavey PV 115 Speaker PA Passive
I OWN A NAD M 25 ---7 CHANNEL AMPLIFIER. I AM USING 4 CHANNELS TO BIAMP MY SPEAKERS. ONE OF THE UNUSED CHANNEL IS SHOWING A RED PROTECTION LIGHT.THE BIAMPED CHANNELS ALL WORK FINE ...I HAVE CHECKED ALL...
The manual would suggest you have a problem.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-M25-Amps-manual/id/8043ci561/t/2/
Try unplugging all of the speakers and see if that amp is still distressed. If it looks clean and happy start adding speakers until it returns (or not).
Jul 03, 2011 | NAD M25 Amplifier
I broke the passive biamp switch off the back of my 1800 x subwoofer. i have been using it like that but now its not working. can i buy just the back panel with the switch on it or do i have to get another...
You can get replacement switches. The internals of the switch probably broke and no longer connect causing the speaker to not work. FullCompass.com is the Behringer parts distributor but they may direct you to first call Behringer to get a part number for the item.
Feb 14, 2011 | Behringer EUROLIVE Professional B1800X Pro...
I have a rotel rb970bx. I have 2 and ran them in mono driving a speaker each. I tried to biamp the speakers with one amp driving the tweeters and one the woofers. This worked for about 4 minutes at 1/4...
hi
it sound to me that when you biamp and driving speaker and woofer , you are over loading the fuses , suggestions
uprate the fuses till they stop blowing
Dec 21, 2017 | Rotel Audio Players & Recorders
Harman Kardon AVR 135 6.1....AUDIO DELAY???
This model does have a delay function. Programming is on page 19 of the user manual. Go to http://www.harmankardon.com/product_support/interstitial.aspx?sJump=ps&Region=USA&Country=US&Language=ENG select all products, AVR135, and get the owner's guide. If you have trouble with the link, then go to the Harmon Kardon site, and make your way to the support portal and then select all products.
Nov 26, 2008 | Harman Kardon AVR 135 Receiver
Krell sav250a power amp
hey tong
This confirms you have an earth loop problem then. Has it just started, or has it been this way from when you first set up the gear?
Jul 04, 2008 | Audio Players & Recorders
Harman Kardon AVR 130 Receiver Logo
48 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
