Question about Singer 7462 Sewing Machine
Will not sew, lights flash on stitch selection panel
When first turned on, cycles and then when I start to sew, it'll do one or two stitches and then all lights begin flashing and beeping. Checked button hole lever and tried pressing reverse button (lots of beeping) to reset...nothing. Any ideas?
2 Suggested Answers
SOURCE: Button Hole Beeping on 7462
Yes frustrating issue this one. I discovered that you need to pull down the retractable button hole guide found behind the needle threader (not visible when you are sitting at the machine).
Hope this helps, happy sewing!!!
Posted on Oct 26, 2008
I dont have the instruction manual and i cant figure out how to do a zig zag stitch? Help
You don't say the make and model of sewing machine. But generally zig zag is achieved by selecting the zig zig stitch on the stitch selector, then setting stitch length to 2 and stitch,width to between 3 and 4, depending on the fabric. If its a very light weight fabric 4 the thread will pull in and tunnel the fabric so turn down to narrow the width of the stitch.
Mar 03, 2015 | Sewing Machines
Stitch selection control panel lights flash and beeping
is the bobbin lever back in it's original position? it could be a problem with the computer, here is a link for a free manual, just in case you don't have one
http://www.singerco.com/uploads/download/466_7462_efs.pdf
Apr 17, 2014 | Singer 7462 Sewing Machine
Singer Sewing Machine 7422 turns on, but will not stitch...
sounds like there something wrong with the computer part of the machine
it needs to be serviced
Feb 09, 2012 | Singer 7422
What setting do i use for working with silk on a brother xr52 don't have manual
You can download the manual for your machine from the Brother site, link is
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000061/xr52c65txl64526562ug01enesfr.pdf
There are lots of weights of silk fabric but I'll assume you are working with something soft and silky like a silk charmeusse or silk georgette.
You need to stitch seams with a straight stitch and use a new sharp needle size 70 or even 60. Change the needle every 4-6 sewing hours or if you hear squeaking or popping; throw away the blunt one.
Use a quality polyester thread like Guttermann, Mettler, or Metryosene. Start with stitch length on 2.5 and stitch width zero (straight stitch). The normal metal presser foot is probably best for this. If the fabric is see through you may wish to do french seams to encase the raw edges. This is where you sew wrong sides together, then turn and stitch right sides together, if you have never done this instructions are here http://sewing.about.com/od/techniques/ss/frenchseam.htm.
Also pay carefull attention to your bobbin winding, my tip for this is here
http://www.fixya.com/support/r10598580-winding_bobbin_correctly
as winding the bobbin smoothly and evenly is essential to quality stitched seams.
Always press every seam as you sew, dry iron, silk setting. Press each side of the seam, then press the seam allowances open, this sets the stitches into the fabric.
If you find that the seam is pulling up you can try loosing off the top tension by a half number (turn it down to loosen) and shorten up the stitch length a fraction to 2.2 or so. But you don't want it too small as if you need to "unsew" ie unpick, you'll never see the thread.
Use a lighweight interfacing if the pattern requires it; I'd use a fusible but very lightweight such as Pellon Featherweight.
Happy sewing.
Sep 02, 2011 | Brother VX808 Sewing machine
I am trying to alter a swim suit, and I need to use a stretch stitch. Does the Singer model 2638 have this feature?
Here is the stitch selection page from your manual
I would suggest that you use the stitch called "elastic overlock" using a stretch needle, you need a ball point tip on the needle to press between the elastane fibres in lycra. A stretch needle is blue, coated with a substance that makes it easier to stitch these types of man made stretch fibres, often size 75. If you can't get one of those, then use a ball point needle, size 70 or 80.
You need a stitch with forwards and backwards movement so that the stitching doesn't break under stress. Your machine also has a stretch straight stitch and this would be a forwards and backwards straight stitch so this will work too but can look a bit 'heavy' sometimes. But even triple zig zag narrowed down will work often.
If you are sewing leg edges with lycra, shop made garments will have clear swimsuit elastic sewn into the seam using a coverstitch overlocker, you'll never get as good a result with a regular sewing machine but you can get a reasonable finish with practice. This elastic is available to buy, you might want to use the overlock stitch to attach it to the fabric edge, stretching as you go, then turn it to the inside and use a stretch twin needle and straight stitch to top stitch from the outside, stretching the fabric as you sew.
Trust this helps you a little, 4 thumbs up if so. :-)
Jul 13, 2011 | Singer 2638 Mechanical Sewing Machine
Model # 64 60 viking sewing machine looking for manual for sewing leather or canvas which cam to use in it
As to your question about leather, the 6460 has a special stitch for sewing leather. Select Colormatic cam C and install in the cam hole at the back of the machine. To remove/add a cam turn the upper left hand dial on the front of the machine to the small dot. This disengages the cam. Gently remove the cam by pulling straight out from the back of the machine. Install cam C straight in, ever so slightly twisting it back and forth into the hole to find the sweet spot. You'll hear a click when it's all the way in.
To use Viking's leather stitch, turn the upper left dial to the color yellow. (Note: The slash line on the upper left dial is a stop. You can't turn past that point. Go in the other direction to get to the icon or color you want.) Turn the upper right and bottom right dial to yellow also. The upper left dial is what selects the particular stitch on the cam, the leather stitch in this case. The upper right dial selects stitch length, and the lower right dial selects stitch width. You can move the right dials within the color range. Experiment on a scrap of cloth to get the stitch size the way you want it. The leather stitch looks like a straight stitch with a block style edging to the right of the straight stitch. This is supposed to give a stronger stitch to the leather rather than a straight stitch by itself.
If you don't have the manual for your machine: Select which of the eight cams you want to use. All the cams are removed/installed by turning the upper left dial on machine front to the small dot. At the rear of the machine, pull/insert cam straight in or out and twist slightly as you push in or remove to find the sweet spot. Move the dial away from the small dot to lock the cam in.
Turn upper left dial to stitch type you want and match the other dials to that same color. Upper right controls stitch length, lower right controls width. Bobbin tension is controlled by the dial at front left of the machine, above the needle.
Cams A-C are the workhorse cams and the rest are embroidery stitches.Straight stitch, button and stitched zig-zag will work on any cam. These stitches do not rely on matching a color code. To use those three: To select straight stitch, on the upper left dial, choose the icon that looks like a buttonhole with a zig that trails off to the right. Select stitch length on upper right dial and turn the lower right dial to zero, going by number rather than color.
To select stitched zig zag, turn upper left dial to the broken zig zag icon (to the right of the straight stitch icon). Select stitch length and width.
To move the needle to the side for buttonhole stitching or other times when you want the needle off center, turn the upper left dial to the button icon. If stitching a button hole, set stitch length to zero and lower right dial to desired stitch width. Push in the small white button that's beneath the lower right dial in order to prevent the feed dogs from moving the fabric forward. Pushing that button in is also handy for putting cloth under the foot before sewing as it prevents snagging and is used for tacking.
Jun 06, 2011 | Husqvarna Sewing Machines
My Brother LS-2125 does not stitch forward - only in reverse.
What stitch selection have you made, anything to do with the buttonhole? If, so make sure that you let it go through the cycle then, pick a straight stitch pattern with a longer stitch length. You can also go online to brother-usa.com and see if there are any other suggestions
Sep 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
I have a old Elna machine. The air electronic SU 390 B. I have lost the manual and am trying to do buttonholes on a dress. I have forgotten the sequence of nob adjustments to complete the process.
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Aug 26, 2010 | Elna 2007 Mechanical Sewing Machine
I have a necchi 4595, and well I cannot figure out the straight stitch....the dial doesn't show one?
It's just in the front panel, where the drawing of all the built in stitches are, it's the drawing number eleven from the left, you'll see a zig zag (red) and a straight stitch (black) Select A group of stitches (knob with the arrow) and then select the eleventh stitch (same knob but use the dial, look the manual) and then select zero on your stitch width dial. Hope that helps :)
Apr 23, 2009 | Necchi 4595 Mechanical Sewing Machine
Can't select stitches 11-21
To select stitches 11-21 you position the stitch length dial on the "SS" setting , and the pattern selecting dial on the desired stitch number.
Mar 08, 2008 | Brother XL-5700 Mechanical Sewing Machine
Singer 7462 Sewing Machine Logo
19 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
