Question about HP Elite L2201x - LED monitor - 21.5" LM917AAABA -
Want to connect 2012 Mac Mini to HP Elite L2201x
Is it possible to use this HP display port monitor with the current Mac Mini? What is the cheapest, most effective way?
4 Suggested Answers
joecomputer
  • 92 Answers
SOURCE: HP 2140 mini note does not recognize monitor.
Try pressing the Fn key and F2 key at the same time. Also make sure your tv is on the correct imput.
Posted on Jun 23, 2009
  • 3 Answers
SOURCE: HP Pavilion G60-120US NoteBook - External Display Problem
hmmm, f4 + function key should do the trick, you might have to press several times to scroll through modes. If that does do the trick, see if you can view bios with external connected on boot.
Posted on May 12, 2010
  • 17 Answers
SOURCE: elitebook 8470p not displaying to remote monitor with KVM
Is the laptop actually detecting an output when the KVM is plugged in? Try forcing output with Windows + P (Vista/7) or a function key (not sure what it is for the 8470p).
Posted on Apr 10, 2013
I bought an old Mac Mini Intel Core 2 Duo, 2 GB Hard Drive, OS X Yosemite, with serial # C07CS2TPDD6H. What adapter cord could I use to connect it to an iBox C1752, TFT LCD Monitor?
That Mac has a hdmi port and a mini display port. The monitor has a saga port. So ether a hdmi-svga. Or miniDisplay port-svga.
Any usb keyboard will work. So any Mac keyboard newer than 12 years should be good, and newer pic keyboards will work. Beware of older keyboards that have round plugs. On macs these were ADB ports. On PC's, they used PS2 (ADB, ps2, usb are all different, you want the flat rectangle USB)
U.S. pc keyboards also have two modifier keys wired different than the U.S. Mac keyboards, but this can be adjusted in the system preferences. Can't say for non U.S. KBs. They are the windows/alt keys. Vs Opt/Command keys. That is, if you are soused to using a Mac, the key that is closest to the spacebar (command key) is applied by the second key over rather than the first. Again, this can be modified in the Sys Prefs.
Jun 06, 2015 | Apple Mac Mini Desktop
How to planar touch screen to mac mini
Try downloading and installing the latest drivers for your particular model.
Drivers and Software
Oct 15, 2014 | Computers & Internet
How to connect macbook pro to ASUS MX279H monitor?
Your monitor should have 2x HDMI and a VGA port and MacPro has Thunderbolt or a Mini Display Port. There is no direct way to connect your macbook to your current monitor. You'll need a Mini Display to VGA adapter. You can find this on ebay. Hope it helps.
May 30, 2014 | Computers & Internet
Acer display drivers for mac-mini ?
hi, may I know how are you connecting the mac-mini to the display? if it is VGA, that is the highest resolution it can go. But if you're connecting it via HDMI or DVI-D, it can reach its highest resolution for the monitor. did have similar problem last time, but solved by using HDMI-DVI cable.
Jan 01, 2014 | Acer AL1917W LCD Monitor
Need to connect hp pavilion vf15 monitor to mac computer
First of all, before you look which one to buy, you need to find out which Video Port does you Mac has, i.e. VGA or DVI or Mini DVI or HDMI. Once it's confirmed, you have to find out the same with your monitor, so that you can buy the appropriate cable.
Pictures Below:
1. VGA
2. DVI
3. Mini DVI
4. HDMI
Good Luck.
Thanks for using FixYa.
Nov 02, 2012 | HP VF15 15 in.
Hp elite l2201x monitor won't work
I am experiencing the same issue. My monitor will not come out of sleep mode. HP informed me to purchase another power cord, but it yielded the same results. Any solutions????? Thanks
May 28, 2012 | Dell Computers & Internet
Connect 26pf5520d to a mac mini
Try to connect your Mac Mini to another DVI-capable monitor. May be your DVI out on Mini doesn't function at all
Aug 29, 2017 | Computers & Internet
OK, mini display port to VGA adapter-is the VGA cord the one that goes into the port labeled RGB and audio on the back of the Samsung? Sorry to be a dummy but Samsung monitor is 6 years old and has always...
An RGB port is for a component cable not a VGA cable. A VGA cable, similar to a component cable, only carries a video signal but is a 15 pin cable that nearly all monitors and HDTVs support. Most laptops have a VGA out port.
You should be able to connect your laptop to almost any monitor (not sure about your Samsung) with a male to male VGA cable.
Good luck and thanks for using FixYa.
Mar 09, 2011 | Computers & Internet
Re: Video Card TOAST???
Given the environment and issue, sometimes a solid way to process of eliminate, is to add a display to the laptop. Laptop videocards are embedded/integrated in the motherboard/logic board. So, your Mac has not been specified. This provides for many variables. I'll keep this simple but thorough.
First, monitors. Unless you have a great hook up from the next level, you will most likely have a:
  • VGA monitor. if the monitor has the cable attached to it, and not via connectors, but actually runs into the back of the monitor, odds are it's VGA.
  • DVI monitor. Most DVI monitors do have atleast a VGA input.
DVI is digital and far more robust, but the cables and connectors might not outweight what you gain from it if you're not using it to, watch movies, edit video and or edit high resolution photo. If you already own a DVI monitor, then I feel the cable ( if 3-6 ft) and the "possible adapter"
($20) is well worth enjoying what you've paid for.
The "possible adapter" is a white (made by Apple for Apple) proprietary adapter that is required to connect any Macintosh laptop that IS NOT of the ALUMINUM POWERBOOK or MAC BOOK or MACBOOK PRO series, to a monitor. All recent Macintosh laptops ship with 1 form or another of a video adapter.
  • Mini VGA to VGA
  • Mini DVI to DVI
If you need to cross over VGA to DVI and DVI to VGA adapters are available, but you will then have to make note of the gender of the connecting port or cable end.
So, if you own:
  • A white G3/G4 IBook, the video output connection is MINI VGA.
  • Older Titanium Powerbooks, pre 667Mhz have a standard VGA on the rear.
  • 667Mhz-1Ghz Titanium Powerbook, all Aluminum Powerbooks, and ALL Macbook Pros have an on-board DVI female ports. In the rear for TIbooks and Rear right side on Aluminumbooks and MBPs.
  • All Macbooks utilize mini DVI.
SO, ON WITH THE QUESTION PLEASE!!
Connect a display to your laptop. If you get a picture, than more than likely, any component from the cable that runs from the motherboard, up into the display panel, to the inside of the display, is faulty.
If you do not get a picture, than its highly possible the video card or GPU has failed.
If you could specify your model, I can further assist you.
Sep 02, 2008 | Apple iBook G3 Mac Notebook
HP Elite L2201x - LED monitor - 21.5" LM917AAABA - Logo
44 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
