Question about Murray Garden
Fire all wire burned up . if i jump start what needs to be wired up
1990 38inch 13hp garden genral lawn tracter all wires burned i disconeced seatswitch cluch switch blade switch runs but only for 5min than sutsoff
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Murray Expert
  • 216 Answers
When the mower is running, remove the fuel cap to see if there is a venting issue. You may also have a fuel delivery issue.
Posted on Feb 05, 2016
SOURCE: Ignition switch
A kubota dealer should be able to print one for you or go on line with model # etc and you should be able to bring one up yourself. I hope this helps. donnyb60
Posted on Mar 19, 2009
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
kamakani
  • 104 Answers
SOURCE: Murray Lawn Tractor Model 42576x92A will not start...no spark?
http://www.partsandservice.com/bin/ipl.cgi
I found a wiring diagram that I hope helps you out.
Posted on Jul 29, 2009
  • 40 Answers
SOURCE: wiring diagram turns over but won't start
Product manuals with diagrams and troubleshooting guides can be downloaded from manufacturers' websites.
Posted on Nov 01, 2009
wireguy212
  • 1627 Answers
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
Posted on Apr 18, 2010
How do I fix burned wires on Craftsman LT 2000 w/17hp Kohler burned wires. Need wire color diagram.
http://parts.sears.com/partsdirect/index.action
get the manual, it has a wiring diagram. You will probably be able to buy a new wire harness as well.
Aug 30, 2014 | Craftsman Garden
Need wiring diagram for 2002 cub cadet model(2000) 13hp lawn tractor
if wont start look at fuse behind dash and the relay
Aug 18, 2014 | Garden
LAWN TRACTER MODEL JOHN DEERE LA 140 ,TURNS OVER BUT WILL START
I bet you ment will not start. First check for spark at the spark plug. An easy way to do this is to pull out the spark plug, connect it to plug wire and with the threaded end touching bare metal (do not hold it with your hand)on the engine see if you can see a spark jump across the gap of the plug. Also check if the fuel shut off valve(if it has one it will be between the gas tank and carb) is open.
Sep 01, 2013 | Garden
I have a 13hp briggs and stratton model # 28m707 that has one extra wire that i can not idenify. ineed some help rewiring it.
Go to www.searspartsdirect.com . Enter your model number, get the owners manual download and inside there will be a page with the wiring schematic for it .Good luck!
Aug 23, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Engine not starting
It sounds like no electricity is making it to the starter. Several things may be wrong. Check to see if the fuse has blown. It should be behind the dash. Your starter switch may be bad. You can unhook it and use a jump wire from the positive side of the battery to the wire connection on the starter to see if it will turn over. The switch under the seat that detects someones sitting on the mower could be bad. You can unhook it and place a piece of wire in the connections to make a complete circuit then try to start it.
Apr 26, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blowing a 25 amp fuse, will not start
have you checked all the wiring. A wire may have burned up and is arking and causing the fuse to blow. That has happend to me. hope this helps.
Apr 21, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
CRAFTMAN 20 HPmower WILL NOT START. I CAN JUMP THE
Hi, W/D here.
Try cleaning all of the contacts at the solenoid, and the wires that attach to it. That will probably get you going.
--W/D--
Aug 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dog ate my wiring on my troy-bilt lawn tracter bronco 18.5 briggs,I need a wiring diagram
Hi you should be able to look it up on this site its called pats small engines
Jul 12, 2009 | Garden
Garden Logo
23 people viewed this question
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
