Question about Ridgid R4510 10-inch Portable Table Saw With Stand
Bad armature bearing retaining plate nuts spot welded to plate how do you remove nuts without damageing studs
Disregard previous answer. You don't remove the nuts. The plate is held by two machine screws that screw into nut from below. One of the screws will be buried in the grease inside the gearhouse.
Posted on Jul 21, 2014
    Sergeant:
  • 462 Answers
Try chisel or nut splitter
Posted on Apr 21, 2014
Could you please help me repair my Makita angle grinder?
The problem will be removing the inner bearing ring from the armature. You will need to source a suitable bearing puller from a hire shop or possibly get one made.
It will look like a tube with a slot in the side.
The bottom will have a plate welded on it, also with a slot.
The slots allow the puller to pass over the armature enabling the puller to centralise over the shaft,
The top of the puller will have a plate welded on with a hole through the centre. On this plate is welded a nut.
A bolt will pass through the nut and contact the armature shaft.
with the puller centrally located over the armature and the bottom plate in contact with the bearing the bolt is tightened to pull the bearing up.
I have made a puller similar to this from an old spark plug socket (good quality from as socket set) but it may not be long enough for your application.
Aug 31, 2017 | Saws
Bad bearing on makita ga4530. How do I get to the upper bearing?
You have to take the gear housing apart, remove the hex-nut and spiral bevel gear on the end of the armature so you can pull the armature out of the bearing. Then remove the retaining ring, o-ring and bad bearing for replacement.
Oct 10, 2013 | Makita GA4530 4 1/2" Grinder
How to change wheel bearings on jaguar xj6 front 1996
Disconnect the vehicle battery ground lead.
Support the vehicle at the front and remove the appropriate wheel.
Remove brake caliper and disc assemblies see SRO 70 10
Note- Do not allow the caliper to hang by either harness or
flexible hose.
Pry off the hub grease cap
Remove and discard cotter pin
pull off castellated nut retainer
Remove the hub nut and bearing washer.
Carefully remove the hub assembly from the stub axle.
Pry the original seal from the spigot and discard.
remove the bearings and using a drift punch knock out the bearing cups.
Remove all traces of grease and dirt from the stub axle and back plate.
Note: the backing plate may be used to pull the inner bearing and seal if they stay on the stub shaft.
Press in the new bearing cups using a socket or other tool of the correct size to prevent damaging the new bearing cup or hub.
Note: Do not use bearing to press in the cup.
Pack the annular gaps of the oil seal lips with grease.
Wash the hub assembly thoroughly.
Ensure that the hub inner seal diameter is free of debris or damage and is lightly lubricated prior to assembly.
Only replace complete bearings, never cup or race in isolation.
Pack each race with approximately 4 ml of grease and position the inner race onto the stub axle.
Apply a smear of grease to hub inner surfaces and bearing cups. Assemble the hub to the stub axle followed by outer race, bearing washer and hub nut.
It is not necessary to fill the hub cavity with grease, merely protect from corrosion with a coat of lubricant. Seat the bearings by slightly tightening the hub nut whilst rotating the hub. Do not apply load without rotation.
Adjust End float. Set a Dial Test Indicator and adjust the hub nut to achieve the correct end float.
.001-.003"
As the adjustment is made, continually load the hub axially in both directions.
Without disturbing the end float setting, fit the castellated
nut retainer so that it aligns with both hub nut and stub axle drilling.
Secure nut retainer using a new cotter pin.
Reassemble brake rotor and caliper. Bolts MUST be tightened to specification
operation of the braking system verified.
Reassemble wheel
Dec 25, 2010 | 1996 Jaguar Xj Series
Need to change front wheel bearing
Hub and Bearing Removal & Installation NOTE: The removal and installation of the wheel bearing and hub from the steering knuckle is only to be done with the steering knuckle removed from the vehicle
To Remove:
  1. Remove the steering knuckle and hub and bearing assembly.
  2. Remove a wheel lug stud from the hub flange using a C-clamp and Adapter Tool 4150A or equivalent.
  3. Rotate the hub to align the removed lug stud with the notch in the bearing retainer plate. Use a proper C-clamp and adapter tool to press out one of the lug studs 7922eg64.gif
  4. Rotate the hub so the stud hole is facing away from the brake caliper's lower rail on the steering knuckle.
  5. Install ½ of a Bearing Splitter Tool 1130 or equivalent between the hub and the bearing retainer plate. The threaded hole in this ½ is to be aligned with the caliper rail on the steering knuckle.
  6. Install the remaining pieces of the bearing splitter on the steering knuckle. Hand-tighten the nuts to hold the splitter in place on the knuckle. Proper installation of the bearing splitter 7922eg66.gif
  7. When the bearing splitter is installed, be sure the 3 bolts attaching the bearing retainer plate to the knuckle are contacting the bearing splitter. The bearing retainer plate should not support the knuckle or contact the splitter.
  8. Place the steering knuckle in a hydraulic press, supported by the bearing splitter. Properly support the steering knuckle for hub and bearing removal 7922eg67.gif
  9. Position a driver on the small end of the hub. Using the press, remove the hub from the wheel bearing. The outer bearing race will come out of the wheel bearing when the hub is pressed out of the bearing.
  10. Remove the bearing splitter tool from the knuckle.
  11. Place the knuckle in a press supported by the press block. The blocks must not obstruct the bore in the steering knuckle so the wheel bearing can be pressed out of the knuckle. Place a driver on the outer race of the wheel bearing, and then press the bearing out of the knuckle.
  12. Install the bearing splitter on the hub. The splitter is to be installed on the hub so it is between the flange of the hub and the bearing race on the hub. Place the hub, bearing race and splitter in a press. Use a driver to press the hub out of the bearing race.
To Install:
  1. Use clean, dry cloth to wipe and grease or dirt from the bore of the steering knuckle.
  2. Clean the rust preventative from the replacement wheel bearing using a clean, dry towel.
  3. Place the new wheel bearing into the bore of the steering knuckle. Be sure the bearing is placed squarely into the bore. Place the knuckle in a press with a receiver tool, C-4698-2 or equivalent supporting the steering knuckle. Place a driver tool on the outer race of the wheel bearing. Press the wheel bearing into the steering knuckle until it is fully bottomed in the bore of the steering knuckle. NOTE: Only the original or original equipment replacement bolts should be used to mounting the bearing retainer to the knuckle. If a bolt requires replacement when installing the bearing retainer plate, be sure to get the proper type of replacement.
  4. Install the bearing retainer plate on the steering knuckle. Install the 3 bearing retainer mounting bolts. Torque the bolts to 21 ft-lbs (28 Nm).
  5. Install the removed wheel lug stud into the hub flange.
  6. Place the hub with the lug stud installed, in a press supported by Adapter Tool C-4698-1 or equivalent. Press the wheel lug stud into the hub flange until it is fully seated against the back side on the hub flange.
  7. Place the steering knuckle with the wheel bearing installed, in a press with special Receiver Tool MB-990799 or equivalent supporting the inner race of the wheel bearing. Place the hub in the wheel bearing, making sure it is square with the bearing. Press the hub into the wheel bearing until it is fully bottomed in the wheel bearing.
  8. Install the steering knuckle and the wheel.
  9. Check and/or adjust the front alignment.
Oct 15, 2010 | 2004 Chrysler PT Cruiser
Front wheel stud replacement for a 2006 Hyundai Sonata GL.
grind a flat spot on the round head of the new stud this should give enough clearance to install it. don't pull the hub this will damage the bearing.
Oct 24, 2009 | 2006 Hyundai Sonata
I have a bad wheel bearing how do I replace it
Hub and Bearing Assembly
ani_caut.gif CAUTION: Do not begin this removal procedure unless the following parts are available:
  • A new front axle wheel hub retainer (3B477) (Step 1).
  • A new inboard halfshaft joint stub shaft circlip.
Once removed, these parts must not be reused during assembly. Their torque holding ability or retention capability is diminished during removal.
Removal
  1. Turn ignition switch to the OFF position and place the steering column in the unlock position.
  1. ani_caut.gif CAUTION: Discard the front axle wheel hub retainer. It is a torque prevailing design and cannot be reused. If loosened, the retainer must be removed and a new one installed.
    Remove and discard front axle wheel hub retainer (3B477).
  1. Raise vehicle on hoist.
  1. NOTE: Make sure steering column is in the unlocked position, and do not use a hammer to separate tie rod end (3A130) from the front wheel knuckle (3K185) . Use extreme care not to damage boot seal.
    Remove cotter pin from tie rod end stud and remove slotted nut. Discard cotter pin and nut.
  1. Using Tie Rod End Remover 211-001 (TOOL-3290-D) or equivalent and Tie Rod End Remover Adapter 211-087 (T81P-3504-W), remove tie rod end from front wheel knuckle.
  1. ani_caut.gif CAUTION: Use extreme care not to damage boot seal. Do not use power tools to remove the nut, or bearing and seal damage will result. Loosen the nut first, then remove nut from stud using the hex hold feature.
    For SHO vehicles, remove vinyl cover from upper link stud.
    Remove stabilizer bar link (5K484) from front shock absorber (18124) .
  1. Remove disc brake caliper (2B120) and support with wire to obtain working space. Do not allow disc brake caliper to separate from the front disc brake caliper anchor plate (2B292) to prevent contamination of the disc brake guide pin journals. Do not allow disc brake caliper to hang from front brake hose (2078) . Remove front disc brake rotor (1125) . Remove front disc brake rotor from wheel hub (1104) by pulling it off the lug bolt (1107). If front disc brake rotor is difficult to remove from front wheel knuckle , strike front disc brake rotor sharply between lug bolt with a rubber or plastic hammer.
    If front disc brake rotor will not pull off, apply Rust Penetrant and Inhibitor D7AZ-19A501-AA or equivalent meeting Ford specification ESR-M99C56-A to inboard and outboard rotor/hub mating surfaces. Install 3-Jaw Puller 205-D027 (D80L-1013-A) or equivalent and remove front disc brake rotor by pulling on front disc brake rotor outside diameter and pushing on hub center. If excessive force is required for removal, check front disc brake rotor for lateral runout prior to installation. Refer to Section 06-00.
  1. Remove anti-lock brake sensor mounting bolt and front brake anti-lock sensor (2C204) .
  1. Remove and discard lower ball joint nut. Using Remover Adapter 211-211 (T96P-3010-A1), separate lower ball joint from front suspension lower arm (3078) .
  1. Using Rotunda Spring Compressor 014-00781 or equivalent, compress front coil spring (5310) until lower ball joint clears front suspension lower arm .
  1. Using Front Hub Remover/Replacer 204-069 (T81P-1104-C), Two Stud Adapter 205-237 (T86P-1104-A1), Metric Hub Remover Adapter 204-085 (T83P-1104-BH) and Front Hub Installer 204-067 (T81P-1104-A), press front wheel driveshaft joint (3B414) from wheel hub . Wire front wheel driveshaft joint to body to maintain a level position.
    Item Part Number Description 1 204-085 (T83P-1104-BH) Metric Hub Remover Adapter 2 204-067 (T81P-1104-A) Front Hub Replacer 3 — Turn Wrench Counterclockwise 4 — Hold Wrench Stationary While Turning Other Wrench 5 204-069 (T81P-1104-C) Front Hub Remover/Replacer 6 204-067 (T81P-1104-A)1 Two Stud Adapter A — Make Sure Metric Hub Remover Adapter 204-085 (T83P-1104-BH) is Fully Threaded onto 1107 and is Positioned Opposite the Two Stud Adapter 205-237 (T86P-1104-A1)
  1. Remove and discard three hub and bearing retainer bolts from front wheel knuckle .
  1. NOTE: Wheel hub is not pressed into front wheel knuckle . Do not use slide hammer to remove a stuck wheel hub . Do not strike back of inner bearing race. Use of these methods will damage bearing internal parts.
    NOTE: If bearing carrier is corroded to front wheel knuckle , apply Rust Penetrant and Inhibitor D7AZ-19A501-AA or equivalent meeting Ford specification ESR-M99C56-A to the inboard and outboard wheel hub/knuckle mating surface and allow to soak.
    Remove wheel hub from front wheel knuckle .
Installation
  1. NOTE: If wheel hub is damaged or if any end play is detectable, replace wheel hub . End play is not adjustable. If wheel hub is disassembled, the assembly must be replaced.
    Remove all foreign material from knuckle bearing bore for correct seating of new wheel hub.
  1. Lightly lubricate mating surfaces of bearing corner and front wheel knuckle.
  1. ani_caut.gif CAUTION: Knuckle bore must be clean enough to allow wheel hub to be completely seated by hand. Do not press or draw wheel hub into place.
    Position wheel hub in front wheel knuckle . Install three new hub and bearing retaining bolts. Tighten to 83-107 Nm (61-78 lb-ft).
  1. Push front wheel driveshaft joint into wheel hub . Hand start front wheel hub retainer.
  1. Slowly release Rotunda Spring Compressor 014-00781 or equivalent while guiding lower ball joint into front suspension lower arm .
  1. Install new lower ball joint nut. Tighten to 68-92 Nm (50-67 lb-ft).
  1. Install tie rod end into front wheel knuckle . Install new slotted nut and tighten to 47-63 Nm (35-46 lb-ft). If necessary advance nut to install a new cotter pin.
  1. ani_caut.gif CAUTION: Use extreme care not to damage boot seal. Do not use power tools to tighten nut or bearing and seal damage will result. Install nut using hex hold feature to prevent the stud from rotating.
    Install stabilizer bar link to front shock absorber . Install stabilizer bar link nut. Tighten to 77-103 Nm (57-75 lb-ft). For SHO vehicles, install stud cover.
  1. NOTE: Remove rust from the rotor and hub mating surfaces with a medium abrasive pad.
    Install front disc brake rotor and disc brake caliper . Tighten caliper anchor bracket bolts to 88-118 Nm (65-87 lb-ft).
  1. ani_caut.gif CAUTION: The front axle wheel hub retainer must be tightened to specification immediately during installation. If the retainer is not tightened immediately, the nylon lock will set incorrectly, leading to incorrect torque readings and bearing failure. Any front wheel hub retainer that is not immediately tightened to specification or is loosened must be removed and a new retainer installed.
    Install front axle wheel hub retainer . Tighten to 230-275 Nm (170-203 lb-ft).
  1. Install wheel and tire. Tighten lug nuts (1012) to 115-142 Nm (85-104 lb-ft).
  1. Lower vehicle.
  1. Pump brake pedal prior to moving vehicle to position brake linings.
May 28, 2009 | 1999 Ford Taurus
Cant remove wheel hub
here is procedure
Section 04-01: Suspension and Wheel Hubs, Front 1996 Taurus, Sable Workshop Manual
REMOVAL AND INSTALLATION Wheel Hub Bolt Removal
  1. Remove wheel and tire assembly. Refer to Section 04-04 .
  1. Remove disc brake caliper (2B120), and front disc brake rotor (1125). Refer to Section 06-03 .
Brake Shoe and Lining Removal
  1. Remove brake master cylinder filler cap (2162). Check fluid level in brake master cylinder reservoir (2K478). Remove brake fluid until brake master cylinder reservoir is half full. Discard removed fluid.
  1. Raise vehicle on hoist. Refer to Section 00-02 .
  1. Remove wheel and tire assembly from front disc brake rotor mounting face. Use care to avoid damage or interference with disc brake caliper (2B120), front disc brake rotor shield (2K004) or front wheel knuckle (3K185).
  1. Remove rear brake pin retainers (2N386). ( I think it is a T 40 torx bit you need)
  1. NOTE: It is not necessary to disconnect hydraulic connections.
    Lift disc brake caliper from front disc brake caliper anchor plate (2B292) and front disc brake rotor (1125). Do not pry directly against metal caliper piston or damage will occur.
  1. Position disc brake caliper out of the way and support with wire to avoid damaging the disc brake caliper and front brake hose (2078).
  1. Remove outer brake shoe and lining (2001) assembly from front disc brake caliper anchor plate.
  1. Remove inner brake shoe and lining assembly.
  1. Position lug bolt (1107) to clear front wheel knuckle (3K185).
  1. Remove lug bolt from wheel hub (1104).
Installation
  1. Install lug bolt into wheel hub.
  1. Using a lug nut (1012), seat wheel hub bolt into wheel hub.
  1. Install front disc brake rotor and disc brake caliper. Refer to Section 06-03 .
  1. Install wheel and tire assembly. Tighten lug nut to 115-142Nm (85-104 lb-ft).
May 25, 2009 | 1996 Mercury Sable
Rear Axle Seal Replacement
remove rear tires, then remove brake calipers and rotors, then remove the 4 nuts (each side) that hold the axle shafts to the axle tube (located around the axle tube behind the backing plate) then using a slide hammer pull the axle shafts out, next using a die grinder and an air hammer get he retainer collar and the bearing off (without damaging the axle shaft) then remove the seal and the outer race which will still be in the housing. next put it all back together, make sure the plate with the studs is still on then slide the seal, bearing, then retainer on (all new parts) and using a press push them all the way back on. then is simple reassembly.
Apr 21, 2009 | 2004 Jeep Grand Cherokee
How do i access the back left brake lightbulb to change it? everything looks bolted down or glued in place or welded shut. i can remove some cables but thats about it from the looks of it. can anyone help?
First remove the 2 black plastic retainers holding the carpet in. Remove the carpet and underneath you will find 2 studs with plated nuts. Remove the nuts and remove the taillight assembly from the outside of the vehicle to access the bulbs
Apr 06, 2009 | 2003 Mitsubishi Galant
Fan replacement gone bad!
I take it the armature is not moving at all when you are turning the pulley(to the right, is right). You may have to pull the motor asm. out, remove the 4 scres and nuts off of the front bearing plate and pull it out along with the armature. I can't rmember if there is enough romm after pulling it out, from the inside to cut the shaft off with a hack saw. It is either that or replace the front bearing plate along with the armature.
May 26, 2008 | Kirby G4 Bagged Upright Vacuum
Ridgid R4510 10-inch Portable Table Saw With Stand Logo
76 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
