Question about Canon PowerShot A95 Digital Camera
Power probelm. Can't turn on camera even after putting in new batteries. Shutter is closed.
    Sergeant:
  • 321 Answers
Change the circuit. before that buy NiMH eneloop Batt. and try
Posted on Jun 19, 2009
  • mohamed salim shaikh
    mohamed salim shaikh Jun 19, 2009
    change the circuit. before that buy NiMH eneloop Batt. and try
Hi, i have a canon 500d trying to fix, thanks, when i put battery in even with power off, or power on, the blue lamp right of LCD stays on (does not blink), and no power on to the camera other than th
Check the HDMI, mini-USB, and SD card connectors for damage. The DC/DC board is part of the front board and it comes with the battery compartment. Check front and back of board for liquid damage and impact. Check SD card slot for damage to the contacts.
Nov 28, 2014 | Canon EOS 500D / Digital Rebel T1i Digital...
Shutter stuck in closed position on 35mm
Turn the shutter speed dial to M-90 this will release the camera, Then you can put new batteries in and it will work again, (Electronic camera) M-90 stands for mecnical
Sep 23, 2013 | Nikon FA 35mm SLR Camera
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
HI GOOD DAY I CANT TURN ON MY CAMERA IT DOESNT WORK EVAN WITH NEW BATERY THANKS
Check to make sure the batteries are inserted correctly.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.Close the [Memory Card / Battery Cover] securely, and then turn the power on.
If your camera still does not work even after you have performed the above procedures, your camera may be malfunctioning. Please have the camera serviced in this case.
Apr 19, 2011 | Canon PowerShot A460 Digital Camera
I am not getting an image either through the viewfinder or on the LCD monitor. The display is clear and bright and the batteries appear to be fine.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 26, 2010 | Canon PowerShot S2 IS Digital Camera
Shutter wont close
Try setting the shutter to B and see if you can trip the shutter. If no go then it has mechanical problem. If it works on B but not on other shutter speeds, you have electronic problems.
May 16, 2010 | Pentax Program Plus 35mm SLR Camera
LCD monitor is black
Sep 07, 2009 | Canon PowerShot SD890 IS Digital Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Camera wont turn on/off
I went to another problem, knowing my camera was stepped on, I messed around with moving the lens part around, barley moving it, and then I tried holding the on/off button and the button to take the pics with, and then put in new batteries and it turned on. I would suggest doing that.
Aug 28, 2008 | Sanyo VPC-S500 Digital Camera
When i turn camera on shutter closes and lens goes inside, and other way round...
Try the Sony web site technical help. but I feel that there is a main board fault developed here- perhaps time for a new camera try the tech help first though
May 28, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Canon PowerShot A95 Digital Camera Logo
66 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
