Question about NetGear RangeMax WPN824 Router
New computer hung at "Acquiring network address"
I am attempting to connect my new HP 8510p laptop computer to the router using a wireless connection and I keep getting this msg. I'm running Win XP Pro, SP2. The MAC address of the laptop shows up in the Attached Devices on the router. The router has been instructed to explicitly allow this connection, and yet I have no internet access on that computer. Periodically I'll see the msg flash to "Automatic" but then within seconds it's back to "Acquiring network address." Anyone know how to fix this? thanks!
  • 2 more comments
  • xhepera Nov 02, 2007
    Thank you very much for the reply. I followed the steps that you suggested and, finally, I'm getting a "connected" status. However, I'm still unable to connect to the Internet. I tried bringing up IE and all I get is the "page cannot be displayed" message. This IS a step in the right direction though. Thanks! Have you any further suggestions?
  • Anonymous Apr 08, 2008
  • Boomer7298 May 11, 2010
    My wife just got a new Dell laptop running Vista and we have a WPN824 router. It is set up for WEP encryption but we have misplaced the security key. I have been trying to access the router by typing in the in a IE browser but keep getting the message about the system not being able to connect to the network...any clue?
  • Anonymous Mar 12, 2014
    message acquiring network address and cant connect to internet
  • 310 Answers
Log on to the router. ( open IE and type in or -- depending on what the IP of the router is ) . You can find the ip of the router by clicking Start --> Run --> cmd and then typing ipconfig.
Once you log on to the router, run the set up wizard. Most of the times, this should help.
- Ranjit
Posted on Nov 02, 2007
    Brigadier General:
  • 6,966 Answers
Verify that the DHCP feature of the router is enabled. Alternately, you may want to set the PC to use static IP configurations rather than "Obtain an IP address automatically". Sometimes WinXP WiFi configuration messes connections when none WEP or WPA is used.
You may want to fix set your PC's WiFi config to IP Add:; Subnet Mask: and Default Gateway: 192.168..1 (that is of course assuming that your NetGear RangeMax WPN824 Router uses the IP add).
If this still does not work, pls post back so we can figure out tricking the WinXP WiFGi config to connect.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
  • Louie  Role
    Louie Role Nov 03, 2007
    Oooppss, should read"...Default Gateway: (that is of course..."
    A couple of things you can try:
    1. Right click on your WiFi networking icon (bottom right), click on Repair;
    2. Open IE, click on Tools, Internet Options, Connections tab, LAN Setti9ngs button, check "Automatically detect settings", OK, click on Advanced tab, press Restore Defaults button, then check "Use HTTP 1.1 through proxy connections", OK;
    3. Right click on your WiFi networking icon, click on Status, verify that there are some numbers under the "Received". Click on Support, click on Details button, there should be numbers across all settings (pls post these setting numbers), Close.
    Pls verify that your router is connected to and can access the Internet. Am I right to assume that you have a 2nd PC? If yes, can you pls check also its networking config/settings and post details.
I had to reinstall my XP pro os on my HP compaq nc6230. Prior to the re-install i was connection via wireless. Now everyting works fine except I cant connect via wireless. It see all available wireless...
Try power cycling your router while your computer is connected via wireless (even with limited or no connectivity) . Unplug the router for 15 seconds and then plug it in again. Hopefully the router will assign your computer a new IP address.
Mar 01, 2011 | HP Compaq Business Notebook nc6230 -...
I can not connect to my netgear wgr614v6 with my hp netbook. I can connect with my other laptop and the netbook has been connected before. It keeps saying "acquiring Address"
If you're trying to connect wirelessly, and it says "acquiring address" and never connects, it's most likely because your wireless network has an encryption key enabled, and the encryption key on your laptop/netbook doesn't match. You should disconnect from your home wireless network, and then try to re-connect to it. Verify that you're using the correct wireless key to connect. If that still doesn't work, you should reset your router to factory defaults so that there's no wireless key required to connect - and then try again. If you want to put the wireless key back, you can run the CD or connect to the router using the web interface and configure it again.
Mar 07, 2010 | NetGear WGR614 Router
Hung on connecting to router
Reinstall the computer operating system and then install the adapter drivers.
Nov 05, 2009 | Belkin Wireless-N USB 2.0 Adapter
Sometimes you have to change your computer's settings or the routers settings to know what type of encryption its looking for otherwise it will just stay on acquiring.
Sep 19, 2009 | Linksys WRH54G Wireless Router
I set up dlink dir300 router and pc and other
go to your adapter settings for the notebook that does not work and clear off your network connection try to re-discover your router, and enter the same code you used to log in with the notebook that works. Sounds like you have an IP from the router, but no access.
Jul 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
May 01, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Set a Static IP Address on your computer to resolve the issue.
Mar 08, 2009 | NetGear WGR614 Wireless Router
"acquiring network address" problem
The password might have been changed that's why you keep getting "acquiring network address", the password is incorrect. What you can do is just reset the router. There's a reset button at the back of it, press and hold it down for 10 seconds then release, unplug the power now for 10 seconds then plug it back in. That will disable the wireless password, just re-enable it.
Oct 26, 2008 | NetGear WGR614 Wireless Router
Acquiring Address Problem
you will need to make sure that DHCP is enabled within the routers settings as this will tell the router to assign ip addresses automatically, then go to network connections, right click on your network card>properties>TCP/IP line>properties and tick 'obtain an ip address automatically', click ok, close window and restart pc.
Sep 24, 2008 | HP PAVILION A6230N DESKTOP PC
Laptop can not connect to router
If you care to try, manually enter IP settings in your laptop as follows:
IP Address -
Subnet Mask -
Default Gateway -
DNS - whatever your ISP is using
In your Internet Explorer >
Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings", OK, Advance tab, check Use HTTP 1.1 through proxy connections.
Nov 23, 2007 | Linksys WRT300N Wireless Router
NetGear RangeMax WPN824 Router Logo
833 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
