Question about LG WM2101HW 4.0 cu.ft. Washer
Where is the hall sensor - LG WM2101HW 4.0 cu.ft. Washer
    New Friend:
    Problem Solver:
  • 18 Answers
A hall sensor is a magnetic pickup sensor that picks up magnetic pulses caused by a rotor that is bolted to the spinner shaft in back of unit. remove back access panel and motor rotor is facing you now. take bolt off of rotor and slide off. you should be able to see hall sensor under stator. remove bolts on stator to access hall sensor.
Posted on Apr 18, 2014
What is the function of a hall sensor G40(Camshaft position sensor)
Hall sensor function
A hall effect sensor is a sensor that produces a square wave output that can be directly read and modulated by the ECM (as opposed to an AC wave sensor which produces a sine wave that must be converted). They are used as cam position sensors and ABS wheel speed sensors.
Hall Effect Sensor and How Magnets Make It Works
Apr 18, 2017 | Cars & Trucks
2001 saturn lost keys to it. Got it to crank cut right back off secrity lights on bought a brain box for it and got 2keys with it. Still want crank I need to know what to do t could the box be bad ..
No ,the box is probably not bad , but you need to have it programmed . The dealer is the only one that can do that ? The keys don't matter .
The passlock sensor mounted to the ignition switch assembly is located inside the upper right side of the steering column. The passlock sensor contains two hall effect sensors: a tamper hall effect sensor and a security hall effect sensor. The tamper hall effect sensor is mounted on top of the security hall effect sensor. Should someone attempt to defeat the system by use of magnetic experimentation, the tamper hall effect sensor will activate first.
The passlock system is a vehicle theft deterrent system which deters drive-away vehicle theft by disabling engine operation if the ignition lock cylinder is not rotated with the proper mechanically cut key.
The passlock system is made up of an ignition switch assembly, passlock sensor, body control module (BCM), instrument panel cluster (IPC), and a powertrain control module (PCM).
The ignition switch contains a magnet mounted on the lock cylinder and a passlock sensor assembly which consists of security hall effect sensor, tamper hall effect sensor, and output resistors. A drill proof metal shield is also staked over the sensor housing.
The BCM has the passlock controller integrated into it which controls the majority of the security systems logic. The BCM reads the data from the passlock sensor continuously. If the data is correct and has been received by the BCM within a specified time, the BCM will send a coded password to the PCM. The PCM will then allow the fuel injectors to operate.
The coded password for the security system is sent from the body control module to the PCM via the class 2 data link. If the password is correct and received within the specified time, the PCM will allow the fuel injectors to operate.
Sorry but you can't just replace parts , you need to know how the system works . You need to take this to a ASE certified repair facility that knows how it works .
Oct 10, 2015 | Saturn Cars & Trucks
Maytag front load washer mah9700a
I am not used to this appliance as I am from the UK however:
As hall sensors are used on direct drive machines the hall sensor is located on the back of the drum underneath the big round metal motor part, this will need to be taken off to gain access to the hall sensor. (this is how it works with the LG hall sensors as they are also direct drive)
Apr 05, 2014 | Washing Machines
Po338 2005 hyundai sonata
Trouble Code: P0343
Camshaft Position Sensor High Input
Possible Causes:
CMP (Hall) sensor signal circuit is open or shorted to ground.CMP (Hall) sensor ground circuit is open.CMP (Hall) sensor power circuit is open (check fuse in the I/P).CMP (Hall) sensor is damaged or has failed.PCM has failed.The other code is not listed in this listing.
Dec 22, 2012 | 2005 Hyundai Sonata
HOW TO REPLACE HALL SENSOR ON LG TROMM
Unplug machine. Remove back panel (4 phillips head screws). Remove large bolt in center of motor. Pull motor rotor off shaft. Remove phillips head screw(s) holding wire protector and possibly ground wire at bottom of motor area. Remove metric bolts from motor coils and remove coil assemble. Unplug 4 wire harness from Hall sensor. Unclip Hall sensor from coil assembly. Install new Hall sensor, and re-assemble. Plug machine back in. There. Done, and it only took 10 minutes!
Mar 27, 2011 | LG WM1814CW Front Load Washer
I got an E3 flashing, what does that mean. The
Okay; This will essentially be a Hall Sensor fault. The Error code (E3) Is issued when the Motor control board is attempting to drive the motor (during the spin out), but is not seeing any tachometer response readings. The Hall sensor monitors such movements to relay the necessary rotation information to the Motor control board. When the Hall malfunctions, the MCB will assume that the motor is "locked" and it will issue the (E3) code.
The necessary actions are to replace the Hall sensor. Here is a picture of the Stator(Motor) and Hall sensor.
Click here to access the service/repair manual for your unit. This manual will help you disassemble the affected area. You will first need to remove the rear access panel, before gaining access to the affected section. Once the rear panel is removed, focus on page 33-34 to help with removing the stator so that you can replace the damaged hall sensor. Please allow time for the manual to download, due to its size.
  • Once you have replaced the defective Hall sensor, the unit will return to its normal operating status.
Jul 25, 2010 | Maytag Washing Machines
Hall sensor
No. Actually, the Hall sensor, part number 6501KW2002A, is covered by a 7 year part warranty.
Dec 10, 2008 | LG WM-2277HW Front Load Washer
Washing stops after a min or two & LE flashes up!
This is caused by an error from the hall sensor on the motor. It is possible that one of the connectors has come loose (this is an issue with LG's or it could be the hall sensor it's self is bad. First check that the harness that connects to the motor is tight. If that doesn't help then the hall sensor will have to be replaced. The hall sensor is located on the motor. The hall sensor basically tells the computer which direction and what speed the drum is turning.
Nov 16, 2008 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Replacing hall sensor
The hall sensor is located in the back of the washer.  You need to get through the back panel to get to the hall sensor.
Jul 11, 2008 | LG WM-2277HW Front Load Washer
LG WM2101HW 4.0 cu.ft. Washer Logo
98 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
