Question about Pool & Spa
54075 heater turns off
Turn the pump/heater on evrything powers up then after a wile it turns itself off but the light is still showing a number on the display in f it wont let me increase the temp to 104f or 40c this is what is best for this hottub after running for around 2 hrs we noticed that it had stopped pumping the water and the only thing lit up was the numbers when we repressed the heat button the heat light came on and the filter light came on the water does seemt o be heating up a little does any1 have idea's what this could be or if its in a hibernation mode or sumthing
ACTECH
  • 80 Answers
SOURCE: intertherm heat pump
FIRST YOUR OUTSIDE UNIT PROVIDES HEAT BY USING A REVERSING VALVE TO CHANGE THE REFRIGERANT FLOW.THERE IS NO HEAT STRIPS OUTSIDE SECOND YOUR EMERGENCY HEAT TURNS ON ELECTRIC ELEMENTS INSIDE YOUR AIRHANDLER UNIT.IT SOUNDS LIKE SOMEONE HAS WIRED YOUR UNIT WRONG OR HAS THE THERMOSTAT SET IMPROPERLY.WHEN THE HEAT PUMP CANNOT SATTISFY THE SETPOINT THE THERMOSTAT IS SUPPOSED TO TURN ON YOUR ELEC. HEAT UNTILL THE LOAD HAS BEEN REACHED AND THE HEAT PUMP CAN CONTINUE TO MAINTAIN IT.
Posted on Nov 29, 2007
  • 61 Answers
SOURCE: heating & AC thermostat problem
It could be running in a "programmed mode" if it has the capabilities. You could exit from the programmed mode
Posted on May 07, 2008
SOURCE: heat pump condinser freezing.
Simple solution that works every time...turn your A/C on for 5-10 minutes...CASE SOLVED
Posted on Nov 26, 2008
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
  • 83 Answers
SOURCE: When Heater is turned on display shows 125, doesn't ignite/fire.
I am not sure if you have solved this issue, or not, but here is one idea. When you turn on the heater, it is reading the temp at 125/126 correct? IF this is what the heater is reading, then the problem is the Thermistor,or temp sensor, and is very easy to replace.
If you have an Owner's Manual, there are part numbers and instructions on how to replace the Thermistor. If you do not have one, follow the link below and it will take you to one online:
http://www.pentairpool.com/pdfs/MaxEThermOM.pdf
Posted on Jul 01, 2009
We have refiled our lay z sap, after it dispaly shows 3 dashes
You probally just need to break an air lock in the pipes. You can ether force water down the skimmer pipe or find your drain valve and open it for a minute or two till it runs just water and no air. This will get water to the pump and the heater. This should fix you up.
Aug 02, 2010 | Pool & Spa
Spa keeps tripping breaker shows pr
two main reasons breaker trips is the pump motor jammed [not turning]or the heater shorted out --disconnect power open access panel disconnect the lines to the heater turn on power if breaker trips than motor /pump problem if doesnt trip than heater problem can order heater replacement online or pool spa store--if motor pump check pump for debris and motor for lube if u can turn shaft or impeller oil motor and work it into bearings if still not turning possible need to replace motor unit
Apr 26, 2010 | Heritage Pool & Spa
Heat will not turn off.Removed thermostat wile
Hello
Could be a stuck control relay,Tsat completes a circut for this relay to engage,once relay contacts are closed heater will start.and stay on until you reach temp.
once temp is reached relay will open and heat will shut down.
By disconnecting all power to heater your forceing relay to open.or simulating a satisfied temp.
I would have a service tech look at your control relay and t stat.
Jan 28, 2010 | Goodman Heating & Cooling
Goodman electric heater won't initialize final turn on. The coils are hot, I see elements heat up around the fan but then there's a click that stops everything from going further. ???
The limit switch is cutting evrything off. See if you can turn the fan on manually at the t-stat, if so the fan control switch is bad.and needs replacing. if not the fan itself could be bad.
Nov 01, 2009 | Heating & Cooling
No power
Ed,
I have this same problem. Did you ever solve it?
Jun 24, 2009 | Hayward H Series Millivolt 250,000 Btu...
Pentair pool pump vs 3050
These pumps should not be hooked into an intermatic mechanical timer. It should always have power supplied to it, meaning it should be installed to the line side of the power supply. Scheduling is done either in pump itself or thru an external controller such as a suntouch or easytouch controller, etc. When you have it wired into a timer like intermatic, power is interupted to the pump every day when the timer setting is for off. It is very hard on the drive of this pump, it does not like it, and will shorten the life of the drive. The pump was designed to always have power supplied to it, even when it is not scheduled to run. This may be the problem you are experiencing. HTH
Jun 02, 2009 | Pentair IntelliFlo VS+SVRS Pump 230v -...
Pool & Spa Logo
94 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
