Question about Homelite Mighty Lite Lawn Trimmer
The head keeps falling off my weedeater brand weed eater
  • 776 Answers
Add a split washer. Turn it tight enough to compress the split into a flat washer. The spring tension of the washer will hold it on. If not, you will need to add some Loctite.
Posted on May 08, 2014
5 Suggested Answers
  • 246 Answers
SOURCE: weed eater will start but the head will not
Hello snap77b:
From your Description it Sounds like the Shaft May have Slipped Out of the Power Head and the Drive Cable is Not Engaged to the Drive, the Clutch is Worn Out, the Drive Cable is Worn and Requires Replacing, the Trimmer Head has Slipped and is Not Engaged to the Drive Cable or the Trimmer Head Gearbox is Bad and Requires Replacing.
>>Send me the Model Numbers Off the Unit, Please. With these I can Locate the Proper Manual and Better Assist you.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
rycgl
  • 1545 Answers
SOURCE: replace nylon on weed eater head
Go to: http://dl.owneriq.net/e/e795beb6-5dd6-4dbd-a82f-57b8d1a69355.pdf
See pages 14 and 15 for your information on stringing the head.
Posted on Oct 12, 2010
rycgl
  • 1545 Answers
SOURCE: I have a MightyLite weed eater - the plastic
You don't have to purchase a new one. Parts for it are available. This online parts house is good. If you are saying you need the plastic bubble for the carburetor, it is here.
http://www.ereplacementparts.com/homelite-misc-parts-c-18807_24213.html
There are 3 models listed. They are listed in the 4th section of misc. parts and are items 9,10, and 11.
All the other parts for your machine are listed here too:
http://www.ereplacementparts.com/homelite-ut21506-mightylight-string-trimmer-parts-c-18807_20299_64844.html
Posted on Oct 18, 2010
hunter19_46m
  • 7482 Answers
SOURCE: carb on weed eater flooding
Hi james....
Your float level is set wrong, and or it may be that you did not replace the little rubber seat or it is faulty and the float needle is not sealing.
I will give you some info below
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Mar 25, 2013
Trimmer head won't stay on
Use a piece of trimmer like in head. As you slide it on it will likely be tight and hard to come off
Oct 13, 2015 | Poulan/Weed Eater No. Te475 952711797 17"...
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
Morrison weedeater
never saw your brand weed eater . but most weed eaters ,the string cap either unscrews or has plastic tabs that have to be pushed sideways with a flat blade screwdriver.If you have the plastic tabs ,be careful not to crack them off when pushing them sideways with a screwdriver--- so that the nub can clear the slot and get the cap off.
for better info call morrison customer service and ask.
phone # on weed eater and in owners manual. also , owners manual should have instructions under how to change string.
a pdf manual can be downloaded from morrison weed eater.
you will need to know your model number before morrison can help you.
Oct 06, 2013 | Garden
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Weed eater bogs out at full throttle
Make sure fuel is mixed correctly, make sure the choke isnt stuck on aswel, ive had it happen to me before when the little blue leaver sticks and it wont rev out properly.
Apr 02, 2013 | Husqvarna 128 LD Weedeater
John deere 260g weed eater how the line goes on keeps breaking
Does the line break or is it the head. If it is the line try using a thicker type of line, or a better brand. if the head is broken this may need to be replaced, but first check to see if you have it correctly assembled.
Aug 10, 2011 | Garden
I have a brand new craftmans gas weedwacker. The line went completely in the head (after about ten minutes of use) and I can't get it out. It is a bump type head. Any ideas???
When using the weedeater you cant let the line get too shore otherwise it goes back inside the head, you will now have to pull the bump head apart and reload the snipper cord...
Brad
Aug 01, 2011 | Garden
I need a twist n Edge weedeater manual to find out how to put more string on the spindle
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater RTE 115 Trimmer Manual.
Jun 26, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
What is the gas/oil mixture ratio for the featherlite gas weedeater?
its a 40:1 ratio. remember to never tap the tap-n-go too hard or it will bend the shaft, and make the head hot to the touch, and eventually will melt the inside. And always keep fuel stabilizer in the gas, because if you dont, especially in winter and fall, it will clog the carb so you have to keep pumping the throttle to keep it running and you have to run it on half choke all the time
good luck!
,devin
Apr 25, 2009 | Poulan Featherlite Gas Blower, with Low...
Homelite Mighty Lite Lawn Trimmer  Logo
196 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
