Question about Pool & Spa
54075 hot tub heater keeps stopping - Pool & Spa
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Check filters if ok check pressure switch if ok check temp sensor if ok check to see if heater element is ok
Posted on May 08, 2014
Hot tub keeps blowing fuses. Only happens when the heater is on, any ideas?
According to the description, it looks like too weak fuses, respectively too strong current when heater is on. Heaters generally consume high currents, and when motor and heater run together, the current (amperes) may be too strong for the fuses.
May 17, 2015 | Pool & Spa
What is the best product to remove ring in hot tub?
SECRET:
Use a a Good Quality Name Brand "Filter Cleaner".
Works great as a surface cleaner for your hot tub.
May 26, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
Hot tub heating is working but pump has stopped
you may have a system that uses a small circulating pump that circulates the water thru the heater to keep water temp at proper level (this is usually the case with hot springs spas and is because it is the most cost effective way to maintain constant water heat without using a full size pump or two speed pump just to push water past the heater core. therefore the issue is you have a problem with your jet pump and it has nothing to do with the circulating and heating portion of the spa. you can check to see if there are any reset buttons in or near the equipment as well as open enclosures to make sure everything is clean and dry also make use any contacts on spa skirting are secured propertly
Apr 24, 2010 | Pool & Spa
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
Tankless on demand water heater.
Tankless water heaters normally take a little longer than a regular heater to provide hot water because they have to start and get warmed up. I'm guessing the heater uses a pilot light and that the short amount of hot water when you turn on the tap is hot because when the water is sitting still in the heater the heat from the pilot light is enough to get it hot. The tub faucet will get hot a lot faster than the shower because it lets a lot more water through and empties out the pipes faster than the shower. You could probably speed things up by letting the tub faucet run on completely hot for like 10-15 seconds and then turning on the shower.
Oct 24, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
How long does it take to heat the tub
Make sure that the inline heater has power. It should not take very long to heat since your putting hot water into it anyway. The heater is to keep water warm.
Jul 02, 2009 | Waterway 1 Hp 115 Volt 2 Speed Side...
Stopped heating, where is the heating element
turn off the electricity. unhook the two wires going to the heater. Hook up a meter to the two connectors. set the meter to ohms and ohm the heater out. If it has an open in it replace the heater.
David
May 25, 2009 | Coleman (5040B750) Patio Heater
Pool & Spa Logo
35 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
