Question about Water Heaters
Making a beeping noise, sounds like alarm - Water Heaters
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 41 Answers
Wrong Electrical connection, check voltage.
Posted on Jun 01, 2014
Makes beeping noise
Wrong electrical connection.
Apr 17, 2014 | Water Heaters
Making beep sound
What product is making beeping sound?
Repost question and choose best category and give as much info as possible, and then fixya might truncate question so we cannot see what was asked
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 18, 2013 | Water Heaters
Ariston euro-combi boiler not giving hot water
odd noise like popping or singeing fire....clicking noises.....sounds like you have a water leak putting out the pilot.......or your thermo coupling is bad....or the noise is the tank full of calcium buildup and that will make noises when the burner is on
Jan 19, 2013 | Water Heaters
Electric water heater making beeping sound after being switched on for about 24 hours, eventually stops when turned off. Please advise. Thankyou
geooffslater,
I have extensive files on tank-type electric water heaters.
What brand and type of heater do you have that is beeping?
What is making the beep sound?
Add a comment with information that appears on label on side of unit.
If this is a tankless unit, then my information sources are not as complete and might not be correct expert for the question. Add comment with brand and type, and at that point I might ask that question be re-posted with details for correct tankless expert.
Aug 28, 2011 | Water Heaters
New Rheem Fury Guardian System 50 gal water heater model 42V50-40F. Loud low humming or drone sound when in operation. What can this be?
Is the noise when the water is running or when the burner is running???
If it is just the water then the noise often is the flow checks inside the tubes going to and from the heater...
If it is the burner, then the noise could be the gas going through the gas valve...a bit of moisture or dirt can sometimes cause noises...usulally will correct its self after a bit of time...no worry...
poping crackling sounds and such are common with mineral builsup in the bottom of the heater....
Flush the heater and get the dirt out....
sizzling noises sometimes happen from condensation dripping onto the burner....gain not a problem...
sometimes the gas properties will cause the gas to make noises when going through the gas orifice into the burner... usually this is air or a LP air mixture known as "citigas" that will burn like natural gas but really isn't and it will make noises such as your are describing...again no problem...
Ultimately the noise you hear is not a problem but can be irritaing if the heater is where you can hear it easily...
Feel free to comment back if you have any more questions...
heatman101
Feb 25, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a carbon dioxide detectorin my attic that is beeping 3 beeps per second. Would that be a battery issue or maybe because I've been running my gas fireplace ( gas logs). I'm a newly separated not so...
If it bother you open a wind a little bit for fresh air till morning. It is telling you to change the battery. Why is it in the attic? It should be on the floor you are sleeping on for best protection.
Feb 07, 2011 | Water Heaters
Sounds like a squirrel inside water heater
Check your thremostat setting if it is set to highest position it may be causing some of the noise over heating the water and making the noise. And you can put an insulated jacket on it to maybe help with sound.
May 14, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
The noise is inherent in electric hot water heaters. It is the noise that the water makes when it is being heated by electric heating elements. Mineral buildup on the elements can make it worse, so changing the elements can help...but will not totally elimenate the noise. When I install a new tank and turn it on all I have to do is listen to it to see if it is working or not...even brand new will make a sound...it is the sound of hot water... :-)
heatman101
Mar 25, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Beeping noise
E2 means hot water over shot, make sure to check boiler hot water system to make sure zone valve or control is staying closed when the call for boiler hot water to the water heater is isolated. Sometimes a zone valve will fail open or not close properly causing hot boiler water to constantly feed the water heater.
Dec 08, 2009 | Amtrol Water Heaters
Loud noises
did you size the gas line properly? sometimes if the gas pipe isn't sized properly it will cause some pretty loud wistling noises. also if you have something in the fan like bugs or lots of dust it will cause alot of problems with noises
Jul 24, 2009 | Rinnai Digital Remote Water Heater Control...
Water Heaters Logo
163 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
