Question about Cycling
Bike chain replace - Cycling
    Problem Solver:
  • 14 Answers
Here's a helpful link that covers replacing different types of chains: http://thebicyclechain.com/how-to/chain-replacement-and-repair-pg80.htm
Posted on Jul 05, 2014
  • ddfisch Jul 05, 2014
    Here's a helpful link that covers replacing different types of chains:http://thebicyclechain.com/how-to/chain-...
How to fix bike chain
Wrap it round the chainwheel and rear sprocket, threading it through the gear mechanism if one is fitted. Then use the connecting link to join the two ends. About 30 seconds work.
Sep 19, 2017 | Cycling
Bike chain broken, how to fix this?
Sometimes all it takes is a master link or "quick link," but you can't count on that. How to fix it depends on several factors. There are different chains for the various number of cogs/gears on the rear of the bike, and an older chain may require a different procedure than a newer one. Further, if the chain is badly worn it may need to be replaced, but then may not mesh well if the gears aren't replaced as well. Finally, just taking out the rest of the link (one full link is one outer and one inner) may make the chain too short, which could damage the bike.
It's best to take the chain and bike into a bike shop, or a bike co-op if there's one available. If you really want to know all the in's and out's see this link: Chain Maintenance
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Oct 31, 2016 | Cycling
Bike chain
With a chain splitter! It's a good idea to change the front and rear sprockets too so buy the lot when you're buying the chain. Loosen the tension on the chain tensioners on the rear wheel. Split the links. Remove chain. Remove and replace sprockets. Replace chain and be sure to use a chain riveter to sort out the joint. Don't be tempted to use a split link as your bike is too big and powerful for one. Adjust your chain tension checking for tight spots etc. Apply lube and enjoy!
Jul 14, 2014 | 1999 Honda VT 750 C2 Shadow
How do i fix the rear sprocket on my huffy rock it bicycle
on all single speed bikes, it has been my experience, that chain tension is the reason for the chain to come off, try tightening it again, since this seems to keep happening the chain may be stretched out now and replacing the chain and getting it tight should solve the issue.
Apr 30, 2014 | Huffy BMX 20" Boy's Rock It Bike
Chain keeps comming off
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
It sounds like you are dealing with a stretched chain. If the chain will not tension any further, you may be looking at the need to purchase a new chain. Use your model and serial number at the following link to order a new chain.
Bike Parts for LifeFitness LifeCycle 9500 Upright Belts Pedals Seats...
Jan 29, 2014 | Life Fitness Lifecycle 9500 Upright...
Chain size
If it was me, I'd measure the chain already on this bike or go to Walmart with a tape measure and measure one there. I assume you don't have any of the paper work that came with the bike originally? What do you intend to do, Are you going to replace the chain ? You can get a kit to replace a broken chain / link, if you need to. You just punch out the rivet on one side with the tool in the kit, then pop in the connector and attach the locking clip . Remember to feed the chain through the frame at the back., before you do this.
Jul 22, 2013 | Huffy BMX 20" Boy's Rock It Bike
Chain placement on Next 21 gear mountain Bike
You haven't actually asked a question, so I am guessing that you want to know how to replace a bicycle chain on a 21 speed bike. To remove the chain you need to use a chain tool that presses one of the pins out of the one of the chain links (any link, there is no master link). To put the new chain on you use the chain tool to press the pin in. This is just a little tricky with a chain tool, but it's just about impossible without it. They sell these tools at bike shops and maybe even at Wal-mart. Take a look at this link to see a what I'm talking about. http://www.parktool.com/blog/repair-help/chain-installation-derailleur-bikes By the way, Park tools are very good quality for the money.
Dec 07, 2010 | Cycling
Chain Broke on a Huffy Tundra 18 speed 26" bike. I need to know the size chain to replace or the master link/chain connector to fix the chain.
if the bike has gears it does not have a master link, that is for single speed bikes only.
You will need an 8spd chain for your bike (1/2" x 3/32), these will fit any 6,7 or 8 spd bike. This requires a special tool to install ($8-$25), I would recommend taking into a bike shop and have them do it if you have no experience with this type of chain.
Side note: if you do own the tool, you can repair a broken chain for a temporary fix in the future, so may be worth buying. Check around, many bike shops offer basic repair classes and cover this.
Nov 14, 2010 | Huffy Men Mountain Bike (26")
How to put a chain on?
Your question is not entirely clear. If you are trying to replace your existing chain with a new one, then you will need a special tool (chain breaker) to remove it. Here is a link to a video on how to do it.
You may also want to consider getting a quick release chain link for the future to make the job easier.
If you done have access to a chain breaker, then I suggest you take the bike to a bike store. Replacing a chain is cheap and can be done fast.
May 06, 2009 | Huffy 26in Mens Sante Fe Cruiser Bike -...
Cycling Logo
123 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
