Question about Apple iPad 32 GB WiFi Tablet PC
Need replACEMENT how do I get a replacement if I bought extra warrenty waiting for an answer
How to change install directory without doing something that voids my warrenty
You could install extra apps on SD card memory if your tablet has a slot. Every easy on Andriod based Tablets.
Installing SD memory and Changing install directory do NOT void warranty.
Mar 19, 2016 | Tablets & eReaders
Sons cousin sat on his rca tablet and cracked screen. Bought at walmart but lost receipt. Can i track it and see if warrenty will cover/replace it?
someone sitting on it would not be covered under mfg's warranty .and none I know of have a goodwill feature included in the warranty .
Mar 02, 2016 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
I just bought my tablet and it will not let me do anything. I reset it. Nothing. I downloaded games and I cant find them to play. What is wrong with it as its brand new.
HI Brittney
What tablet did you purchase? You have 2 questions here, so I will answer the 2nd one first.
You downloaded games and can't find them? They are usually loacted here... click Settings/Apps/Downloaded.
The first question, depends on what tablet it is.. Samsung ? Apple?
Have you tried plugging in the charger and wait a few minutes for the tablet to show the battery is charging? (on the bottom right there is a battery icon) It should show a small lightning bolt as its charging. If not... take it back to the place you bought it as it's NEW and they can replace it if it's faulty.
Nov 23, 2015 | Tablets & eReaders
My almost new under warrenty galaxy android 10.5 tablet: usb cable end will not fit into the port anyhmore..it used to..is the port hole broken?
Do you have an Android phone?
If so compare the charging ports.
There should be a small plastic bar in the port with connectors on it.
If this bar is missing or damaged, then it would need replacing.
Most phone repair shops can repair this but from past experience it will probably cost between £100 and £200 to repair.
It is NOT covered by warranty unless you have a very helpful staff member from where you bought it.
Samsung usually class this as user damage and will not repair for free.
See picture for the plastic section which may be damaged.
Feb 06, 2015 | Tablets & eReaders
Just got my zeepad for Christmas.power cord for wall plug has already stopped working. send a replacement please.
I would contact the place you purchased the unit, and ask for a warrenty replacement.
Jan 11, 2015 | Tablets & eReaders
Can you get a replacement battery for a kobo touch
Will one of those extra battery packs work to power the kobo? I just bought a 'pocket juice' at walmart to use with my cell phone.
Others are saying it is not worth putting in the real battery.
http://www.mobileread.com/forums/showthread.php?t=102752
Dec 21, 2014 | Kobo 6" eReader Touch Edition
Hi, Purchased a tablet and didn"t register yet. can I, still return the tablet? it hasnt been a year and I brought an extra 2yr warranty on it! please help!
Hi Jean!
Yes you can return that tablet to the manufacturer official store. If they have any assistance about this . Mainly in these case they only give repair warranty not like that they take thier product back and give you your money back . Hope you undertand . Thankyou.
Nov 10, 2014 | Visual Land Prestige 7 Internet Tablet...
DO YOU REPIR CRACKED SCREEN FOR KOCASO M9100
you are going to have to get online and get ahold of kocaso to see if you can either get a replacement tablet, or do you need to buy something else, what i am seeing is they will replace if your warrenty is under a yr old, if not then your going to have to find out from them what to do
Aug 16, 2014 | Tablets & eReaders
My galaxy tablet was fine yesterday but today it will not turn on. The battery ran dead and I pugged it in and nothing, The red light does not even come on to show it is charging. I have tried both the car...
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
Mar 13, 2011 | Samsung Galaxy Tab Tablet PC
Is there another way extra button to turn on my HP TC 4400" the "on" switch is broken inside of the computer
You can actually short out the on/off circuit with a flat head screw driver. I have to do this until I can find somewhere to purchase a replacement sliding switch to attach to the new motherboard which I have waiting to be installed. Alternatively purchase a cheap docking station off ebay
Jun 08, 2009 | Compaq tc4400 Tablet PC
Apple iPad 32 GB WiFi Tablet PC Logo
23 people viewed this question
Top Apple Tablets & eReaders Experts
John mullen
john smith
Ronald Connal
Ronald Connal
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
