Question about VeriFone Lipman Nurit 8000 8020 14.4k External Modem
GSM radio test fail
Failed radio test 3 times
I have a uniden bearcat 880 CB radio and just hooked it up to a K40 antenna with a 9' mini 8 coax and for some reason my swr is pretty much 3 and it passes on the rf output test but fails antenna test
Failing either test is odd. Is mini 8 coax RG 8x? I assume it is, so your readings do not make sense. My first suggestion is to test with another piece of coax. If it tests fine, check your connectors! If it is still bad, you may have a rare piece of bad coax. It happens, just not often. Please post your results. Jack
Mar 20, 2017 | Uniden Radio Communications
Why I failed emmissions test 3 times
what is your question?
I failed emmissions test once too, and it turned out to be a bad gas cap!!! $30 for a new one.. Yes, it was a Kia too.. Sephia.
Aug 27, 2014 | 2003 Kia Sedona
2000 Mitsubishi Galant ES 2.4 liter, the electrical issue is that the battery seems to lose power and trips out the radio and will not start and have to put in radio code all the time and fuses seem to...
How old is the battery? More than 3 years it may be failing. Summer heat will test the battery limits.
Could be the alternator / regulator is bad causing large spikes in the voltage.
Take to an Auto Zone or other auto parts store and ask them to test the battery and alternator.
good luck
Jul 07, 2011 | 2000 Mitsubishi Galant
93 civic failing emissions test... tested 3 times, replaced plugs, wires, o2 sensor, catalytic, and retarded the timing slightly...passes curb idle...fails all 3 on ASM2525
check for any vacuum leaks, run some injector and combustion cleaner through it, check the pcv valve and the egr valve, and fresh oil, can't think of anything else
Nov 17, 2010 | 1993 Honda Civic 4 Door
Cannot hear transmisions all the time. changed batteries to regular alkaline from pack to see if the battery were bad. this did not change the transmissions problem. need help.
You may have one of the following issues:
1) Programming of special features is inhibiting communications. Reprogram the radio(s) back to a basic mode with the special features, code and Qt filter (if any) turned off (zero). Then check to see if communications improves.
2) You could have a Transmit problem with the other radio. This could be caused by a bad or low battery or even a sticking PTT. Try trading the batteries with a known good radio and see if the problem changes or moves to the other radio.
3) Your radio could be failing. If you have changed the batteries to known good batteries, and tested the radio with more than one other radio, and you do not have a programming problem, you likely have a radio which is failing.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Best regards.
Sep 15, 2010 | Motorola T8500 Two Way Radio
Ps3
wired conection , connection test fails obtain ip adress connect but connection internet failed.
Oct 07, 2008 | Sony Playstation 3 (PS3) Console
Motorola T5420 Transmit Problem
Here are some troubleshooting thoughts:
1. Is your battery indicator showing at least 2-3 bars? (Battery Note: Your rechargeable batteries may fail due to setting without use for a long period of time. They need replaced every 12-14 months usually. A good tip is to charge them once a month to keep the chemical in the battery active.)
2. Check to see your Qt noise filter is shut off. Refer to page 22 of the owners manual. It is possible you have some radios set to Y and others to N. To assure good communications you should set all of them to N.
3. With your radios set to interference code zero, place your radios one at a time in scan mode, while you transmit/talk on one individual radio. See if any of the radios receive. Do this with each radio individually to see if you are transmitting at all. NOTE: This test will determine if you have any ability to transmit. If you do not receive any sound on the 3 radios setting in scan mode, the individual radio you are testing will not transmit.
Aug 25, 2008 | Motorola Talkabout T5420 (14 Channels)...
NEED A HELP
TEST 8 FAILED means
the control head is a mismatch with the body of the radio
Oct 05, 2007 | Motorola Radio Communications
VeriFone Lipman Nurit 8000 8020 14.4k External Modem Logo
48 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
