Apple MacBook Air Logo
Posted on Jun 19, 2009
MacBook Air Sound Problem - Same Situation
I have the same issue, and it does seem like a cord is loose because sometimes if the sound card still works but the sound stopped working I can push the right end of the laptop down and the sound starts working again.
Anonymous
Level 1:
  • Contributor 50 Answers
  • Posted on Aug 12, 2009
Anonymous
Contributor
Level 1:
Answers
50
Questions
11
Helped
14311
Points
72
This is due to accidental disconnection of wire internaly so go to an authorised dealer and repair it otherwise it can also harm to your logic board if it touch with that rate it plz
Macbook air pinging sound
Turn off letting the Hard Drive Go To Sleep when Possible.
It's in
Apple menu
System Preferences
Energy Saver
1st check box should be unchecked.
5helpful
Sound is locked in mute in Mac air and it can not unchaked
At iPatch solutions, we see this problem WAY too often. I know this will sound silly but all you'll need to fix this issue is a can of compressed air (for dusting off electrical components). Is there a red light on inside the earphone jack? Usually that accompanies the muted volume but not always. Here are the steps to fixing it in about 2 minutes.
Step 1: Attach the little straw (there should be a small straw supplied with the can when you purchase it).
Step 2: Insert the opposite end of the straw inside the earphone jack. No need to jam it in there. Just so it is inside about 1/4".
Step 3: Start blowing short blasts of air into the jack. Don't worry, this will not harm the computer or void any warranty. As you do this, keep checking the volume. It WILL come back on. There was a small glitch when Apple installed the jacks (it has happened to my MacBook Air and my standard MacBook). Usually without even noticing, it happens sometime after using the jack. Not always right away and sometimes not even at all. Don't forget to vote after you try this. You're going to shocked at how fast your volume works again. Here's my email if you have further questions: [email protected]
My FA-66 is connected to my MacBook Pro via Firewire. When I plug a secondary display in, it makes lots of extraneous noise, even worse if the PSU is not connected to the MacBook Pro. What is causing this?
Is the noise a constant hum? If it is such a noise, I suspect a faulty or poor performing power supply. Check the power supply that powers Edirol sound card for any improper ground. Another custom made power supply which is properly regulated (voltage) and at a higher ampere rate would be an idea to consider. I think your main issue is grounding because you say the case become worse when the MacBook PSU is not there. Because, you are loosing a ground path when you remove the PSU. Then it solely depends on the Edirol ground path. If that path not a good source of ground, there lies your problem.
3helpful
MacBook Air sound/disappeared
This is a widespread hardware issue with the MacBook Air. You are not alone. See:
http://discussions.apple.com/thread.jspa?threadID=1736638&tstart=15
Some users report that replacing the Audio Board Flex Cable corrects the problem, but others report that the correction is only temporary.
If your machine is still under warranty, I would get it back to an Apple repair facility immediately. If it is not, you will still need to get it to a repair facility, but bring along the above URL and suggest that Apple treat it as a warranty extension issue.
2helpful
2answers
Loud air sound
If there is an engine code po410 you have problems with your airpump. There are bulletins out on this situation.
My dryer make a buzzing sound when i push the start button--sometimes it'll work but most of the time it won't
motor issue or start switch on the dryer
wiring issue to the dryer at the cord connection on back of dryer
cord plug in recepticle
loose wire at breaker
bet motor issue
2answers
Laptop keeps shutting off,battery is not on electric cord is connecting.. cord has a slight buzzing from the square is this normal..and i cannot use my usb ports
"Buzzing" from the brick generally means the fields are breaking down. This could also cause a problem to the main board.
Sometimes Radio Shack has the IGO Universal on sale, I paid $28.95 for mine with 8 different tips.
As far as the USB, the northbridge chipset should be updated, google the north bridge after installation and running
Also if the USB's bus is not operating, check the pcmcia card bus, if you install a wireless card or cardbus usb adapter and it hangs you have a motherboard chip issue.
Sound Problems
Here is the update from apple on this issue.
http://www.apple.com/support/downloads/audioupdate2007001.html
2helpful
2answers
Lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
6helpful
5answers
Sound not coming out of speakers
just remove the cord from CPu...the sound cord and re-plug it and try the option line out or line in...
otherwise simple way is that...check wheter there is sound installed in Control panel under the add or remove program tab....
if not,then install the driver from *********** Board CD..
simple restart the PC it is required..
and for more queries post it on..
www.vk7.weebly.com
under the guest book..
i will sort it out as soon as possible..
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
