Question about Coleman Heating & Cooling
Split system AC has pungent brussel sprout odor
We have an old Coleman split system HVAC in our trailer. The heater & fan work fine, without odors or problems. But our AC is very weak & after it runs for 10-15 mins, a pungent smell is produced, comparable to brussel sprouts or rotten eggs. We have brand new ducts, as of 6 mos ago. We replaced the filter & cleaned the coils, but the smell still persists. There is no condensation, if that means anything? We are going to go to Home Depot to get some coil cleaner stuff today. We live in Phoenix & we need our AC already! Our trailer heats up fast, our thermostat reads 90 by 2-3pm! Any tips?
    New Friend:
  • 84 Answers
Clean well all the small drainage with bleaching liquid and soap it with scented soap.also at the back of the unit that are having small drainage and through the drain hose
Posted on Apr 23, 2014
  • 400 Answers
SOURCE: Evcon AC (heat pump) leak in indoor coil
Most refrigerant leaks can be repaired. However, if the leak is between the aluminium fin plates, I would have to agree that it should be replaced. They are correct that you cannot after fifteen years find either an indoor or an outdoor unit seperately and the whole unit would need replacing.
Posted on Aug 11, 2009
  • 147 Answers
SOURCE: heat controller mini-split air conditioner
Check each screw on your compressor to ground (compressor case). Should be very high resistance Then check the resistance across your teminals on the compressor to be sure it is not shorted. Then check the wiring to your capacitor (The big one). I ran across this just last week. The mechanic didnt have the capicator wired correctly. If it is brand new it will have a wiring schematic somewhere on it.
Dont leave the compressor on very long, but turn it on long enough to get a voltage reading across the terminals. I assume it should be 240 volts. If you have check all of this, they make a jump start gadget to start a stuck compressor. They sell it just about everywhere. Let me know how this comes out..
Posted on Sep 30, 2008
SOURCE: Compressor kicks out and it's new
First of all, clean your outside coils so that you are assured of good cooling air. The compressors have an overtemp device that is usually internal to protect them against heat. If you have an air compressor use it to blow out the coils good. If the compressor will start, the capacitor is good so it sounds like a cooling problem with the compressor
Posted on Jun 25, 2009
  • 45 Answers
SOURCE: My Lennox HS22 series split system scroll compressor overheats
There couild be a small blockage in the refrigerant piping. This obstruction could be cyling through the system and causing the pressures to increase and decrease which is overheating the compressor. Normally when the compressor is overheating there is not enough refrigerant getting returned to the compressore to keep it cool while running. When it shuts down the the refrigerant equalizes which can return the blockage back to the coil or just simply dislodge it frome where it is hung up. When the compressor returns to its running temp, it turns back on and can cycle that blockage through the refrigerant piping which sometimes it may go thru and sometimes gets hung up and clog the system again. I would have a certified technician come over and hook their manifold to the system which can easily tell them if there is a blockage or he can trace the problem. Do you know what type of metering device is in the coil inside?
Posted on Jun 06, 2010
Testimonial: "Thanks Terry I did refrigeration for over ten years but got out of it 15 years ago...It took a while for my brain cells to click.I didn't think about the blockage which still may be a possibility. My pressures were a little low for my ambient temp so I added some freon now I have a good sweat back to the compressor and it has been working good for the last 3 hrs...the temps outside are supposed to hit the hi 90's and I will keep an eye on my head pressure.it is a split system and I'm getting some sweating at my txv..that is were the restriction usually happens.I used to get a lot of cap tube restrictions in small systems.thanks for the help."
sloooo44
  • 235 Answers
SOURCE: Our mitsubishi split system heat
Usually if you get a musty smell, the unit is short cycling. This means the compressor is coming on, then turning off for a couple minutes, then coming back on. The best way to tell if this is the issue is to turn the unit way down stand outside and see if the compressor is turning on and off. If it's staying on, let me know and we will go from there.
Posted on Sep 28, 2010
Air Con
no the pipes should not be cold and wet but if you just have stop using the aircon recently it will do that for a while till all the gas is out of the system so yes its sorta normal
Oct 02, 2008 | 2001 Chrysler PT Cruiser
4322 coleman furnace
Check electrical xxxxxxxxxxxxxxxxxxxxxx
May 23, 2014 | Coleman Heating & Cooling
2008 impala, terrible nauseating odor from heater
sounds like a mouse nest in hvac system, no smell because when using ac it doesn't use outside air, probably a nest on the screen at the hvac air intake or if you have a a cabin air filter check in there. many times rodents make nests have babies and then the car moves and they cannot feed the babies and so they die and rot smell comes into car. usually it is not hard to access because there should be a screen between the outside and inside under the cowl cover, if no screen and the little buggers vot into your hvac duct system this could be a much bigger problem entailing removal of dash completely. most likely this isn't the case, good luck
Feb 11, 2014 | Chevrolet Impala Cars & Trucks
I have an Air-con air conditioner and heating system
Check your filter, if it's clean check the condensate drain to be sure it's draining if ok your system has a leak and will need an ac tech to repair and recharge the system
Nov 28, 2013 | Air Con 9,000 Btu Split ditioner Wall...
Ac not workng
The musty odor is moisture in the HVAC box. Someone needs to check and see if the system is full of freon, then check the circuit going to the ac clutch for power.
Jun 12, 2013 | Cars & Trucks
When I run the air cond there is a unpleasant odor the we smell. The unit has not been used for a 3 years. Any thing I can do to get rid of the odor. can I clean something ? Change filter ? Ron
Definately change the filters, but im sure there will be an odor from sitting around. Clean the evaporator coil , not with high pressure wash, dont wanna damage the fins, they sell cleaners at HVAC suppliers. That should do the trick
Aug 13, 2009 | Coleman Heating & Cooling
Sour Vinager odor in vents when using AC in a 2003 325i???
milk may have been split in the vents
it goes very sour & vandals sometimes do it on the street!
Jul 20, 2009 | 2003 BMW 325
Odour from ac
There is a problem with heat pumps known as "Dirty Sock Snydrome". Research this on the web as this may be your situation. It is a smell produced by micro bacterial growth on indoor coil. Contact a local HVAC company for solutions if you determine this is the cause of odor.
May 22, 2009 | Hitachi RAS-09UH Air Conditioner
Sony SDM HX73 LCD screen - pungent odor bugging me
If the monitor is working well you need not worry. If any electrolytic capacitor burst out this type smell may come.
Dec 10, 2007 | Sony SDM-HS73P 17" LCD Monitor
Heating & Cooling Logo
127 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
