Question about RCA Tablets & eReaders
Water dropped in water
I have had my tablet less than a year an the screen broke is that coverd withe the one year replacement
damage do to mistreatment, dropping , water immersion etc is not covered by warranty
take it in to a repair shop and see what can be done under warranty or otherwise
Aug 19, 2016 | Tablets & eReaders
How do i fix my nextbook tablet when it has been dropped in water
I hope it was clean water! You should be able to pop the screen off by using a knife on the edge and gently pry all the way around until the screen comes loose, then dry out. Whenever anything electronic is soaked in water, the first thing one should do is disconnect the battery; too late now, but perhaps it will not hurt. If power is connected, electrolysis takes place which can ruin the circuit board and/or components. Dry naturally, or with a hair dryer (not a lot of heat), and you may be okay. Do not power up until it is completely dry. I hope this helps. Good luck and God bless you.
Feb 09, 2015 | Nextbook Tablets & eReaders
Tablet discharging
Probably a faulty motherboard. How old is your tablet?
has it been dropped in water or has water entered it by any means?
Sep 02, 2014 | AOC MW0811 Breeze 8Inch Tablet PC Black
Kobo help
Clean water, I hope, otherwise chances are much worse. DON'T turn it on. Pat it dry as much as possible, then completely bury it in a sealed jar of uncooked rice for maybe 3 days. After that, try turning it on. If nothing, try charging for several hours. If still nothing, sorry!
Aug 11, 2014 | Kobo 6" eReader Touch Edition
I droped my andrid tablet in water how do i get it to work agan?
If after going in the water it failed, it is time to buy another. The thing to do with any phone or tablet etc after being dropped in water is to get the battery out as fast as you can. Obviously that is very difficult to do with a tablet.
They are not designed to be repaired, being most of them bonded together, and although you can get one apart with some difficulty, you will find repair uneconomical now.
Aug 09, 2014 | Android 7 inch Tablet
How to fix kurio 7 after dropped in water?
This is probably water damaged. You MIGHT get lucky with keeping it (powered off) in a bag of rice to wick the moisture out of the tablet and into the rice. Keep it there for a few days to keep it from getting damaged any further.
Jul 15, 2014 | Kurio Touch 4S Handheld
Dropped water on
may be fried.... got insurance? warranty for spillage?
Mar 13, 2014 | Amazon Kindle Fire HD
Kindle fire hd got wet
It's a delicate electronic device. It's not designed to survive this. Sorry.
Jan 19, 2014 | Amazon Kindle Fire HD
My kindle wont turn on
If the kindle won't turn on because it was recently dropped or water was spilled on it or something, you should consult your warranty. If this is due to no external event/damage you should call amazon and see whether or not there's an update in software or a bug of sorts. If it's on their behalf you'll get a replacement device. Good luck!
Mar 06, 2011 | Amazon Kindle 1
Tablets & eReaders Logo
24 people viewed this question
Top RCA Tablets & eReaders Experts
Christoverre Kohler
Christoverre Kohler
Lawrence Thornton
Level 1 Expert
Are you a RCA Tablet and eReader Expert? Answer questions, earn points and help others
