Question about Ruud Heating & Cooling
Ruud UAKA-030JAZ fan spins, not blowing cold air
I have a 15 year old Ruud UAKA-030JAZ unit, the fan spins, but I don't get cold air in the house. The fan outside is blowing cold air instead of warm air, and the pipe running from the unit isn't warm at all. I have a second unit (for upstairs), everything works fine. I replaced the run capacitor on the unit in question - same result. There is a Supco hard start boost on the unit, but I don't think that's the issue. Fan spins freely - nothing blocking it or anything like that. I had a contractor out at the end of last season, he put in a replacement contactor, I suspect that's the problem. The unit worked until end of season, then I turned it on this past week - worked for about 1/2 hour before I noticed it wasn't blowing cold again. I'm frustrated - the contractor has been here 2 times, and keeps telling me I need a new unit. I'm pretty sure that's not the case, but I'm flummoxed on what's wrong. Thanks in advance for any / all help!
  • rjdee Apr 17, 2014
    I should have mentioned that I did check the circuit breaker - everything is fine there. This is also a no fuse disconnect, so no issues there either.
    New Friend:
  • 84 Answers
There are 3 things to be considered,first,if the compressor motor `s connectors are having loose,it gives a hi ampere to your RELAY that can cause to its contacts being fried,second,the compressor motor itself is gaining a hi ampere already i.e. having unusual sound that can cause heavy friction inside the turning mechanism and third the last but not the least,maybe this time,the tubes or the compressor itself having very small holes that causes to the refrigerant to escape and it doesn`t gives off cold air.
Posted on Apr 23, 2014
watugot
  • 290 Answers
SOURCE: Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Posted on Nov 20, 2007
  • 37 Answers
SOURCE: Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Posted on Apr 25, 2009
  • 588 Answers
SOURCE: Kenmore AC compressor on and off while outside unit fan running
If the out door fan keeps running and the compressor cycles off that would be the overload in the compressor.
What keeps the windings cool is the refrigerant back to the compressor.
For the overload to cycle it would have to be either not enough cooling back to the compressor or high amp draw, which could be the metering device (txv or orifice) or low on charge, or other things would be a bad capacitor, sometimes a bad start relay not staying open, when compressor gets up to speed or anything causing the compressor to draw high amps.
To check the refrigerant, he needs to check the superheat at the compressor it should be appoximately 12° to15°, and next time the compressor goes off if you shut the power off and feel the top of the compressor and if it's hot 130° or higher it's probably refrigerant.
Posted on Aug 19, 2009
  • 133 Answers
SOURCE: Just cut on 8 year old Goodman CPLE24-1 AC for the
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know.
I think I have it covered above. Let me know if you need something more specific. Thank you. Roger
Posted on Apr 12, 2011
  • 2006 Answers
SOURCE: Central Air unit fan inconsistent
Those symptoms sound like a contactor - ralay not closing properly or the capacitor. In most situations, I would recommend they both be replaced, since it seems they fail close to each other.
Posted on Jul 26, 2011
Where can I purchase a run start capacitor for a RUUD air conditioner model # UAKA-030JAZ
Most big box stores do not carry these type of parts.You are supposed to be a licensed contractor to buy at a heating & cooling supply company. Not knowing were you live I can not recommend a supplier. I am in the Cleveland Ohio area. If you can not find it locally I can ship it for you.
Jul 04, 2014 | Ruud UAKA030 Air Conditioner
I have a 15-year old Ruud Achiever 10 A/C unit outside that has blown a second set of fuses in just a month. The fuses are in the box on the wall adjacent to the unit. What may be causing the fuses to...
A BAD RUN CAPACITOR INSIDE THE CONDENSING UNIT ?.SEARCH YOUR AREA FOR FREE CAPACITOR TESTING.OR LOCAL ELECTRIC MOTOR REPAIR.. CHECK THAT FAN SPINS FREE, IF NOT, IT CAN BE OILED .. SEARCH POST ON OILING FAN MOTORS
Jul 26, 2011 | Ruud Matching Split Air Conditioner
Model UAKA 030JAZ was working fine. Now, the compressor fan does not come on and neither does the compressor. I don't know how the contactor works but it is not engaging (the spring loaded contacts are...
Hello
You need to complete the 24 volt circut from the themostat to the transformer to get the contactor to pull in.
Check for voltage at the transformer,should be 120 v in 24 volts out.Also there may be a small reset button on the transformer.
Apr 18, 2011 | Ruud UAKA030 Air Conditioner
I am trying to find a parts list for a RUUD UAKA-030JAZ air conditioning unit (specifically the compressor/condensor contactor).
RUUD will only sell there factory parts to certified contractors. My advice to you is to find a local HVAC parts distibutor that will sell you generaric parts which will work just as good as the factory parts.
Jun 23, 2010 | Ruud UAKA030 Air Conditioner
We need an owners manual.
Hi, looks like you have a 21/2 ton Ruud split system by the numbers. Let me look this up and see if I can find a manual for this unit and send you a link to down load it. Give me sometime please. Be back soon.
Shastalaker7
May 08, 2010 | Ruud UAKA030 Air Conditioner
Unit three years old. came home yesterday and
Check your circuit breaker for the outdoor unit,seperate from the furnace.
Sep 09, 2009 | Ruud Heating & Cooling
Have a Ruud Achiever Model number UAKA-037JAZ that won't run since yesterday. When the air kicks on it simply makes a buzzing noise and the fan doesn't spin. Can anyone help?
try spinning by hand when the unit make the buzzing sound. to see if the capacitor is bad. If the fan runs replace the cap. If not motor probably is bad. See if it spins freely. this is a good starting place. need to check if the buzzing is the contactor and there is no power to the condensor. The contactor will buzz even though the main breaker is off or tripped
Aug 10, 2009 | Ruud UAKA037 Air Conditioner
My unit is 9 years old Ruud RCGA-60AIGH24B seems
It's possible that there is gas leak causing part of the coil to freeze. The cost will depend where the leak is.
Jul 12, 2009 | Heating & Cooling
Not blowing cool air on my Ruud, 18 years old, outside unit.
If you have ice on the Line you are iced up. If coil is iced no air can get thru. Now First. Turn of ac and turn fan to on posotion. That will thaw unit. Let it run 45 minutes. That should do it. If the fan is not running you amy have a bad fan relay. One of the reason iced up unit is dirty evap, coil inside. Try to thaw it out first. You can clean the coil with a stool brush. Does not damage the coils. Good luck
Jun 07, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
211 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
