Question about Haier HDP18PA Stainless Steel Free-Standing Dishwasher
New haier dishwasher wont drain
Washes but will not drain
3 Suggested Answers
SOURCE: pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Posted on Jan 05, 2009
  • 17 Answers
SOURCE: Haier dishwasher wont run and shows a code OP
The code "OP" means the door is open. I would suspect you have a faulty latch. The dishwasher thinks the door is open and will not start the cycle.
Posted on Aug 02, 2009
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
HAIER ENCORE WASHING MACHINE MODEL GWT750AW WONT DRAIN
Most likely pump but could be logic board not calling for machine to drain.
Nov 20, 2014 | Haier GWT750AW 4 Cu. Ft. Encore Top Load...
Our Haier HDC1804TW counter-top dishwasher does not complete the washing cycle. It stops after 90 minutes which should be 115 minutes for heavy washing according to the manual. The washing light is...
Since mine does the very same thing, it's my guess that is the sterilising cycle as by this point it has already washed, done a short fill to remove any remaining detergent, and two rinses. I'm also assuming the second short fill is just to cover the heating element and/or to to generate an amount of steam having being heated by the element (I'm basing that assumption on the heat of the dishes at the end of end of the cycle and the heat of the water when it drains)
Mar 05, 2011 | Haier HDC1804TW Dishwasher
This thing has never drained properly. You have to hit the cancel/drain button a few times for it to finally drain. I don't think it drains completely after wash and before rinse because everything comes...
If its never drained properly, then perhaps it was installed incorrectly. Check that the drain hose goes up and over the machine before connecting to the homes drain pipe.
Jun 15, 2017 | Haier ESD210 / ESD211 Built-in Dishwasher
Brand new dishwasher will not drain at end of cycle.
Check your manual. Some dishwashers actually do leave water in them after the final drain cycle. It has to do with the type of seals they use. Some will leak the very first time they are used but not after that. The seals in these types must remain wet. If this isn''t the issue, wait about 5 minutes fir the timer to finish. Sometimes there is quite a lag at the last cycle. If all else fails, call the customer service number in the manual.
Feb 02, 2009 | Haier ESD300 / ESD301 Built-in Dishwasher
Haier countertop dishwasher will not empty
There is a filter at the bottom of the tub that has to be cleaned out once in a while. Then it will drain. This should help. It is a plastic looking mesh filter most can be removed and hand washed. Hope this helps.
Jan 18, 2009 | Haier 17 in. HDT18PA Built-In Dishwasher
All 4 lights on my haier dishwasher Model CG206B blink and beep.
I had the same thing the drain hose was plugged.To reset You have to tilt the washer back 45 degrees.Mine is now running hope this helps.JIM
Jan 04, 2009 | Haier ESD200 Built-in Dishwasher
Pump not draining - Haier portable dishwasher
Feb 03, 2008 | Haier HDP18PA Stainless Steel...
Haier HDP18PA Stainless Steel Free-Standing Dishwasher Logo
24 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Tom Chichester
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
