Question about Orbit Underground 57896 6 Station In/Out Timer
No AC fault in Orbit Sprinkler Timer Model 57896
I have recently acquired an Orbit Sprinkler timer (Model 57896) to be used in Europe (Spain) and it seems to not work properly. I am using an external transformer (220V to 110V) to adapt to the unit current requirements (110V AC). When I plug the timer, the display keeps on showing No AC all the time, as it is not detecting proper input voltage. Find the type of transformer I am using into the following link: http://www.ebay.es/itm/191038554056?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_4784wt_1238 The item was delivered with a 3 V battery, which is working well. I have checked it with a multi-meter and it is fully charged (3,2 V reading). I can change whatever I want into the timer interface. The terminal by using the battery energy seems to work perfectly. I have tested the timer with one new watering valve connected. It does not work (the valve is not activated from the timer). After connecting the valve terminals to the timer the display keeps on showing No AC. 3. I have checked the voltage in the following points: a. Plug in my voltage house connection: 220 V --> OK b. Output of my external transformer 115 V --> OK c. Output of the Orbit internal transformer (in the terminals of the integrated circuit): 24 V --> OK There is a reset button on the front of the unit. I have pushed it several times to reset the unit, but no change. The unit is provided with several external connections: - Up to 6 terminals for 6 possible stations (valves). Either cannot be activated. - 1 terminal for an external pump. It cannot be activated. - 2 terminals for rain sensor (the unit was provided with a bridge in such terminals to by-pass it). - 2 terminals for 24 AC Output --> The reading of this terminals shows 24 V AC when the unit is plugged, despite the unit is still showing the No AC message. I presume that these terminals are aimed at being used for any additional external device, like a master valve. What is going wrong ? Is Orbit recommending using an specific transformer (220V to 110V) for EU regions ? I would appreciate if you can give me advice to fix this issue. Thanks upfront, Kind regards, Jordi Alfonso
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 71 Answers
Call Technical Support at Orbit. The 800 number should be listed in the instructions.
Posted on Apr 18, 2014
We have had it for 2 years and it just stopped turning on. I have tried reprogramming battery good what else can I do?
Pull the dial toward you.
Line up the correct time of day to the arrow.
This may help in the event that the power went out at some point.
When that happens,
it changes the time when your lights turn on & off.
Apr 15, 2015 | Orbit Underground 57896 6 Station In/Out...
Wiring new sprinkler timer one wire on my old
Just cut the common wire and put one end in each of the 2 pins. The rain sensor just interrupts the signal to the valves when wet.
Nov 04, 2013 | Orbit Underground 57896 6 Station In/Out...
Orbit timer 57899 no AC
Transformer is probably burned out. If it is a indoor timer buy a new 24V transformer. If it is a outdoor timer buy a new one.
Apr 28, 2013 | Orbit 9 Station Super Dial Irrigation...
Where is the fuse on an orbit model 57896 sprinkler
The fuse is the 120 volt circuit breaker.
Check outlet for power.
If outlet is outside, it should be on GFCI, which might be located in kitchen or bathroom or garage.
Use circuit analyzer on outlet to check for correct polarity and ground.
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Sep 24, 2012 | Hardware & Accessories
Need instruction manual for orbit sprinkler timer model 57196
Copy following link for Orbit Sprinkler timer manuals
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=01&Type=Timers
Copy following link for various brand name sprinkler timer manuals, including Nelson, Melnor etc if you need new timer
Sep 10, 2012 | Hardware & Accessories
I have city reclaimed water source for my sprinkler system. My problem is I connected the waterlines to the solenoid (1) and then the zone index valve (4 zones ), then i wired the solenoid to my spr
What model number of timer? I have to see exactly which timer you have to answer question.
What wire goes where?
Are you using 120Volts?
What is output voltage of timer?
What voltage is solenoid? 24Volt or 120Volt?
Copy following links for Orbit manuals:
Aug 09, 2012 | Orbit Hardware & Accessories
Directions for GreenThumb watering control by Orbit model 27157
Copy following links for Orbit timer manuals & sprinkler timer manuals
Jun 08, 2012 | Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Orbit Model 57896 I can only get 4 stations I seem to have lost two that I did have.
Try removing the battery, unplugging the timer, plugging the timer back in, pushing the reset button (if you can find it) and try reprogramming for all 6 zones. Post again after trying.
Gary
Mar 15, 2011 | Orbit Sprinkler System Power Source...
Orbit Underground 57896 6 Station In/Out Timer Logo
772 people viewed this question
Top Orbit Garden Experts
squeely
richie46
Are you an Orbit Garden Expert? Answer questions, earn points and help others
