Question about Maxtor Hard Drive
Maxtor 6Y160MO always tunrs off and it takes time to spin when I want it accessed
I have two hard drives in the Vista system
C: runs the OS
D: stores the data
The D drive Maxtor 6Y160MO always turns off and it takes time to spin when I want to access it. It only spins for few seconds and then it turns off again. There is no setting in Vista to control this behavior. I thought that the “ALWAYS ON” option would control this but it doesn't.
Any ideas?
  • Karel Grulich
    Karel Grulich Nov 02, 2007
    There is only one option to select under the Advanced settings for I guess all the hard drives. I'm using the High Performance plan which should keep the PC on all the time. Under the advanced settings, the hard drive to turn off is set as 20 minutes. Even if I change this to a higher number or never the same problem remains and the hard drive turns off after few seconds. The C drive is OK.
  • 244 Answers
Maybe you turn-off the hard drive at your power scheme on your screen saver.
Posted on Nov 02, 2007
Maxtor Personal Storage 3200, after years of use my Vista machine now tells me that the USB Device isnt recognised.
However last month I found that the Maxtor is no longer recognisable to my machine. Reading through related postings on other sites it appears that Vista updates from Microsoft may be the reason why this functionality has suddenly ceased. I presume the security updates in particular may have meant that the Maxtor 3200 is also considered a potential threat. The question is who will take responsibility for resolving this issue of Maxtor 3200 users no longer being able to access their back up files via their Vista based machines. Personally I believe the onus is with Microsoft
hope this helps
Feb 24, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
My maxtor external hard drive disc is damaged and I am unable to access my hard drive. I am running windows vista home premium OS. my computer does and recognize it ... do you have any suggestions?
bring it to the hard drive technician so they can fix it...but if it really damage,you have to buy another hdd the supports your machine,so you can work with it
Feb 10, 2011 | Maxtor Hard Drive
I have a Maxtor External Personal Storage 3100.
Here is a link to the Maxtor install guide for your drive. From what I can see there are also some diagnostic tools however / the listed supported OS does not include Vista but - if your running Vista 32 bit OS - try the XP tools. Affraid to say though it may be time for an upgrade.
Jan 29, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
Does it give you an error message ? Are you running Windows XP or Vista? If so post it here so the problem can be further narrowed down.
You might want to try a chkdsk.
In Windows XP and Vista both, a shortcut to get to the command console is holding the Windows Key and pressing R.
in the command console, type:
chkdsk X: /f /r
Where X is the drive letter of the drive giving you problems.
This will run a chkdsk on your external, restoring files and folders that cannot be accessed.
I also have a Maxtor External hard drive and have to do this quite often. It's pretty frustrating.
Apr 04, 2009 | Maxtor 160GB OneTouch III Mini USB 2.0...
The hard disk in drive D: is not accessible
Hope I can help you with your problem. If your hard drive was installed to be used as D: in your old computer then you will have to set it up to be D: in the new computer. This may be why it is not being recognized. You can do this by connecting it as a slave on the primary IDE cable.
Also you will need to check the jumper on the hard drive to make sure it is set in the slave position.
Dec 03, 2008 | Maxtor Hard Drive
My computer will not recognize my maxtor personal storage suddenly when it has always worked before.
My Maxtor 3100 did work with my XP widow machine at one time. But suddently my computer doesn't recognize the USB connection. How do I fix this?
Nov 09, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
Computer not recognizing my Maxtor hard drive
Andrew, That Maxtor drive sounds like it has finally died on you and being just an 80 gig drive means its really old. The systems failure to read the drive as your booting up is what's causing the long boot delay as the system will see the controller board of the drive, but your spindle motor on that drive is most likely dead and there fore you will not be able to access or read any of your data stored on that drive. Hope you had backups of important files.
Apr 15, 2017 | Maxtor OneTouch A01B080 80 GB Hard Drive
Maxtor One Touch III mini drive problem
Please connect your hdd and go to disk management right click on my computer on the desktop g to manage and iskmanagement ..
check your hard disk is listed there or no if yes check it have drive letter if no please right click and add drive leter.if its there then check it has a format like it writng ntfs or fat32 if there then rigt click on the left hand side pan and say reactivate if still dosent work may be u need to format it. or use a third party software like hard disk regenerator or mac disk worior...
Jun 01, 2008 | Maxtor OneTouch III Mini Edition (R01E100)...
Maxtor Hard Drive Logo
218 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
