Question about Kenmore 30" Microwave Combination 721.85033111
Fan not turning off. Microwave shutting off
The fan goes on by itself then won't turn off until unplugged. the microwave shuts itself off after a few seconds.
  • 9 Answers
SOURCE: Kenmore 665 68610891- built-in 1998 model
Fan relay on circuit board stuck. Give it a tap (the relay), to free it up. Otherwise get the relay or driver transistor replaced. Easy fix. Take it to an electronic repair place, not the brand agent.(They,ll just replace the whole board).If this Item is under warranty you should not be wasting my time.:::Spiceweasel.au
Posted on Apr 04, 2008
  • 107 Answers
SOURCE: Microwave hood # 721.80833500
One of 2 things are happening..One of the thermo protectors has a bad connection (Kenmore is good for these) or the Magnetron has a leak inside the control cavity causing a temporary short in the control.
Posted on Mar 13, 2009
SOURCE: FAN WONT SHUT OFF
My Kenmore microwave oven fan has been turning on and off, almost every hour. Sometimes 3 or 4 times in one hour. It's very random. Model No. 721-80593401 Serial No.503TA03208
Please help!!!
Posted on Nov 09, 2009
SOURCE: Kenmore 721 microwave fan turns on by itself
I have the exact same problem with my Kenmore Microwave model 721 that we bought in October of 2005. The Fan will just randomly turn itself on even when we are not cooking. It has been doing this for the last few months and is starting to become more frequent. There is no way to turn it off except to unplug it for several hours.
Was there a recall for this defect ?
Posted on Sep 28, 2010
  • 6771 Answers
SOURCE: why won't my kenmore microwave's exhaust fan turn off?
It is more than likely one of the door switches has malfunctioned, or there is a problem with the keypad control board.
Posted on Apr 19, 2012
I have a Kenmore microwave. The vent will just start on its own and can't shut off
Actually, that's a feature! If you cook much on the range (stove) beneath the microwave, the heat will cause the microwave bottom to heat up quite a bit (just touch it!), and the microwave will turn on it's exhaust fan in an attempt to save itself from burning up. It will shut off in about 15 minutes after you turn off the source of heat.
But if the fan comes on by itself even when the microwave is cool (or at least not hot), then you probably have a defective fan thermostat. This thermostat is located behind the control console on the inside bottom of the microwave.
Aug 27, 2014 | Kenmore Microwave Ovens
Dacor Microwave DCM24S cooling fan continues to run
follow this steps and fix it. God bless you
  1. Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#9#ixzz2aNH65mG4
Jul 27, 2013 | Dacor DCM24SS Convection Microwave Oven
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
What causes a Samsung Microwave exhaust fan to turn on by itself?
mine turned exhaust fan on automatically... i couldnt shut it off... had to unplug it.... no buttons worked.
Aug 29, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
Frigidaire Microwave Fan won't shut off plmv169dcd
Had the same issue, leave Microwave unplugged for 30 minutes and then plug back in. My fax stopped blowing and now fucntions 100% normal again HI/LO / OFF
Best of Luck!!! :)
Jan 17, 2010 | Frigidaire PLMV169DC Microwave Oven
Fan does not shut off unless unplugged
If the light and fan come on when the door is opened normally, check the door switches.
May 19, 2017 | Kenmore 80809 Microwave Oven
GE Microwave Profile Spacemaker Runs on its own
Your microwave turning on by itself is a "self preservation feature" of the GE Profile Advantium and maybe some other models. Read the manual, When your over the range oven gets warm enough, for whatever reason the venting fan comes on until a satisfactory oven temperature is reached. You are not permitted to shut the vent fan off. Also it seems a temperature near room temp must be achieved before it shuts the fan motor off, it is very annoying. We had to return our Advantium because of fan noise. I configured the ovens vent fan to the recirculate direction because we do not have a vent duct that exits the house over our range. When the vent fan acting as the ovens cooling fan automatically turned on we would have to leave the house to hear each other talk. Too bad we really liked the oven other than that major problem. G-Man
Apr 19, 2009 | GE Profile Spacemaker Over-the-Range...
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Mar 30, 2008 | Kenmore 80809 Microwave Oven
Kenmore 30" Microwave Combination 721.85033111 Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
