Cell Phones Logo
Anonymous Posted on Jun 19, 2009
Wap and internet settings for Siemens M75 ... in NZ
Looking for correct profile settings for wap and internet and the linking settings to link the profile to service ... or how do I set up this phone so it can get data via GPRS
Cheers
Andy
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
301
Points
There is a lot of information on the vodafone site. It takes a bit of finding but you can get to a page which sends a data message that automatically updates your phone when you accept it. I have done this to set up the pxt functions. The only options available are for the m65 and those worked
3helpful
I lost my bsnl gprs setting .how can i get again. because i don't know bsnl customer care number
if your are using net through USB moden just type any name in connection name. leave other places blank. and in apn type bsnlnet this will work
for mobile
GENERAL PHONE SETTINGS FOR GPRS
1. Setting APN : First we have to set one APN each for Internet and MMS respectively.
(Access Point Name) - for Internet set ( www.e.po) and for MMS set (mms.e.po)
2. Setting WAP Profiles : Now we need a WAP PROFILEwith WAP GATEWAY (192.168.81.163)
3. Creating Bookmarks : Now we need some BOOKMARKS of WAP SITES for Internet Surfing.
4. Settings for MMS : Different Handsets have their respective MMS Settings where we
require MESSAGE SERVER / HOMEPAGE and this is set as follows : http://192.168.81.166/servlets/mms
still helpless..
click on this link
http://www.bsnl.co.in/service/mobile_gprswap.htm
tip
Restore WAP, 3G, MMS Settings | Sony Ericsson Phones
Many people are having problems configuring their phones after de-branding or after flashing it. Usually after de-branding your phone you lose all the WAP, Internet, MMS settings from the phone. And you won't be able to send MMS or browse Internet.
For MMS and WAP to function properly, you should first create Data Accounts in Phone Settings and Then create Internet Profile and MMS profiles which make use of the Data Account. For manually creating these accounts and profiles you will need a lot of technical information from your CellPhone Service Provider. You will need to know the APN, Proxy Address if any, Username and password settings. Hence the idea of manually setting up is not recommended, unless you have spare time to figure out things.
You can directly download WAP and MMS settings for your phone from local Sony Ericsson Website. Visit SonyEricsson.com. In support section specific to your country, you will find links on how to configure Internet and MMS. Visit those links, You will be asked about phone model and operator name ( like Vodafone, Airtel in list), Select your operator and provide your cell phone number. You will be given a authorization code, and in a few minutes Sony Ericsson will send you the Internet/MMS settings directly to your phone. Enter the authorization code in your phone. And MMS, WAP, 3G and Internet settings will be installed correctly. All operator based services should then work fine.
Thank you for using FixYa!, Keep visiting..
Concerned, Nooh.
on Jan 23, 2011 • Cell Phones
13helpful
3answers
How to open smart gprs for my samsung star?
hi, if you are from philippines, you would want to do this... press message, then type this to your keypad. for SMART Internet settings,  type SET INTERNET  S5233 and send to 211, wait for configuration and install it to your phone.  go to your menu, press internet, select settings, select browser profiles, press the double arrow or >> to edit the acount, scroll down and select advance, check your static DNS to enable it and type the following server address to your server 1 ; 202.057.096.003 press save and exit the settings.
to configure your samsung star for wap or gprs,  you can do the same thing, type in your message SET GPRS S5233 and send to 211, wait for configuration, save it and make it as default browser profile.
if you want you can also do this manually.  1.   press menu 2.   select internet 3.   select settings 4.   select browser profile 5.   press create on the following boxes type this SET NAME ; SMART WAP BEARER TYPE : UMTS/ connection less (depending on your network) ACCESS NAME: WAP.SMART.COM.PH AUTH TYPE : NORMAL user id : smartwap password : smartwap protocol : WAP home url : www.smart.com.ph/wap proxy address : leave it blank linger time: leave it as it is press advance settings : check static ip address input this 10.102.61.46 leave static DNS. or if it ask,  check it and input 202.057.096.003
1helpful
My internet is not working on my phone and i have 2 mms' that i cant retrieve i have been on the vodafone site and tried their settings but it still wont work.
In order to use the Mobile Internet and services such as picture messaging you are going to need to configure the phone you can do this a number of ways, I have included a link to the auto configuration on Samsungs website where the Internet and MMS can be setup quickly and easily. I have also included the manual configuration below if you have any issues.
Setting up WAP
1. Press menu
2. Scroll to and select Settings
3. Scroll to and select Browser settings
4. Scroll to and select Profile Settings
5. Scroll to and select a free profile (e.g. Profile 3)
6. In profile name enter Vodafone Wap
7. In home URL enter the URL of the site you want as your homepage i.e.
http://live.vodafone.com
8. Make sure bearer is set as GPRS only
9. Set proxy to enable
10. Select GPRS settings
11. In proxy IP enter 212.183.137.012
12. In proxy port enter 8799
13. In APN enter
for Pay monthly customers: wap.vodafone.co.uk
for Pay as you talk customers: pp.Vodafone.co.uk
14. In login ID enter wap
15. In password enter wap
16. Press save
17. Press save again
18. Press Back
19. Scroll to and select Current Profile
20. Scroll down to your new Vodafone WAP profile and press select to activate it
Setting up MMS
1. Press menu
3. Scroll to and select Message settings
4. Scroll to and select Multimedia Messages
5. Scroll to and select Multimedia Message Profile
6. Scroll to and select a free profile (e.g. Profile 3)
7. Press Options
8. Scroll to Edit
9. In profile name enter Vodafone MMS
10. In Server URL enter the URL of the site you want as your homepage i.e. http://
mms.vodafone.co.uk/servlets/mms
11. Set proxy to enable
12. Select GPRS settings
13. In proxy IP enter 212.183.137.012
14. In proxy port enter 8799
15. In APN enter
16. In login ID enter wap
17. In password enter wap
18. Press save
19. Press save again
20. Press Back
Once you have followed either step you will then be able to access Mobile Internet and MMS fine.
or.....go to the following website and configure your mobile settings
http://www.samsungmobile.co.uk/supports/configurephone/wapSetting.do
2helpful
Internet and MMS settings for ATT carrier with unlocked samsung f-480
AT&T Settings
1) Start>Settings>Data Connections>Menu>Edit Connections
2) Open Dial-Up Connections. Delete all Orange Settings.
3) Open Proxy Connections. Delete all Orange Proxy Settings.
4) Create PROXY CONNECTION:
Description: mMode
Connects from: The Internet
Connects to: WAP network
Proxy (nametongue.gifort): 10.250.250.54:8080
Type: HTTP
Username: (blank)
Password: (blank)
5) Open GPRS Connections. Delete all Orange Settings.
6) Create a new GPRS CONNECTION
Description: ATT GPRS
Connects to: The Internet
Access point: proxy
User name: (blank)
Password: (blank)
Primary DNS: (blank...will later default to 0.0.0.0)
Secondary DNS: (blank...will later default to 0.0.0.0)
IP address: (blank)
7) DATA CONNECTIONS
Internet Connection: ATT GPRS
Work Connection: Automatic
WAP Connection: Automatic
Secure WAP Connection: Automatic
8.) In Internet Explorer, Menu>Options>Connections
Auto Detect Settings: Unchecked
Select Network: Wap Network
9) MMS SETUP.
Inbox>Menu>Options>Account Setup>MMS>Menu>Edit Connections.
Delete any Orange Settings that are there.
10) Menu>Add
Description: ATT MMS
MMSC Address: http://mmsc.mobile.attwireless.net
Data Connection: The Internet
Gateway: WAP 1.0 Gateway
IP Address: 10.250.250.100
Port: 9201
11) Click Done twice to return to the MMS Setup Screen
Server: ATT MMS
Download Messages: Automatically
Outgoing Message Size: Less than 100KB
Allowed Message Types: Personal
Click DONE.
Cingular Settings
WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to [email protected] (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to [email protected]
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to [email protected] (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
May 02, 2009 • Cell Phones
4helpful
I recently bought a P168C Unlocked Cell Phone from Ebay......
The most common cause is that the Data account for the GPRS data profile you are trying to use was never
configured, is configured incorrectly, or the proper GPRS profile was just never "Activated" under the WAP settings after the profile was
created. First go into the Data account services under the GPRS settings & make sure you have set up the correct profile for your
carrier. If it is set up, then edit the profile & make sure all the settings are correct as well as the spelling is correct. Then go into the
WAP Service settings & check to see that you have selected the correct SIM & correct profile, as well as Activated the profile. To
Activate the profile just select the correct profile from the list, and tap on the Activate profile bar. Also edit the profile to make sure
all the settings are exactly correct for your carrier, as well as the correct Data account (GPRS account) was selected for the internet.
Below is the Step by Step to set it up. Works if it is done exactly.
ATT Manual Set Up
WAP
***First Step***
11. Save
***Second Step***
Select WAP
Select back or done
MMS
Select Edit Profile
Select Done or Save
4helpful
5answers
Unable to get internet on i9 phone im with fido
Go to Main menu> Services>Data Account>GPRS
Select a profile and select "Edit profile"
Enter the following settings
APN: internet.fido.ca
user: fido
password: fido
Go to Main menu>Services>WAP>Settings>Edit profile
Select a profile and select "edit profile"
Enter in the following settings
Homepage: www.google.com
Data account: GPRS>FidoINT
Connection type: HTTP
user: fido
password: fido
Then to browse, Go to main menu>Services>wap>homepage
You may get an error "Unsupported scripts in content" Just click ok.
4helpful
5answers
Multimedia messages
try this menu then settings then connectivity then network then access point then new access point then fill in it is case sensitive so do it exact name: MEdia Net
bearer setting: gprs APN: wap.cingular user id: [email protected] Password: CINGULAR1 Primary server: 066.209.011.061 Secondary 000.000.000.000
then save it
then go back to menu then internet then settings then network profiles then new profile then fill in name: MEdia Net homepage: device.home proxy: on ip address: 066.209.011.061 port number: 9201 access point MEdia Net then save then options then activate
then menu then messaging then settings then multimedia then network profiles name:MMS homepage mmsc.cingular.com proxy: on ip address:066.209.011.061
port number: 9201 access point MEdia Net then save then activate you may have to highlight mms to activate .
This worked for me. Good Luck!!!
2helpful
3answers
Cect p168c iphone clone mms and wap settings for o2 uk
MMS
Select Edit Profile
Select Done or Save
Oct 25, 2008 • Cell Phones
1helpful
No internet
Internet Setting T-Mobile
T-MobileWeb Settings:
Primary IP Address: 216.155.165.050
Secondary IP Address: (Blank)
Access Point Name (APN): wap.voicestream.com
Data Bearer: GPRS
Profile Name: GPRS
Username: (Blank)
Password: (Blank)
Home Page: http://wap.myvoicestream.com
Picture Messaging Settings:
Multi-Media Service Center (MMSC) Address: http://216.155.174.84/servlets/MMS
Validity Period: 72 hours
Hide ID option (if option exists): set to off, no, or disabled
Internet Setting for Cingular:
Profile Name: Cingular
GPRS setting:
APN: wap.cingular
User Name: WAP @ CINGULARGPRS.COM
Password: CINGULAR1 (ALL UPPERCASE)
Time Out: Off
Primary Gateway IP: 66.209.11.61
Port: 9201
Secondary Gateway IP: 0.0.0.0
Port: 0
DNS Server:BLANK
CSD setting:BLANK
Dial in number NONE
Query at Logon: (NO CHECK MARK)
User Name
Password
Baud Rate Auto
Line Type: ISDN
Time Out Off
DNS Server:
Then go to your browser and enter the following settings:
Profile Name: MEdia Net
Homepage: device.home
Network Link: Cingular
MMS Settings:
Profile Name: MMS over HTTP
MMSC: http : //mmsc.cingular.com/ (No Spaces)
Max Sending Size: 30K
Network Profile: Cingular
Top Siemens Cell Phones Experts
Paul Bade
Ngoro
john h
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
