Question about Xerox Phaser 7700 7750 color laser printer Staple Pack 3 Re Refu
Black Smudges from Tray 1 MPT
Getting black smudges all over the paper from tray 1 mpt. Tray 2 is fine. The smudges are fused.
  • Mike Frost
    Mike Frost Apr 19, 2014
    I bought a new fuster unit to see if that works.
  • Xerox Expert
  • 393 Answers
Dust, dirt, toner, in paper path, clean. -Carl
Posted on Apr 21, 2014
Black smudges from one tray only
Dust, dirt, toner, in paper path, clean. This paper hits portions of the printer diff. than 20lb and grabs toner where thinner paper does not. -Carl
Apr 17, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
Xerox 6180 James at Tray 1 mpt every time!
Your lower trays are programmed incorrectly. Change the size and or the paper type back to letter and plain paper
Aug 23, 2012 | Xerox Phaser 6180N Laser Printer
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
My magicolor 2200 keeps asking me to put paper in the mpt (multi purpose tray) when I'm printing form the bottom tray. The resulting print comes out slightly smeared and starts part way down the page. ...
ok seems like 1 of 2 things,,, firstly check your print settings and ensure your selecting the correct try to print from..
turn off machine
might be a stuck sensor, turn off machine look at where u load the paper, close to where the printer pulls it up, there is a small leaf swith there that tell the printer if it has or dont have paper, play ith the switch a bit.. Then turn back on and try again.
Apr 02, 2011 | Minolta magicolor 2200 DeskLaser Printer
Xerox phaser 7400DN jabs at fuser
The printer trays accommodate most sizes and types of paper, transparencies, or other
specialty media. Follow these guidelines when loading paper and media in the trays:
- Envelopes, labels, and glossy paper can be printed from Tray 1 (MPT) only.
- Transparencies and custom size paper can be printed from Tray 1 (MPT) and Tray 2.
- Fan paper, transparencies, and labels prior to loading them in the tray.
- Use only paper envelopes. All envelopes should be printed single-sided only. Some
wrinkling and embossing may occur when printing envelopes.
- Do not overload the paper trays.
- Adjust the paper guides to fit the paper size.
- If excessive jams occur, use paper or other media from a new package.
Mar 06, 2011 | Xerox Phaser 7400DN Laser Printer
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
Service call error 125 Pulls paper to print then jams and stops Also multipurpose tray won't go into the down position.
125: Error
Error detected in MT home position.
1) is an Error Message displayed? Yes
Turn ON power again.
2)Does the Error take place again? yes
Replace MT
Oct 27, 2010 | Xante Ilumina Digital Color Press Printer
Xerox phaser 7760 sends fault error code 007-274. Won't go further. -john
This error means there is an open circuit in the Paper size sensor, in Tray 1/MPT.
It could be a broken wire in the tray assembly, or a fault on the Engine control interface board.
The voltage at the sensor should be about 3 VDC. (Pin 1 of Plug J610)
Dec 22, 2009 | Office Equipment & Supplies
Xerox 6350 prints ghost page every page printed. It is printing a ghost imge of the previous document printed on every page.
If the ghost is black then you might have a bad Black Developer 116-2011-00
If the ghost is in all colors then it may be your fuser, or possibly just your paper settings. (If you are using glossy paper or card stock this needs to be fed from the MPT tray and defined correctly in the control panel)
Whit
Item, Inc.
Oct 13, 2009 | Xerox Phaser 6350/YDT Laser Printer
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Apr 07, 2009 | HP Color LaserJet 2600n Printer
Xerox Phaser 7700 7750 color laser printer Staple Pack 3 Re Refu Logo
77 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
