Question about Xerox Phaser 8550/SDP Color Laser Printer
Black smudges from one tray only
Black smudges from only one paper tray
  • 3 more comments
  • Mike Frost
    Mike Frost Apr 17, 2014
    Im running tabloid extra, thick card stock and black streaks are all over each page.
  • Mike Frost
    Mike Frost Apr 24, 2014
    We are now getting the black smudges from paper tray 2 with thicker paper, anthying heavier than 20lb. And we always tell it what we load it with.
  • quennie732 Apr 24, 2014
    Well you got me... The fact that it runs OK from tray 2 says the belt cleaner is fine. Service call? Sorry. -Carl
  • Mike Frost
    Thanks, tray 2 does lay down black smudges (looks like tire tread) but only when we send labels through it. I set for labels, they are thick.
  • Mike Frost
    Mike Frost Apr 28, 2014
    changed the transfer rollers and the wast cartridge no help. Maybe I am not explaining what we are getting correctly. It is black ink all ofer the entire print area that looks like roller marks. Sort of if you took a paint roller and had just a little paint on it and rolled it out.
  • Xerox Expert
  • 398 Answers
Dust, dirt, toner, in paper path, clean. This paper hits portions of the printer diff. than 20lb and grabs toner where thinner paper does not. -Carl
Posted on Apr 21, 2014
Testimonial: "I took apart the area labeled (D) and cleaned everything I thought the paper touched and it's the same. I replaced the fuser but that is not the problem, still the same."
  • 2 more comments
  • quennie732 Apr 23, 2014
    When you use this stock you "tell" the unit that you are using thick stock right? and its only on this job/tray the problem happens? -Carl
  • Mike Frost
    Yes, that is correct.
  • Mike Frost
    I have a new transfer roller and wast cartridge on the way. I have seen a belt cleaning kit which I do not know about.
  • Mike Frost
    I just ran 80lb text, no smudges in tray 2, tray 1 MPT horrible.
Black smudges on paper when printing
Toner cartridge no longer any good. Needs to be replaced.
Nov 18, 2015 | Office Equipment & Supplies
Black Smudges from Tray 1 MPT
Dust, dirt, toner, in paper path, clean. -Carl
Apr 17, 2014 | Xerox Phaser 7700 7750 color laser printer...
Leaves black marks on copies
It could be leaking toner from the recovery area that sis on top of the dum, it removes any toner that was not transfered to the paper. You would have to remove it and empty out the toner.
Dec 11, 2012 | Toshiba e-Studio 232 Black and White...
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
What causes my copier pages to have black smudges on them.
Black smudges are usually caused by a defective or worn out drum. When the drum gets a fingerpirnt, any kind of oil, or anything else that causes the static charge to not hold the toner to the paper, the toner will not go where it is supposed to in order to create the image on the paper and it will cause smudges, streaks or lines.
Jan 31, 2011 | Canon imageCLASS D661 Digital Printer
Black ribbon is not back feeding same amount/speed as label, leaving black smudge at beginning of label
This is due to the quality of the ribbon.
When the paper moves back, since the head is not raised, the paper rubs on the ribbon en is the cause of the black smudge. Use correct Ribbon
Jan 08, 2011 | Toshiba TEC BSX5 Thermal Label Printer
Black Smudge of ink along top edge paper Brother Intelifax 2800
try cleaning the grid on the drum unit otherwise there could be some thing on the fuser preasure roller.
Jan 16, 2009 | Brother IntelliFAX 2800 Laser Fax
Canon i9900 black ink smudging
ok, What cartridges are you using, Are the Canon cartridges?
What paper are you using, is it Canon paper?
If you are to both of these it could be wise ordering a printhead, but this is mostly caused in the uk by None Canon Paper.
Please let me know what you are using?
Sep 24, 2008 | Canon i9900 InkJet Photo Printer
Xerox Phaser 8550/SDP Color Laser Printer Logo
67 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
