Question about Panasonic Audio Players & Recorders
What can I connect a Panasonic subwoofer SB-WA733
napps
SOURCE: Subwoofer
is it just the sub you have or do you also have the dvd unit with it?
Posted on Mar 10, 2008
  • 104 Answers
SOURCE: need to connect panasonic sb wa730 to panasonic sa dp1 system
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
Posted on May 23, 2009
  • 156 Answers
SOURCE: how can I connect the subwoofer sb-wa920 to a any audio system
Some systems have a sub out. Does this sub have an output on it? If it does, use it first from your output then out to you other speakers. Hope this helps some but I could really use more information.
Posted on Jul 13, 2009
SOURCE: Simple question?? how do I connect my Panasonic subwoofer to my denon receiver?
I have a very similar problem with the same exact Panasonic sub. I went to Best Buy and Radio Shack looking for an adapter, and they basically told me that one does not exisit. Apparently, Panasonic designed the home theater system specifcally so that it could not work if any part of the entire system was ever seperated.
Posted on Nov 15, 2009
jedweller
  • 21 Answers
SOURCE: Panasonic sb-wa 340 active subwoofer
This is normal operation.. The subwoofer will only play sounds below a set frequency...There may be a crossover setting in your menu that you can adjust the frequency cutoff to your liking.
Posted on Oct 01, 2010
How to put my Panasonic sb-wa733 on aux
The Panasonic SB-WA733 is an active subwoofer that was originally sold with the SC-HT733 Home Theater system. There is no AUX input on the SC-HT733. (The manual for the SC-HT733 available online covers three models. Only one, the SC-HT930, has an AUX input.) With the original remote for the SC-HT930, the remote has a TV/Video Aux button. The SC-HT930's Input selector button (to the right of the power button) will add an Aux option when you cycle through all of the available inputs. I found the manual for the SC-HT733 at Manage My Life here: http://www.managemylife.com/mmh/lis_pdf/OWNM/L0532709.pdf .
Which home theater system do you have? Check the input to which you have connected the audio cable; set the unit to that Input to hear your music.
I hope this helps. Please add a comment with the model number for the center part of your audio system for further assistance.
Oct 27, 2017 | Panasonic Audio Players & Recorders
How do I connect a new dvd reader with a Panasonic SB-WA340 active subwoofer?
Of the Phillips is not a home theatre system them you can but you will have no volume co trol of the sub. If it is the alot of philips home theater in a box (htib) use special plugs...you would need to change the cable end of the sub to a compatible plug.
Aug 23, 2016 | Panasonic Audio Players & Recorders
I have a Panasonic SB-WA340 Active Subwoofer, and need to know if this is compatible with other Panasonic home theater units?
It should be compatible with other Panasonic equipment that has an output for a powered subwoofer
Dec 25, 2012 | Audio Players & Recorders
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
May 27, 2009 | Panasonic SC-HT930 System
Need to connect panasonic sb wa730 to panasonic sa dp1 system
Feb 28, 2009 | Panasonic SC-HT730 System
I need the schematics for panasonic sb-wa733 active subwoofer
Have you tried manualsparadise.com or eserviceinfo.com or even partstore.com. Any of these might have a service manual. Good luck.
Jul 31, 2008 | Audio Players & Recorders
Connect stereo to panasonic SB-WA310 Active Subwoofer
SA-HT800V yo quiero el cable que conectaal dvd del suruofer to sb-wa310 tel 809 904 2175 ruddy german.
Apr 21, 2008 | Panasonic Audio Players & Recorders
202 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
