Question about Envision Computers & Internet
White Screen/ thin blue vertical lines
Stopped Working Overnight
  • 70 Answers
Check the cables, try a different monitor, try this monitor on another computer. This will isolate the problem. If it is the monitor, it is not worth fixing, usually. It is far cheaper to make things than to fix them. If it is the computer, a new video card can be installed.
Posted on May 07, 2014
SOURCE: on screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Posted on Aug 01, 2007
SOURCE: thin blue line
vertical line on my hp f2105, at first there was 2 on the left after 2 month another one came up in the middle and after 5 month onother one again came up on the right. this is a good monitor when it comes to design and picture but durability.... it is a failure.
Posted on Jan 19, 2008
SOURCE: LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Posted on Jul 23, 2008
Fix-4U
  • 293 Answers
SOURCE: vertical line in my toshiba laptop
Hi...there,
Check the flat wide cable that attached to the panel, it's might be loosen a bit. Sometime cable got pulled when lift open the screen. If not, then you got a busted panel...
Posted on Dec 06, 2008
Filidor
  • 28 Answers
SOURCE: what causes vertical lines on screen
They are static lines. They can be caused by a variety of reasons, damage to your monitor, damage to your vid card (perhaps it was got a little too hot?), ive seen this issue also with overclocked, try resetting to defaults if so. Also try reinstalling/updating your current display drivers. If you have an integreated video card it could be that your motherboard got hot and perhaps damaged it. If you have a spare vid card or something else you can hook up to try, and it still has the static lines, then it is your monitor for sure.
Posted on Jul 29, 2009
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
My Sanyo tv has a white screen with blue and red vertical lines down it.
Thats usually caused by the T conn board which is replaceable www.tvrepairworld.com should be able to assist with the diagnosis and replacement parts.
Mar 02, 2012 | Sanyo Televison & Video
Permanent vertical line down monitor
The thin ribbon that connects the board on the back of the lcd screen to the front glass of the lcd screen got damaged.
It wraps around the top of the screen and is very thin and can be easily damaged.
May be from old age and heat at the top of the screen or it could have gotten hit at the top.
The cheapest way to repair this is to replace the lcd screen with a good used one because trying to find a shop to try to repair it would cost more than a new monitor.
It will change color with different colors and also if you push the screen at the top point. Don't play with pushing the screen too often as this may cause more to show up.
Sorry there isn't an easy fix to this.
Fran
Mar 29, 2009 | Acer AL2216WBD LCD Monitor
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
Vertical line on LCD screen
hi unfortunately you'll have to replace the lcd display
Aug 09, 2007 | HP Compaq nc6000 Notebook
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Jul 12, 2007 | RCA P52937 52" Rear Projection Television
On screen thin yellow and blue vertical lines.
Apr 21, 2007 | NEC LCD
Audiovox AVT 1598
The vertical output IC or the vertical circuit is whats at fault. its all solid state and im sorry to tell ya that its not a user replaceable part. This set is probably not worth the repair it would take to get this set working again but please if you like ask a ;ocal repair shop what they thought about this problem.. Good Luck and please dont forget to rate this thread
Nov 11, 2006 | Audiovox AVT1498 TV
Computers & Internet Logo
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
