Question about Kodak EasyShare C310 Digital Camera
Kodak easy share camera /c1530 wont take 4g purchased sd card..why?
  • 34 Answers
SOURCE: Trying to transfer pics on internal memory to my SD card.
Set the image storage setting of the camera to Internal.
Once it is set to internal, put the card in the camera and press review.
Copy the pictures from the internal memory to the card.
Posted on Jun 22, 2009
  • 509 Answers
SOURCE: My Kodak C875 camera will not format a Kingston 4G SD card
The max SD card size for the Kodak C875 is 2GB. HCSD cards will not work.
Posted on Mar 28, 2010
SOURCE: Kodak Easy share C182 Digital Camera
Please check that you have putted kodak alkaline batteries.
Posted on Apr 12, 2010
  • 141 Answers
SOURCE: Is the kodak easy share c180 digital camera webcam?
I won't say the camera is usable as a webcam because you will definitely severly shorten the life of the camera by using it as such. Firstly the camera is designed to take photos and short videos, NOT being left on continuously for use as a webcam. The heat generated by doing so could damage the delicate CCD (the part which collects light from the lens and converts it into electrical signals) Secondly most cameras are deigned to switch themselves off after a certain period of non use. Not handy for webcams.
Next there's the power issue. Unless you are using an external power supply for the camera you will be forever replacing batteries and for what an external power supply costs you could buy a proper made for the job USB powered WebCam complete with focus and sometimes zoom.
Next there's the mounting issue. Where will you mount the camera to give a well lit and steady picture of your face. Definitely not on top of the monitor due to extra heat generated by the monitor itself. Mix that with camera's heat and hello, and too soon, goodbye camera.
Webcams cost $20 if ou shop around maybe cheaper. OK your cmera will give a better picture but at the distance you're talking it won't matter. Plus you will need software to generate the webcam picture. MSN is a good webcam program. Plus depending on the output of the camera, usually only video. You may need a video capture card for your computer. The camera will give you a full screen image of what it's pointed at but you need a box to put a smaller picture in on the screen otherwise all you will see is one big face, yours.
So do you really want to wear your camera out prematurely simply because you can't afford a $20 webcam. The made for the job unit is cheap, will stay on all day and the power comes from the USB port. Everything you need and cheap. I think you know which way to go.
Good luck
Posted on Apr 22, 2010
SOURCE: SD HD card won't format
This camera only works with standard SD cards with a max of 2 GB
Posted on Nov 14, 2010
When I put in new batteries in my easy share C1530 they immediately discharge
There is an internal fault that is shorting out the batteries get it looked at before batteries explode or burst and camera internals get damaged more
Dec 31, 2015 | Kodak Easyshare C1530 14 Mp Digital Camera...
What am I going to do? the SD card could not be format in Kodak Easy Share C310 camera?
The Kodak will only format memory card under 1gb in size, for some reason it wont work on bigger cards
Mar 02, 2011 | Kodak EasyShare C310 Digital Camera
Where can I purchase and sd or mmc card for my easy share c340 camera
MMC cards are nearly extinct and hard to find. SD cards should still be available at just about any department, electronics, or office-supply store. Be sure to get SD cards and not SDHC cards, as the latter will not work in the C340.
Nov 16, 2010 | Kodak EasyShare C340 Digital Camera
I purchased a 4 GB SDHC card for my kodak easy share dx6440. The camera keeps rejecting it because 'it is not formatted'. I formated it and it still does not read it. is the DX6440 limited to SD 2GB? ...
The DX6440 uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and won't work. You are limited to SD cards 2GB and smaller.
Nov 09, 2010 | Kodak EasyShare DX6440 Digital Camera
Purchased memory cards PNY ooptima 60xHD 4GB for my camera (Kodak Easy share CX 7430
The CX7430 uses SD cards. Your 4GB card is actually an SDHC card and will not work in the CX7430.
Jun 19, 2010 | Kodak Cameras
How do we move the photos to the memory card in the camera?
Get out your manual and read the chapter about file transfers. It should be fairly simple to move the files from internal memory to external memory.
Aug 06, 2009 | Kodak EasyShare Z1275 Digital Camera
Mar 31, 2009 | Kodak EasyShare Z612 Digital Camera
What is the upper limit of SD card as GB without any freezing or slowrunning problem in Kodak easy share V1003?
I have a 2 GB SD card that i use on mine, and i dont seem to have any problems with the camera being slow. I hope this helps and good luck!
Jul 13, 2008 | Kodak EasyShare V1003 Digital Camera
Kodak EasyShare C310 Digital Camera Logo
27 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
