Question about Singer Sewing Machines
I would like to know the correct direction to thread the cotton on a 196K205 singer industrial machine please, a diagram would help. Thanks
Model 196k205 industrial
  • Peter Camilleri
    Peter Camilleri Apr 17, 2014
    I haven't used this machine before infact any other for at least 35 years since I learnt basics at school. I'm a male, and was given this machine and would like to try use it.. Properly if I can.. But the manual I downloaded don't show how or what direction to thread the cotton from the first step to the last. A diagram would be very helpful and appreciated emencly
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Singer Expert
  • 300 Answers
  • 4 Answers
SOURCE: I have a singer futura ce-250/ce-350 machine.
I have been sewing for quite some time on other machines. I assumed I knew all that I needed to do and I have the same problem, bunching undeneathe. I found out my problem was twofold. One when you thread the top part - you should pull the thread back and forth in the top thread guide. (#1 in the manual page 6). The second thing was the curly tail in front. It really needs both of these. I hope this helps you. Made me feel really inexperienced. I actually pulled out the manual.
Posted on Jan 25, 2009
SOURCE: Singer 132K6 industrial machine
Make sure that the thread is under the tension spring then thread it throgh the hole in the spoolcase,push the spoolcase retainer over to hold it in then turn the balance wheel towards you to pick up the thread through the hole in the needle plate, pull both threads back and sew away. I can supply a manual for this machine if you want one.
Robert
Posted on Sep 07, 2008
Gigatech
  • 259 Answers
SOURCE: singer 251-2 industrial sewing machine
It was a tough find but here is your manual:
http://www.bestneedles.com/catalog/singer/Singer%20Instruction%20Manuals/251-Class-Inst.pdf
Posted on Dec 10, 2007
Zenqi
  • 208 Answers
SOURCE: I have a Singer Special Zig Zag Model 418. I can
More than likely you have a broken vertical shaft gear.
When you turn the handwheel you should see the sewing hook moving under the bobbin case.
If not, take it to a sewing repair person and it should cost somewhere around $100 to repair.
Posted on Aug 21, 2009
SOURCE: free download of singer overlocker manual
Jag har en industri overlock singer 81k73 Jag kan inte trä den
Har du några förslag
Posted on Oct 20, 2009
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
How do i fix thread tension on Singer 191D300A industrial sewing machine?
Make sure the bobbin is spinning in the correct direction before you try to sew. Where is the thread collecting? Under the needle plate?
A few other things can be wrong. I will need more information.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 28, 2014 | Singer Sewing Machines
New Singer 1507 user - cotton jamming everytime
try this link for a free manual just in case you don't have one
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
if the fabric is real light weight you may have to use a stablizer
also check to make sure the needle is the right one for the fabric being sewed..
make sure the bobbin is turned the correct direction, try putting the bobbin in the opposite direction..
if the machine keeps jamming, take it back up where you bought it and show them what it's doing and see if they can help you..
Jun 20, 2013 | Singer 1507
Singer sewing machine stiches not forming & thread bunching
Sounds like what is called bird nests or thread nests. The top thread is not seated completely in the tension disk.
Remove the top thread completely from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Now, retest your machine.
Jun 28, 2017 | Singer Sewing Machines
Free download of singer overlocker manual
Mar 25, 2009 | Yamata FY14U4AD
Industrial over locker
The singer site would be a good place to start. There are also groups on Facebook that you can ask a lot of questions about industrial machines.
Oct 02, 2017 | Sewing Machines
Singer tiny tailor TT700
www.Sewusa.com
click threading.
scroll to the SINGER brands.
Click of tiny tailor 700.
this should help you.
Sep 27, 2007 | Singer Tiny Tailor TT700
Sewing Machines Logo
110 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
