Question about Dishwashers
How to change pump on a asko dishwasher - Dishwashers
4 Suggested Answers
SOURCE: Faulty Asko dishwasher
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
Posted on Apr 11, 2009
  • 14 Answers
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
Macmarkus
  • 2605 Answers
SOURCE: How do I remove the cerculation pump
Hello, With the right technique it isn't too bad, but it does require removing it from the cabinet/cupboard. This is what I do. FIRST**Turn off the power at the main service panel or unplug the unit.** Shut off the water and undo the water supply and drain hose. Remove as much water from the sump well as possible because you'll need to lye the dishwasher on its front ( remove any dishes inside and also get some towels or a blanket to lay it on so you don't damage the front panel or control's ). Once you have the unit out and face down, you'll see the back of the circulation motor&pump assembly...this is where it gets a little tricky, but I've done plenty and will guide you through. The clamps holding the pump hoses in place are "one time" clamps so once removed they'll need to be replaced with narrow "worm gear" clamps when installing the new pump assy. Undo the wires at the side of the motor ( A good idea would be to take a picture or draw a diagram, the picture is likely better...in my case at least ). Hopefully from here you will get the new one in. Let me know how you make out, I'll watch your post. Good luck. Macmarkus :)
Posted on Apr 22, 2010
Testimonial: "Yhanks for the info now I need to decide new washer or fix rhis one any recomondations on a new one."
Asko dishwasher D1760 tripped the power on drain function, replaced drain pump then worked ok. Next day dishwasher started making a very loud noise when washing then tripped power. Thoughts?
The replacement pump may have failed early on. Something other than the pump may causing failure, such as ingestion of some kind of destructive material.
Feb 11, 2017 | Asko Dishwashers
Drain pump small black insert, found in the sump area. Where can I find one of these for my ASKO D1706 Dishwasher?
call asko directly, or call Great Plains Appliance Parts. Don't know the numbers, but Asko stocks parts in Texas, and Great Plains stocks them in Denver.
Aug 29, 2013 | Asko D1706 Built-in Dishwasher
Asko D3530 Dishwasher Water Inlet Fault
I did research on the net and asko mention a special settings menu in the pdf manuals available
you can download a manual but there is a reference to water not entering the washer in the manual and how to trouble shoot it
Pressure pumps deliver water at pressures from 35 psi to 60 psi and if you have checked all of the slow fill reasons , maybe checking the on/off pressure switch for the pump would be a place to investigate
the machine will start when the water has reached the level set
anyway go google and type in - workshop manual for asko dishwasher model d3530 --and download a pdf version to read
Jun 08, 2017 | Dishwashers
Asko 1475 dishwasher - won't wash. Circulation pump?
Check your drain. It is dual purpose. It not only drains but, it also recirculates the water doring the cycles.
Aug 10, 2009 | Asko Dishwashers
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Jun 22, 2009 | Asko 1375 Dishwasher
Circ pump runs, but does not pump
Oppen the centre orifice , remove cover , remove impeller , clean debri and change impeler with new one, Vitally
May 13, 2009 | Asko 24 in. 1885 Built-in Dishwasher
Mar 12, 2009 | Asko D3152XLSS Stainless Steel Built-in...
Apr 04, 2008 | Asko Dishwashers
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
