Question about Campbell Hausfeld No.FP2028 Gal Pancake Compressor
Compressor will not air up tire
Same compressor, similar problem. It will not air up a bike tire or a lawnmower title. When I press the release button air shoots out of the hose fine. It just won't work when trying to air up a tire
  • Dean
    Dean May 11, 2010
    I assume you are using the proper tire inflating nozzle or gun yes?
Is it depressing the valve in the air chuck, sound dumb but I just had an air chuck that gave me problems replaced and it works fine.
Worth a look.
Posted on Jun 20, 2009
Ford Expedition 2001 crankshaft sensor location and installation
  • Located front of engine, close to crank pulley
  • press the helpful button and follow me on Fixya for more tips
  • Insert the square tip of a 1/2-inch socket wrench into the square hole in the center of the serpentine belt's adjustment pulley. The adjustment pulley is the smallest pulley the belt wraps around.
  • Pull the adjustment pulley toward the engine with the socket wrench to release the tension on the serpentine belt, then pull the belt off the air conditioning compressor's pulley.
  • Remove the bolts which secure the air conditioning compressor to its mounting brackets with an open-end wrench, then position the compressor to the side of the engine compartment. Do not disturb the hoses that attach to the compressor.
  • Pull the electrical connection off the crankshaft sensor.
  • Remove the two bolts that secure the crankshaft sensor against the engine with an open-end wrench, then slide the sensor out of the engine.
  • Slide the new crankshaft sensor into the engine, then install and tighten the sensor's two securing bolts with an open-end wrench.
  • Press the electrical connection onto the crankshaft sensor.
  • Position the air conditioning compressor against its mounting brackets, then install and tighten the compressor's bolts with an open-end wrench.
  • Pull the serpentine belt's adjustment pulley toward the engine with the socket wrench, then position the belt onto the air compressor's pulley. write up found @ehow
How to Replace the Crankshaft Sensor in Ford 150 eHow
Jan 28, 2016 | Ford Expedition Cars & Trucks
Central pneumatic 61693 problems
Without seeing and being able to do hands-on trouble-shooting I can only make a shot-in-the dark analysis.
I, years ago had a similar situation, and it turned out that my compressor was one which REQUIRED LUBRICATING OIL IN THE CRANKCASE [just like a 4-cycle lawnmower engine].
I had failed to regularly check the oil level and over 4 or 5 years it had "used up" the oil and was beginning to run dry. Dry bearings build additional friction which will cause "drag" and slow the compressor RPM!!!!! That could explain the inability of your compressor to exceed 20 to 30 Psi!
With enough dry running, the bearings within the compressor will eventually totally wear out, and FREEZE-UP, locking the compressor up. Once that happens, the compressor will have to be replaced, OR OVERHAULED, just like you would do with a frozen bearing in a lawnmower engine!!!!!
IF, and I EMPHASIZE IF, RIGHT AWAY you properly lubricate the compressor [IF it uses crankcase oil] you MAY extend the life a little while longer, but that no cold start, and low high pressure capability suggest that the bearing(s) is/are dragging badly already.
If your compressor is an "oil-less" type, then an overhaul or replacement will probably be necessary.
Jan 10, 2015 | Air Tools & Compressors
Bought a barely used 2010 Cannodale I think it is a road bike. Haven't biked for 25 years. Needed to add air and all I did was let out all the air. Trying to use remaining air in a turned off...
The adapter for car tires should work on the bike tires. If you are using a compressor with a regulator and gauges then with a full tank of air adjust the regulator so the output gauge is set to the pressure you want the bike tire be be. This makes it take longer to fill the tire but reduces the changes the tire is overfilled and damaged. If you have an old fashioned bike pump and want some exercise that is different than biking then that works also. The valve stems on the bike tires have threads just like the car valve stems and the valves and caps are interchangeable.
Aug 07, 2011 | Cannondale Cycling
MY COMPESSOR GAGE SHOWS 135 PSI AND 135 ON THE OUT PUT GAGE BUT I CAN,T INFLATE MY MOTORHOME TIRES TO THE REQUIRED 110#.DO I NEED A LARGER COMPRESSOR?I CAN,T FIND ANY LEAKS.
It is possible that the compressor psi as it is running drops below the tire psi creating a standoff. You must maintain air compressor psi over 110 to fill a tire to 110psi. Add air to your tire but stop when the compressor motor starts to run. When the motor stops then continue to add air until the compressor motor starts and again stop airing up the tire. Repeat as needed.
Dec 25, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
The compressor continues to run but no air enters the tire, the tire just seems to get more and more flat.
Hi, I suspect the plunger for the valve stem connector on the pressure head is not depressing the air release pin in the head of the valve stem.
I have a Black and Decker and have to use a valve stem seat removal tool to quicky unscrew about 3 to 4 turns the stem seal and then connect the air hose head. After the tire reaches the correct air pressure I have go thru the tighten the valve stem seat drill.
You can buy the vavle stem seat tool at any auto parts store. I keep mine with the compressor.
I don't want this to sound bad but... is the air hose supply vavle turned on? Some have a slider button on the valve you have to push to charge the hose. If the hose is charged then see above.
Thanks for using FixYa.
Kelly
Feb 10, 2010 | Campbell Hausfeld 02-Gallon Air...
My accu-gage tire gage does not hold tire pressure reading. the dial drops slowly down to zero.
If there is a button you push to release the pressure (resetting the gage to zero), this is a valve which probably has a little piece of dirt impeding the seal of that valve. The dirt would have been carried there by the air and condensation. But don't take it apart to clean it. This is a typical problem with these kinds of gages. When you have plenty of air available (a compressor nearby) hold the gage on the valve stem, while you repeatedly push the release button. That should clear the dirt, but you may need to add more air to the tire.
Jan 17, 2010 | Accu Gage Tire Pressure Guage 60 Psi Range...
HITACHI AIR COMPRESSOR
what type of air compressor you have,since when you maintained it
Sep 23, 2009 | Hitachi EC12 Portable Electric 2hp Air...
2004 Honda Pilot A/C stop working. No clicking sound or cold air
See if it's the compressor by watching the compressor either spinning ( compressor is working ) or not ( compressor not working ). Compressor will not engage if refrigerant is low. Add R-134a ( 12 oz. can )
Sep 08, 2009 | 2008 Honda Pilot
WON'T RESTART
The reset button used on Bostitch is the type that cuts out when motor is too hot to safely run. You must wait till system cools a bit before the reset button will reset. May be a good idea to solve overheating problem before replacing reset. It is always best to connect the compressor directly to the outlet instead of using an extension cord. If it is already connected directly to plug, insure that the outlet is capable of delivering amps needed for your compressor. When the compressor reaches rated pressure and shuts off there should be a small release of air from the pressure switch. This release of pressure allows the compessor to start in an unloaded state. If the compressor does not release the air in the hose the motor will not have the power to overcome the backpressure and cause the reset to open. There is a capacitor that could be at fault. The capacitor must be removed from the circuit to test. It should test within 95 percent of rated value. Generally, overheating is caused by low power. A failed capacitor is caused by low power. Good luck, enjoy.
Dec 24, 2008 | Stanley Bostitch CWC200ST 3HP Oil Lube...
Campbell Hausfeld No.FP2028 Gal Pancake Compressor Logo
207 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
