Question about Exercise & Fitness
Roger black silver blowing tiny glass fuse not running
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
There is a short somewhere. it could be on the control board ,motor or power cable. does it start at all ? if it turns on but blows when the motor runs it could be a problem with the motor or control board
Posted on Apr 20, 2014
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: lost manual for roger black silver treadmill
see the video and proceed according., God bless you
Posted on Apr 04, 2013
Lost manual for roger black silver treadmill
Apr 03, 2013 | Exercise & Fitness
How to charge garmien 1300
Hello
Charge your Nuvi for at least 4 hours. If your unit will not charge in your vehicle, you might nee to replace the fuse located at the tip of vehicles' adapter.
1. Unscrew the black, round endpiece, and remove it. 2. Remove the fuse [glass and silver cylinder] and replace it with 1Amps fast-blow fuse. 3. Ensure that the silver tip is placed in the blace end piece. Screw on the black end piece.
* Connect the vehicle power cable.
* Connect the USB cable (included in some packages)
* Connect an AC adapter (optional accessory)
These are the three ways to charge your Nuvi. Ok
Please don't forget to rate this solution.
Jan 21, 2012 | Garmin nuvi 1300 Car GPS Receiver
My Yamaha RX-V757 Receiver wont turn on at all, everthing has gone blank??? Help
There are internal fuses in this unit.
Check these fuses first.
If you find a fuse that measures open, and the glass isn't black or black/silver then simply replacing the fuse may do the trick.
Make sure you get an EXACT match for the fuses, some are slo-blow because of the power on surge it has to allow.
Feb 27, 2011 | Yamaha RX-V757 Receiver
My charger is not working, the garmin connects to the computer and updates fine so i know its not the usb...any ideas?
If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece.
  2. fileservlet?date=1&kb=%7b6b85cfa0-194d-11dc-44cd-000000000000%7d&id=%7b6e53bea0-6874-11dd-436f-000000000000%7d&ext=jpg
  3. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  4. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
fileservlet?date=1&kb=%7b6b85cfa0-194d-11dc-44cd-000000000000%7d&id=%7b6e476290-6874-11dd-436f-000000000000%7d&ext=jpg
Sep 01, 2010 | GPS
My garmin nuvi 650 na keeps depleting its battery even though I just fully charge it on the computer. It also does not charge when I plug it in the cigarette lighter in the car. The screen turns dark...
well if you have the factory car charger. There is a fuse inside of it. This is indicated in the manual. But it could also be the cigarette lighter fuse in the car is blown. I would make sure the cigarette outlet has power. If the cigarette lighter has power and you have the factory power cable that has a fuse try this. f the unit will not charge in your vehicle, you might need to replace the fuse that is located at the tip of the vehicle adapter.
1. to change the fuse unscrew the black, round end piece on the vehicle power adapter and remove it. inspect the fuse to see if it is blown. If not end here.
2. if determined the fuse is blown remove the fuse (glass and silver cylinder), and replace it with a 1A fast blow fuse.
3.ensure that the silver tip is placed in the black end piece. screw on the black end piece
let me know how this works by following up with a comment and i can instruct you on where to go from here. Thanks.
Aug 26, 2010 | Computers & Internet
Hi. I have a Produex glass bathroom scale. I have no idea what model it is and I can't find the instruction manual. Somehow it got switched from pounds to kilograms and I don't know how to switch it back....
I have a produex glass scale that is silver with a solid black stripe on one side and rows of poka dots on the other side. It has a tiny swicth on the back that changes the scale from pounds to kilograms.
Jul 27, 2010 | Health & Beauty
Unit will not power up
check fuse in power cord if using in car adapter. unscrew the silver ring at the tip of the cigarette plug DO NOT ALLOW THE SPRING TO SHOOT OUT WITH THE SILVER CONTACT PIECE INSIDE! remove the spring and contact piece then remove the fuse, look to see if it is scorched, you will either see black soot on the glass or a break in the wire that runs through the glass tube. Hold it up to the light. See if you can tell where the brreak is. Sometimes the break is at the verry top and you cant see so just replace the fuse with a new one form the hardware store, ETC. replace fuse spring contact tip and retainer ring then plug in and try again.
Nov 29, 2009 | Delphi Roady XT XM Radio Receiver
Where is the fuse box on a 1965 ford fairlane 500
Hello faeriedew: My name is Roger and I can answer your question. The fuse box ix part of the headlamp switch. If you look up at the light switch you should see the fuses. These fuses will be glass. Please be careful that you do not get glass in your eyes if you pop the fuse out. You can also remove the switch to access the fuses. To remove the switch. locate the release button on the switch. Press the button and pull the light switch rod out of the switch. Remove the lock screw that the rod runs through the middle of the switch. Reverse the operation to reinstall the switch. Should you need further help please just ask. Please rate the quality of the answer you received. Thank You for using Fix Ya. Roger
Oct 05, 2009 | 1965 Ford Mustang
Lost instructions for Rober Black cross trainer
Hi, I have bought a second hand roger black silver cross trainer and I do not have any instructions, also the bolt that holds the front post together is missing and the tension dial does not seem to work can I adjust the tension in side the front post! Please can you help. Kind Regards Janet
Feb 01, 2009 | Exercise & Fitness
Exercise & Fitness Logo
51 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
