Question about Frigidaire FAHE1011MW HE Top Load Washer FAHE1011MW
Unlock top load washer
Cycle stopped hours ago, but top will not unlock to open.
  • 75 Answers
Hi, switch power off completely, remove plug from socket, wait few minutes then reinstall plug and start anew. (It would be great if the machine had a reset button). Hope the power unplugging does the trick. All the best.
Posted on Apr 18, 2014
3 Suggested Answers
SOURCE: my washer won't stop filling
I have a Maytag that had that problem. Mine has a plastic tube inside of the machine that connects to a sensor. As the water level rises, some of it goes into this tube creating air pressure on a sensor that signals the machine that the water is at the selected level. The bottom of the tube had come loose and just needed to be put back onto the fitting. I accessed this tube by lifting the top of the machine, and it is in the back. Very easy to get at. I hope this works for you.
Posted on Sep 22, 2008
BIKER T
  • 909 Answers
SOURCE: Front load washer FTF530FS1 stop mid cycle,
Seems you have possibly 2 problems. One, check to see if the element is not faulty. If no heat during heating cycle, the washer wont proceed for a long time.. Two, if noisy, especially on spin cycle, the bearings (2 of them) and the seal are faulty. Replace them as soon as possible.
Posted on May 27, 2010
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
My washer begins the cycle and than stops and does not unlock when i stop it
Possible that fault is connected with the controller unit. The door is not released even after the cycle hass completed and so there can be some delay in releasing the same. You can try and see if the connections from the controller unit is intact.Also make sure the door locks are free.
Check this link for some clues: washer door lock.
Jun 26, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Code "rL" means???
Code rL or F34 --> Load detected in machine at the beginning of the clean cycle. Push stop, remove clothes from washer & try again. Mine did this to me, even though there was nothing in the washer. I just tried it a second time & all is good again.
Feb 18, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Duet Washer - Problems with the Spin Cycle
you might want to call whirlpool cause it might be still in warranty
Dec 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune Washer won't stop running/or shut off after cycle
clean the small presser hose out and check the pump sump make shur there is no obstruction
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Door unlocks and won't spin or drain
it sounds like a clogged filter
Please remove the filter on the side of the machine or the front.
Make sure you have towels handy.
Clear the filter out. If your pump cant empty the machine out you will get these problems
Make sure waterline is not obstructed
Apr 15, 2008 | GE WSXH208A Front Load Washer
Frigidaire FAHE1011MW HE Top Load Washer FAHE1011MW Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
