Question about LG LRSC26920 25.5 cu.ft. Moving on Up Side-By-Side Refrigerator
Victory Freezer not working after a move
I have a large industrial sized Victory Freezer that was moved from my house into my friends restaraunt. We had to lay it on it's side to move it and to get it into the restaraunt. There was no damage during the move.
I heard a leaking noise during the 24 hr period that we allowed the freezer to stand before plugging it in. It does not cool now.
Is this a common problem? What's the solution? Is it as simple as a refrigerant re-charge?
  • Anonymous Dec 23, 2007
    I have a McClary (Camco) freezer, we moved a week ago and thought the freezer was plugged in. I opened the freezer and the food was all defrosted therefore there was a lot of water in it. I've cleaned it out and left it unplugged with the freezer door open. Every now and then there seems to be a seepage of some brownish liquid coming out of the inner seams. Is this dangerous and would the freezer have incurred any damage? Thanks.
How long did yu wait before pluggin it in? When laid on its side the freon, and compressor oil migrate. You may have ruined the compressor by turning it on when there was not enough oil in it.
It is best not to set freezers on the side, but if you must, make sure you leave it for 24 hours to allow the oil to settle again before plugging in.
Posted on Nov 08, 2007
Scooter won,t move just clicks if I take the seat off and move the big wiring harness it will run
Hi, Sounds like a loose connection from the controller to the motor, now check the wire leading to the motor, two for the motor and two for the brake, the brake wires being the thinnest....
Oct 26, 2013 | Pride Victory 4 Wheel Mid-Size Electric...
Won't move when drive leaver pushed
go to my group page on facebook wac mobility scooter and i will message you.many thanks billy
Mar 19, 2013 | Pride Victory 4 Wheel Mid-Size Electric...
Juki DDL-227 won't spin
:) welcome to the world of industrial machines. The good news is they are typically simple machines.
It is a good habit to take a few minutes to clean and oil your machine before you start sewing. Look for the oil points and give it one drop of quality sewing machine oil in each port.
Now let's try to determine why the hand wheel isn't turning. Loosen and remove the belt from the large reducer wheel under the table to the sewing machine. Try to turn the hand wheel. If it does turn.... Good! If it doesn't turn... we know the problem is in the the machine head and not the wheels below.
Make sure there is no bobbin thread or upper thread. Try to turn the hand wheel again. Anything?
Look carefully at the machine... is the take up lever bent? (personally had this happen with friends helped me move a big machine like this.)
Keep working this way... inspecting the machine until you find the problem. Good luck
Sep 08, 2012 | Juki Sewing Machines
I have not used this printer in 5-6 yrs. I turned it on and wanted to check the ink cartridge. However, the cradle does not move the cartridges to the center. Anything I can do?
I would take a train to Nebraska, go in to the local restaraunt (don't worry, there is only 1 restaraunt in Nebraska) and buy a cow from Orville (the cook). Rent a car and drive home with the cow in the back seat. When you get home, put the printer in front of the cow and have the cow jump up and down on the printer. If the printer STILL doesn't work after that, buy a new printer.
Aug 27, 2011 | HP DeskJet 3820 InkJet Printer
I have a Kenmore ColdSpot Refridgerator MODEL # 52552100. It was working fine until we moved it to my friends house, now it's not blowing cold air. Any ideas to what this may be? Hopefully it's just a...
please try to touch the condenser if heating or listening on the freezer if have hizzing sound if not maybe your unit have no refrigerant u said that u move in to friends house maybe piping damage if this happen try to braze leak and recharge refrigerant.or try to relocate your unit maybe the circulation of air to condenser is not good. observe the operation of compressor if working continues.
Feb 08, 2011 | Kenmore Refrigerators
I moved my freezer and now will only stay cold for a short time, why?
You jard the liquids. Did you just move it a little or move like to another house because if you move a frig or freezer somewhere or lay on it's side you shouldn't plug in for an hour or more so it all settles or it won't work. Hope this helped
Apr 29, 2010 | Danby 5.5 cu. ft. / 156 liter Chest...
Chest freezer - hose adaptor?
That would depend on the size of the freezer. If it's a compact 5-7 cubic feet, then its not necessarily needed, but if it is a large freezer I would recommend buying the hose adapter. The basic function for the hose adapter is draining the water after defrosting the freezer.
So if it's a large freezer that will not be moved, then YES by all means, you need the adapter.
Nov 19, 2008 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Inside fans not running
verify wiring probably lose wire(s) in movement
Apr 21, 2008 | True T-49 Side by Side Refrigerator...
Freezer not freezing
Check your temperature setting.
Feb 04, 2008 | Electrolux ER7926B Bottom Freezer...
Refrigerators Logo
437 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
