Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Turn on LCD display DS603ss Fischer Paykel Dishwasher
Is there a way to turn on and off the light on the LCD display on the DS603
4 Suggested Answers
RescueTech
  • 145 Answers
SOURCE: problems with fischer paykel self cleaning oven
Hi and welcome to FixYA.com!
Here are links to the two most popular Fisher Paykel Wall Ovens:
OD/OS301:
http://www.fisherpaykelparts.net/partmanuals/545619C_Aerotech_UGM_USw1.pdf
OD/OS302:
http://fisherpaykelparts.net/partmanuals/599194C_Aerotech_ugm_USw.pdf
If neither od these is your model, let me know which one you have and I will locate a use and care guide for you.
Hope this helps and Happy Holidays from the FixYa crew!
Posted on Dec 15, 2008
pride applia
  • 232 Answers
SOURCE: F1 problem on Fischer and Paykel Dishwasher.
NO POWER TO LOWER DRAWER, CHECK POWER AT BOARD IN LOWER BACK CORNER BEHIND DRAWER,CHECK FOR BROKEN WIRE TO LOWER DRAWER,CAN ALSO BE THERMAL FUSE ON HEATER PLATE,COULD ALSO BE CONTROL BOARD IN LOWER DRAWER.GOOD LUCK there is a drawing taped inside behind the drawer. oops sorry about all caps prideapplianceser@sti.net
Posted on Jan 01, 2009
  • 784 Answers
SOURCE: Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Posted on Sep 09, 2009
Ds603 has no power coming to it - no lights, no sounds. It is not the power point. Can you tell me which part maybe affected?
Your control board is definitely dead and the likely cause 8 times out of 10 is because the heater plate blew (when the heater shorts out it often back feeds to the board and fries it, can be a little pricey to repair over 300 easily, but the control board can die for no specific reason or can be caused by power surges, you will first need to work out whether the heater plate is blown or not, this riquires a bit of electrical skill
Jul 27, 2014 | Fisher and Paykel DS603SS Stainless Steel...
DS603 has power but no light coming on panel
If you can operate the dishwasher but the display is blank then it is likely the LCD panel is faulty. Needs to be replaced. see below.
http://spares.bigwarehouse.com.au/product_info.php?cPath=64658_64876_68136&products_id=1653549
Oct 21, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
Eletronic oanel displays F1
The reason for F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorized service center. These problems cant be fixed on your own.
Thank you !!
Jun 21, 2010 | Fisher and Paykel DS603SS Stainless Steel...
F1 fault on a ds603
The reason for your F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorised service centre. These problems cant be fixed on your own.
Apr 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Sep 08, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Problems with fischer paykel self cleaning oven
OD/OS301:
OD/OS302:
Dec 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
