Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool ED5RHEXNL03 water dispenser isn't working
Water dispenser isn't working, I pulled the unit out and the lines were not crimped. What do I do next?
  • Whirlpool Master
  • 4,655 Answers
On back of refrigerator there is a dual water control valve. One side may be defective. If you would like my help, let me know, Thanks, Sea Breeze
Posted on Jun 19, 2009
Water dispenser not working ice maker okay water line to valves okay appears line in door frozen
GE has a fix for frozen water line in freezer door. WR49x10173 is a heater kit that is installed in the dispenser area. It uses a minor amount of energy, but enough to keep the area warm. You have to pull off the dispenser board, remove the 4 screws to remove the dispenser cradle and unplug the wiring. Then follow instructions to crimp on the heater wires. Allow about 3 days for frozen water line to defrost. .
Jul 15, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
My hotpoint side by side is not dispensing water, ice is being made and dispensed but no water. Do you have any ideas? The filter was replaced 2 months ago. Water line isn't crimped or leaking. Any...
In this case the dual water control valve side that turns the water on for water dispenser found here as location 800 in photo=> HSM25GFRASA Motherboard and Compressor Components
I believe you replace this part=> WR57X10051 Water Valve - Dual Outlet
And you will be good to go for dispensing water! Click here for a Service manual that will work with your model=> Here Please rate this solution and If you have any questions please let me know, Thank You Sea Breeze
Oct 10, 2011 | Hotpoint HSM25GFRSA
Whirlpool Water Dispenser not working and not producing ICE.
check the fresh water solenoid on the back of the unit theres a screen in the water line to it that maybe clogged also crak the line lose gently to isure water is passing through it if not? then change the water solenoid
Jan 15, 2010 | Whirlpool GS6NBEXR Side by Side...
My water dispensor want work, I'm getting water, no humming when
Before you replace the switch have you checked the following.
Proper waterflow / pressure, filter condition, water line has no been crimped or bent, water line is not frozen.
Have you tried unplugging the unit and waiting a few minutes, plugging it back it and checking it?
I am sure these Q's may sound dumb, but I don't know everything you have already done. AND I hate to see people spend money on stuff they don't need.
Hope one of these help.
If so, please rate me.
Thanks,Matt
Sep 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool ref side by side the water
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
OR
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 20, 2009 | Refrigerators
Water dispenser just quit putting out water one day whirlpool refriderator
OR
Aug 09, 2009 | Whirlpool Refrigerators
Ice maker and the water dispensor is not working.the fridge is only 6 months old
does your plastic water line run from underneath your sink to fridge? if so maybe you put something under sink and crimped the little plastic water line. pull refride out some and then try water dispenser
Jul 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser does not work. Water supply is
If you are getting water to the refrigerator holding tank, check the line that runs out from that and up to the dispenser. You may have a "downline" leak from the internal storage tank. If you do not find a puddle, you may have a hole or a crimped line (check at the point where the line comes into the door).
Jul 10, 2009 | Refrigerators
Water dispenser problem
Did the man who installed it use plastic hose or copper pie? PLastic pipe can get crimpled (closed) and starve the water supply.
Simply move the refrigerator far enough away from the wall and see if the tubing is crimped. If it is copper and it is crimped- you should call the installer back to repair the copper pie. Once copper pipe is crimped- it is unusable and must be refitted with a coupling or union or some other proper repair.
Maybe this is all that is wrong.......
Hope this helpes!!!
May 30, 2009 | Whirlpool ED2FHEXN Side by Side...
ICE MAKER NOT MAKING ICE &WATER DISPENSER NOT DISPENSING WATER. WIRLPOOL ET9FTTXLQ11
Check the water filter cartridge - possibly needs replacement. It should be near the bottom of the unit in the front.
Mar 28, 2009 | Whirlpool ET9FTTXL Top Freezer...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
258 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
