Question about Bosch Classixx WFL 2066 Front Load Washer
My washing machine is beginnig to smell inside the drum is it because I wash on a quick cycle
  • 118 Answers
It's very common. There is a high efficiency washing machine cleaner you can use in is as well as cleaning the gap in the seal for the door. Some machines also have a filter to catch small objects and if that is not clean it can smell as well.
Posted on Apr 17, 2014
SOURCE: Problems with washing machine cycles
does it heat up? if not the element has gone and needs replacing. try it out on a cold 30 wash to see if it goes through if so element probs.
Posted on Jun 01, 2007
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Posted on Apr 26, 2008
nikeananth
  • 267 Answers
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
barkencoa
  • 3463 Answers
SOURCE: drum not working on bosch washing machine
I would say that the brushes want replacing in the motor, access to the motor is by removing the rear panel, remove the belt, and undo screws securing motor, remove motor, brushes are located at rear end of motor.
Please rate my solution.
Thanks
Posted on Nov 08, 2009
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
How do you get rid of mold smell in washing machine
Hello friend, thanks for your post!
I understand that you have a mold smell developing inside of your Frigidaire washer. I would normally recommend using a clean wash cycle with either one cup of bleach or one pouch of Tide Washing Machine Cleaner. If you do not have a clean wash cycle on your washer you could also use hot water and a regular cycle with a cup of bleach to clean out your washer.
You should also check over your gasket to assure there is no mold buildup, if you do locate mold inside of your gasket you can use bleach to help get rid of any residue. I hope this information is helpful. -Matt
Sep 25, 2014 | Frigidaire Washing Machines
Why does my Whirlpool H2low washing machine smell bad inside?
Are you sure it's your washer or is there an awful sewage gas smell coming up your drain where your washer hose drains in.. I had this happen and I had to instal a U trap in the line the washer drained into.
Sep 09, 2014 | Washing Machines
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
Jan 24, 2011 | Washing Machines
My beko washing machine smells of burning
i need a motor circuit to test the motor of a defy automaid it does not spin fast
Nov 24, 2009 | Washing Machines
My aquarius WML540G washing machine has no obvious fault apart from I am sure there must be an item of clothing trapped in the washer because my clothes smell of when something has been left wet for a long...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Smells coming from inside the drum are usually caused by a build up of soap and scum congealing on the inside of the container, (that is the container rather than the inner drum) and the worst culprit for this build up is liquid washing compounds because they do not have any bleaching agents in them and they form a kind of paste. Put the machine on a service wash, (that is a very hot wash with a good quality washing POWDER and no cloths) allow the machine to complete the cycle. This may need to be repeated once a week or month until you are happy the smell has completely gone. If possibly I would avoid liquid soap in future. But that is just my opinion.
Aug 31, 2009 | Hotpoint Washing Machines
Bad smell inside drum and when draining also makes laundry smell
Recommend running it through empty (and without soap) on a long, hot wash cycle a couple of times.
Modern cool cycles don't always wash away all the detergent, and the machine fills up with smelly grey sludge after a while.
A.
Aug 01, 2009 | LG Washing Machines
WF740 Hotpoint washing machine with bad smell from drum. Tried 95 degree wash but still smells. Door seal slightly blackened but I think smell is from drum too. Any help?
Wash it out with a strong solution of washing soda placed into the drum before you fill the machine
Ps
Run the machine empty through a full hot cycle then run the soda one
The first will soften the deposits and the second should help kill the bacteria that is causing the smell.
Reducing the load so that there is more agitation helps as well
Jul 03, 2009 | Hotpoint Aquarius WD640 Front Load...
LG washing machine smelly drum
try the hotest wash not on a quick wash and put a hand full of soda crystas in the drum. you can buy these at most supermarkets.
Feb 15, 2008 | LG WM-1480FHD Front Load Washer
Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Nov 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
