Question about Ariens Lawn Tractor 46"" Riding Lawn Mower 936053"
How do i add transmission oil - Ariens Lawn Tractor 46"" Riding Lawn Mower 936053"
  • Ariens Master
  • 2,478 Answers
Should a plug or cap on top of transaxle.
Posted on Apr 18, 2014
How to put transmission oil in a 2001 Audi A6
Remove the transmission oil filter and you can add the oil through there using a long funnel or funnel that has a plastic tube long enough to reach. Add the oil slowly to keep from overflowing and make sure you add the exact amount that you removed.
Oct 14, 2014 | 2001 Audi A6
FILLING TRANSMISSION OIL ON A 1996 SUNFIRE
add it to the TRANSMISSION (red) dip stick tube. check on level ground traney hot in park while running.
Apr 16, 2013 | Cars & Trucks
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
Trying to find the exact location on my car to add my transmission fluid i have automatic 2007 suzuki frenza my chek engine light is on
Open up your bonnet and look at the very back of the engine and you should see a long tube with a colored handle sticking out, also the check engine light can also be the engine oil so on either side of the engine you should see the same thing as the transmission handle. Its best to check both the transmission & engine oil/fluid by pull out each one by one when the engine is off and cold then get a rag and wipe off the oil/fluid on the longs metal sticks and putting them back in & out to see how much oil/fluid they have.
On both sticks they have a add more & max level lines so if the oil/fluid is on the add more line, add more oil/fluid to them to get it on the max line.
Remeber that the transmission oil/fluid goes to the back stick behind the motor and the motor oil/fluid goes to the side one. Good luck.
Jul 29, 2011 | 2007 Suzuki Forenza Sedan
Where do you add transmission fluid on an 04 roadking
On the right side of the bike, right behind the cap that you add engine oil in. There is a chrome cover (clutch release cover) on the right end of the transmission with a large plug in it. Most of the time it takes a 7/16 "Allen" wrench to remove the plug. It will have a dip stick on the plug. Check the oil in the transmission with the bike standing straight up. If you need to add oil, you can use the Harley Davidson Syn3 oil as Harley says it can be used in either the engine, transmission, or the primary. Otherwise use Harley Davidson sythetic transmission lube. If you drain the transmission, refill with 20-24 ounces of oil.
Oct 03, 2009 | 2005 Harley Davidson FLHR - FLHRI Road...
Where does the transmission oil go
If your car has a manual transmission , there won't be a dipstick or filler tube. Oil (fluid) is added through a plug on the top or side of transmission , depending on your vehicle make or model
Sep 22, 2009 | Cars & Trucks
How do i add gear oil to my transmission
You do not add gear oil to your transmission, you add transmission fluid through the dipstick tube.
May 18, 2009 | 1992 Honda Accord
How do you add transmission fluid?
If this is for a 2002 and up explorer with the 4.6, there isn't a dipstick. It is a complicated deal. The vehicle has to be running much like the old ones, but a plug must be removed from the pan. Behind the plug is a upwards tube that you, believe it or not, squirt oil up into until it runs generously back at you. then it is full.
Crazy huh?
Nov 25, 2008 | 2004 Ford Explorer
Add transmission fluid
On 91 vehicles there's a 17mm allen screw on the side towards the left front wheel. Open it add the oil there on a level surface and fill till oil reaches the hole and starts coming out. DO NOT FILL OIL FROM THE TOP where what seems to be a plug. It's actually the timing marks and houses the clutch. Put oil there and you'll need a new clutch.
Nov 01, 2008 | 1991 Volkswagen Jetta
CHANGING THE FLUID
2000 Chev Malibu 3.1 L checking the transmission oil level is a must since there is no dipstick to check the oil level with. The MOTOR oil is hot to change the oil in the motor. Driving the car up on ramps alters the level a bit as does the trans fluid at 200 degrees instead of the recommended 100 degrees. Let the car idle while you slide cardboard, newspaper, a flex socket wrench with a deep 7/16 inch six point socket. Set both the Park at the transmission gear selector and the parking brake, and put blocks behind and in front of the rear tires before you climb underneath the car. Cars roll off of jacks, ramps and whatever enables mechanics to get underneath. Before changing the motor oil while the engine is at a slow idle, using a six point 7/16 wrench turn the plug on the passenger side of the transmission counter clockwise looking down at the top of the bolt/inspection plug. If oil runs out put the plug right back in. If not add about four ounces at a time.
To add fluid, remove the red add fluid cap is on top of the chain/side cover which is underneath the exhaust crossover in front of the air valve. I used a turkey baster with the bulb removed and used a funnel into the baster which I placed into the add fluid hole after removing the red add fluid cap. While it is a better to have one person adding fluid while the other is underneath yelling stop when the fluid starts to run out of the inspection hole, I added 4 oz at a time and may have a slightly overfilled transmission. Although the car is not level, if you have fluid at normal operation temperature, the expansion of the fluid will compensate for the overfill due to the rear of the car being lower than the front.
After removing the motor oil and filter, spray some engine degreaser on the side of the motor and transmission to remove dirt and to make finding future leaks and pinpoint their location.
If you do not have a leak and are not losing transmission fluid the time to check the fluid level adds less than five minutes to your oil change. If you have to remove the fill plug and add fluid after finding or buying Dextron III transmission oil, you may add 15 - 30 minutes to the oil change.
The exhaust crossover pipe is several hundred degrees even at idle. A bright flashlight is helpful to find leaks when lying on the ground underneath the car and oil pans.
Jun 02, 2008 | 1983 Chevrolet Malibu
Ariens Lawn Tractor 46"" Riding Lawn Mower 936053" Logo
123 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
