Daewoo dwd m1032 doot won't open. sounds like it is locking/unlocking but the door won't budge. any ideas?
SOURCE: Daewoo washer - LE error message
replace the lock switch
Posted on Dec 27, 2009
bunnydawg
  • 5158 Answers
SOURCE: My door won't open on
unplug the machine for about ten minutes and then try to open the door after you plug it in. If the plug is not easily accessable, locate the fuse in the fuse panel for it. i may add after you have interupted power to the machine, you may want to try opening the door then.
Posted on Jun 12, 2011
  • 2696 Answers
SOURCE: the door is locked and
unplug it,remove the bottom panel,stick your hand up where the door lock assy. is and on the bottom of the door lock assy. there is a plastic wire that releases the door manually,grab it and pull down and the door will release.
Posted on Jul 10, 2011
  • 500 Answers
SOURCE: cycle completed, water out, buzzer
Hi jht1,
I believe your Door Lock has failed. But lets try something first:
- Turn the machine off, plug it out of the wall, and leave it out for 5 minutes try toe open the door then
- If it did not work, select a cycle, run it for 5 minutes, switch to a drain cycle to drain the water out, and wait again for the Door lock light to vanish, then try again.
If neither of these helped then you need to replace the Door lock ( Part number: PS2367737 - LINK )
I hope this helps
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Posted on Aug 18, 2011
SOURCE: daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Posted on Dec 19, 2011
Cenral locking won open the tailgate fuse 1 ok
It normally DOES NOT Unlock with the Door Unlock. Depending on the Year/Make/Model. Some have a Separate Button, Some you have to Push 2 QUICK Unlocks for it to work, then there is one I ran into that you had to push it 3 times (I though that was odd).
One Quick Push = Drivers Doot
Two Quick Pushes = All Doors
Three Quick Pushes = Trunk
Apr 18, 2015 | Cars & Trucks
1999 Plymouth breeze door light keeps flickering on and off and my doot locks keep latching up and down
that sounds like the central locking controlling lock is malfunctioning , if it is the drivers door then that lock is the control lock and need replacing
Oct 27, 2014 | Cars & Trucks
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
I have a daewoo washing machine model DWD-F1011
I believe the EO code means the pump is blocked, and you will have to clear the pump for it to work again.
Oct 12, 2013 | Daewoo Washing Machines
On 2006 saab conv trunk wont unlock using handle on trunk lid, works using remote and door button
Saab have an auto-lock to thier trunks. So that nobody else can open your trunk while you're in the car etc. If you open and then closes a doot the lock should unlock. If not, your modell is only unlockable with key/doorbutton.
Oct 06, 2013 | Saab Cars & Trucks
How to change the switch door lock
What is the model number of your unit?
Nov 02, 2012 | Daewoo DWD M1031
WASHER DOOR STUCK
Not all that uncommon on some front loaders. Yes, it is trying to lock and unlock. You can try two different things that might work. 1) Unplug the unit and let it set for 5 minutes and see if it then unlocks itself. Some units have a bi-metal timing that can take from 2-4 min. to release after the spin stops. 2) Wake up unit by pressing start or any button that starts the lock clicking. Have your hands on the door with some gentle pressure because if it unlocks you can pull the door open. Sometimes these things get mixed up and lock, unlock, and lock again. Once you get it open it usually clears up and does not happen very often.
May 17, 2012 | Daewoo DWD-WD3011WW 4.0 cu. ft. Capacity...
Daewoo DWD-F1011 PFE error code
Nov 16, 2009 | Daewoo Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
