Question about 99-03 Ford F150 XL XLT / Expedition 1PC Front Vertical Grill
A voice in the Ford F 150 model 2003
I have a rumbling sound when you press on the gas pedal while driving I do not know where that voice issued from the engine or transmission of note that the car 6 cylinder Transmission Manuel on you change the Spark blog and you clean the throttle body and change the clutch and Sulaindr What I want is holidays Express your solution
  • gorge mathla
    gorge mathla Apr 17, 2014
    Sound appears while walking only
    Sergeant:
  • 268 Answers
That sound could be caused by many different things, but to isolate it then use a free AutoZone Diagnostic Code Reader to see if its coming from the engine. It could be a sound of bearing going bad by a wheel. As you have 4 wheels there is 4 bearing for me when I had to replace my sealed bearing it cost about $45 to buy and using some air tools took me 40 minutes to replace, but without air then it could take hours. Your back axle has bearing in it that is loud when driving. These are just a few things that could cause that sound. I would suggest that you look under the truck to make a visual and be sure your not dragging something. LOL my wife complained of noise and when I looked under the truck I saw she had been dragging a tree limb.
Posted on Apr 29, 2014
I have a 2003 Ford F-150 FX4 5.4 and the AC only blows out of the defrost and help
Dustin, Sound like vacuum loss to position switch. Defrost is the default position when vacuum is lost in vent control system. Check any and all vacuum lines and connections under hood first, especially any that run through firewall. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2001 F150 V6 4 2 AC Heat Stuck In Defrost Easy Repair
Heating Vent Control Issue Page 2 Ford F150 Forum
2003 150 heater auto climate control Defrost Only Ford F150 Forum
Fixed the EATC defrost only Ford F150 Forum Community of Ford Truck Fans
Apr 13, 2016 | Ford Cars & Trucks
My 2003 ford taurus just stopped accelerating when i push the gas pedal while i was driving
it could b just the acklator cable that slipped of the throttle body
look under hooh a have someone press on the acc and see if anythingis moving
Jun 28, 2014 | 2003 Ford Taurus
Vibration in engine area felt in gas pedal
Almost sounds like maybe a motor mount issue.
Nov 30, 2013 | 2003 Ford Taurus
Car won't stay goin without foot on gas
There has to be a story about that situation
Share it with us ---the long version & what possibly
could we do for you ,IF --you never work on your
own cars,if that is the case
Dec 07, 2012 | Cars & Trucks
2009 mini cooper clubman with sport button-delay when press on gas.
The fuel pressure and fuel system needs to be inspected.
I suggest you few helk links.Click the link below and follow its troubleshooting procedure:------------------Pushing on the gas pedal, but the car slows down? Gas pedal to the floor and the car slows down? http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
-------------Car only starts when gas pedal is pressed? http://technoanswers.blogspot.com/2012/01/car-only-starts-when-gas-pedal-is.html
----------1999 Ford F-150 Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
----------Delay starting on Toyota Prius? http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
These will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
1991 F 150 will only idle,dies when gas pedal is pressed
Sound like a carburator problem. Possibly a bad accelerator pump. A carburator kit comes with a new one if you know how to install the kit. If not either have a shop rebuild it. This is much cheaper than buying a new one.
Dec 04, 2011 | 1991 Ford F150
When I am not pressing on the gas pedal, the oil pressure guage flickers between low and high very fast. As soon as I press on the gas again, it goes right back to the middle (This is normally only after...
The gauge issue is most likely a defective oil sending unit( or pressure ) switch.. No biggy.. They usually run less than 20.00 and labor of approx. 30 min.. Your vibration issue could be a number of things.. You'll need a Tech to test drive it.. could be the brakes rotors.. but not sure..
Mar 08, 2009 | 2003 Ford Ranger Regular Cab
99-03 Ford F150 XL XLT / Expedition 1PC Front Vertical Grill Logo
70 people viewed this question
Top Spyder Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Spyder Vehicle Part and Accessory Expert? Answer questions, earn points and help others
