Question about Whirlpool Duet Steam WED95HEX 27" Electric Steam Dryer with 7.4 cu. ft. Capacity, 11 Cycles, 5 Temperatures, Quick Refresh/Enhanced Touch-Up Steam Cycles, EcoBoost Option and Quiet Dry Ultra System
Whirlpool wed95hexwo fuse
Dryer will not start
Dryer want start come on or nothing
If the dryer won't start, then the safety fuse is usually the culprit. Remove the rear panel to access the fuse. Here is a link to the part you need.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-dryer-thermal-fuse-item-number-ap3132867.aspx
Nov 16, 2011 | Whirlpool LER4634J Electric Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    Dryer will not start when pushing start button it just clicks once
    This sounds like a problem with the thermal fuse blown which is wired in series with the motor. Power to the motor is terminated when the thermal fuse blows and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed instructions in troubleshooting this kind of Whirlpool Duet or Kenmore Elite dryer problem.
    Troubleshooting Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
    Mar 23, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
    Whirlpool Cabrio Dryer Wont go past sensing light when I press start. The door is tightly closed and the filter is clean. It just won't even try to start it just just beeps once.
    my dryer sensing light was on and dryer would not start, we replaced the sensor fuse and now it works the fuse is in back of dryer close to the bottom on the left hand side very easy to replace cost $11.00 by the way don't call whirlpool they have no clue, wanted to send repair man out to fix it.
    Nov 04, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
    Whirlpool gas dryer. Only few min.( less than 5min) heat work.
    there is a thermal fuse inside the dryer it is a one time fuse also there is an ignitor that could be bad
    Jul 03, 2009 | Whirlpool WGD5300S Dryer
    Whirlpool dryer will not start when I press the start button.
    frist check the door switch in sure it is working if it is good unplug the dryer remove the back cover where the vent comes out there is a little white fuse with 2 wires on it. it is oblong and most of the tim the 2 wires are blue replace this fuse and your dryer should work fine.
    Jan 19, 2009 | Whirlpool LER4634J Electric Dryer
    Whirlpool LER5644EQ2 Electric Dryer that won't start
    HI yes it could be a fuse its called a thermal fuse located at back of dryer remove back on the left sede on air duct a fuse with 2 smaller blue wirse that should be your problem thanks THE APPLIANCE DOC
    Sep 06, 2008 | Whirlpool LER5636P Electric Dryer
    WHIRLPOOL DRYER WON'T START
    It may be as simple as a thermal fuse. Some Whirlpool dryers have power for the motor going through the theraml fuse.
    Mar 08, 2008 | Whirlpool LEQ9858P Electric Dryer
    Whirlpool Duet Steam WED95HEX 27" Electric Steam Dryer with 7.4 cu. ft. Capacity, 11 Cycles, 5 Temperatures, Quick Refresh/Enhanced Touch-Up Steam Cycles, EcoBoost Option and Quiet Dry Ultra System Logo
    52 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
